Question about Sport & Outdoor - Others
I have a 1987 honda 4wheeler that will just shut off while riding. when running it runs like it is new. sometimes start right up and sometime really have to mess to get it started, then it will start and run like a new one. rebuilt carburetor and still having same problem. can u help me
  • 1,428 Answers
From experience I can tell that this is a fuel system related problem
1. Check Fuel pump
2. See the fuel filter
3. See the Oxygen sensors.
That will be all.
Good luck.
Posted on Feb 01, 2010
My troybilt bronco riding mower won't start the gas n oil r fine when I turn key it has no fire
possibly a bad starter switch which has a built in kill switch. There is a wire that goes up to the coil that is used to kill the spark when you shut it down and also goes in the safety circuit to prevent it from starting unless everything is in the right position. sometimes you can unhook the wire and still run safely. if it doesn't shut down when the switch is in the off position a toggle switch can be wired in to ground the circuit if you need it.
May 12, 2014 | Garden
Honda Fortrack 250 XAtv 1987 Kick start, air
Check the heat range on your plugs or their general condition. Wouldn't hurt to run a carb cleaner and do a general tune up as well. Hard to start when warm is usually a fouling issue with the plugs or a fuel air mixture problem.
Normal routine maintenance can fix the problem most of the time.
Oct 05, 2013 | Se Hbar Atv High Si Pt
1987 sportster 883,sometimes will not fire,sometimes fires right up,replaced coil and wires,sometimes just quits like turning off the key,and not start.
when it shuts off i would check to see if your on/of switch has continuity in the on position, if yes is your answer check the r/r = regulator rectifier it will give you stator symptoms when the stator may be functioning properly also just for giggles check your stator the procedures for checking also check the starter to make sure it is not sticking if it is sticking it will cause run ability problems
Oct 15, 2012 | Harley Davidson Motorcycles
1987 LeBaron won't start unless I pour gas into
Check you injector seals,you may be losing pressure in the fuel lines
Jul 16, 2009 | 1987 Chrysler LeBaron
Yamaha runing on 2 cylinders
carburater needles to much wear not seating properly, or coil or plug wre problem.
Nov 10, 2008 | 1987 Yamaha FZ 750 MG (Europe-US)
Sport & Outdoor - Others Logo
14 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
