Question about HP Pavilion dv1000 Notebook
I have the same issue with my dv1000 "If I press the switch at the top left of the unit ( the one that puts the unit in standby when the lid is closed), the screen comes to life momentarily sometimes for 15 to 20 seconds. I can use with an external monitor and when the screen is dark, I can see that it is operating, but it is too dark to use.". I have changed the inverter and it still doesn't work, how do I check if th einverter I bought as a replacement works and/or is compatible?.
  • colmoconnor_ Feb 01, 2010
    Thanks but I replaced the inverter and it still doesn't work,the exact same issue(as you described above). If the backlight went would it not even light up momentarily?. What are the chances of the inverter I got not being compatable or actually being broke when I got it do you think?, how would you tell if the inverter didn't work?.
  • 2,567 Answers
Usually inverters fail in one of the following ways:
1. When you turn on the laptop, the screen lights up for a short period of time and then goes dark. You still can see an image but it is very dark, almost invisible and definitely not usable. When you restart the laptop, the screen lights up and then goes dark again. The laptop works fine with an external monitor.
2. Your laptop turns on but the screen remains dark all the time. You still can see a very dim image outline. The laptop works fine with an external monitor.
3. The laptop screen works fine for hours or even days, but sometimes it goes very dark as it mentioned above. When you restart the laptop, the screen works fine again.
Inverter failure symptoms are very similar to backlight lamp failure symptoms and in most cases you cannot tell which one is causing the problem until you replace either the inverter board or the backlight lamp. From my personal experience, inverter boards fail more often than backlight lamps. If you have to guess, replace the inverter first.
Posted on Feb 01, 2010
  • Mohamed Omran Feb 01, 2010
    Please refer to the following page which explains how to test the LCD inverter:
    http://www.laptoprepair101.com/laptop/20...
E725 notebook goes to standby
Go to control panel, power options, look down to the left to system standby and select never from the list, next! top right "hibernate" click, and make sure hibernate box on the left is unchecked, and close window. This should solve the problem computer going to sleep.
Apr 23, 2012 | Acer eMachines 5202496 PC Notebook
Washer woant spin after washing heavy down comforter
You most likely have one of two possible issues going on with this machine. Either the lid switch assembly has been damaged by the comforter floating up or the comforter may have gotten torn allowing some of the material to get stuck in the pump. Since you mention no tears, let's check your switch.
As far as the lid switch, there are two different ones that were used in this washer. One was a mechanicel stlye switch that was activated by a plunger attatched to the edge of the lid. You can identify this pretty easily by looking at the lid for a "tab" that hangs down and would go through a small opening in the top of the washer when the lid is closed. The actual switch is below the top of the washer and would have an arm that protruded just below the hole. Pressing this arm should produce a faint yet audible click sound. You may notice the arm is bent out of alighnment causing your no spin problem..
The second type of lid switch used was a magnetic style switch. This is identifiable by a rectangular block attatched to the bottom of the lid, and a corresponding rectangular plastic strip on the top of the washer. The idea being that when the magnet (bottom of lid) is on top of the switch the contacts are closed.
-Unplug the washer-
To access the inside of the machine you will need to use a putty knife to release the front panel. There are two clips one on the left and one on the right between the top of the washer and the front panel. using the putty knife lift the clips on either side while pulling the front forward.
With the front panel removed you will see two tabs that hang from the extreme right and left of the washer top. There will be one 1/4" screw in each of the two tabs holding the top down. Before pulling the top up you wil lneed to remove the magnetic style switch as the wires that go to it are pretty short. You may even see that one of the wires has been pulled out at this point (causing your no spin) if so cut both wires and strip back the insulation and wire nut them together to allow you to use the machine until you get a new switch. To remove the switch you have to press a tab located at the rear of the switch in and push it up through its hole in the top. (WH12X10334 magnetic style switch part number)
I would not reccomend leaving any lid switch bypassed as this could result in a safety issue if children were to open the lid during a spin cycle and reach in the tub.
Good luck with this and feel free to reply with any other questions!
Jun 26, 2010 | General Electric WCSR4170D Top Load Washer
Panasonic dmres30v unable to open dvd drawer led displaying u99 and cant remove
Press the power button on the main unit to switch the unit to standby. When the unit is in standby , press the power button again on the main unit to turn it on. If the unit doesn’t switch to standby, press and hold the power button on the main unit for about 10 seconds to forcibly switch it to standby.
To open the drawer, press and hold STOP and CH UP buttons on the main unit at the same time for about 5 seconds.
Nov 27, 2009 | Panasonic DVD-S35 DVD Player
My Dell dv1000 has completely died
You are listing this unit as a HP and stating it is a dell.???
Nov 06, 2009 | HP Pavilion dv1000 Notebook
Screen dim HP pavilion dv1000
The lid actuator switch may not be working correctly. It's a small switch above the keyboard and led's on either the right or left side. Try pressing it 2 or 3 times to see if the display starts working correctly again. If so, it will need to be replaced.
If that doesn't work, you can also turn it on with the ac adapter plugged in. After it boots, press the power button and hold it in until it shuts off and then turn it on again and see if the display has returned to normal.
If neither of these options work, your laptop may need to have the backlight replaced.
Aug 13, 2009 | HP Pavilion dv1000 Notebook
Washer fills with water, washes, but when it gets to spin cycle it quits
probably lid switch uplug unit! to check take out two phillips head screws either on front console left and right about 1 inch in from side or behind in console left and right lift out and roll up console look for lid switch connector in middle of cabinet release and pull up put a small piece of wire between the outside two terminals on connecter then plug back in and try spin cycle if it works order lid switch with model number 877-262-1479
May 31, 2009 | Kenmore 24032\24036 Top Load Washer
My washer starts and stops a few seconds later with a FL code
Hello donaldwoulla,
I’m an owner of a FAV6800AWW not a GURU, this forum automated rating system is way too generous, I will try to help. Do you feel OK to try some troubleshooting? The following troubleshooting assumes you want try a possible DIY fix.
“FL” code is Failed to lock, we will try a few troubleshooting steps. The following test will be done by selecting the Spin Only cycle. First test will be done in service mode.
1. This is from SM; Press Enviro Plus and Spin Only keys for 3 seconds to activate Service Mode. Access Board Output Test by pressing the Delicates key. Display shows “ot” and the lid locks should actuate locking the lid. Does this happen, do you take the “FL” fail code in this process? Hit OFF button to cancel this test.
2. I want to make sure you signal an “OP” alarm to the display. Can you select Spin Only cycle with the lid open press start. Do you signal the “OP” alarm, lid open to the display? If it does close the lid and the “OP” alarm should clear, does it? I’m checking that the lid magnet is in place and the signaling connections are working thru the left lid lock back to the control board.
3. With spin only cycle selected and the lid closed press the Start Button do both lid locks try to close and lock the lid? From your initial post I believe you throw a “FL” to the display very quickly, that is the left and right lid locks do not actuate several times before the control board displays the “FL” fail code. Is that correct?
4. This step requires you to raise the top off the washer you will need to the move the washer out several inches and you should have a helper available to hold the lid up for you. Unplug the washer from the 120VAC outlet. Use this info and the FAV6800A/9800A Service Manual to assist you. To raise the top of the machine, insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. See page 33 of the SM for putty knife insertion point. We are going to reseat the Left Lid Lock plug a couple of times into the Left Lid Lock. We are checking to see if there might be some corrosion on the plug contacts. Take a look at page 34 of the SM. Top right of the page Lid Lock/Reed Switch Removal where the persons thumb is. This is the plug we want to remove and reseat a few times. It may be difficult to do remove so be careful. Mine was very difficult to remove the first time. This lid lock is near the bleach dispenser and other owners have had corrosion issues with this left lock causing issues. After doing this and you have reseated the plug into the left lid lock a few times power up the washer and give it a try.
Just to let you know don’t worry about the right lid lock, it’s signaling and control functions are in parallel with the left lid lock. I’ve had mine disconnected since mid Dec. The left lid lock is the important lid lock. It has the dual functions of signaling the control board that the lid is open/closed by the magnetic reed relay in that lid lock and the lid is locked by contact closure back to the control board in that lid lock. If this doesn’t help resolve the issue we will try removing the left lid lock to inspect if you feel OK to continue. Good luck. Rich
Mar 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Hp dv4000 screen problem
Sounds like its trying to go into sleep mode or standby or just turning the screen off.
This usualy happens because in the power options, the screen is set to shut off after say 5 minutes. It could be that the lid closed sensor is bad and it thinks your closing it and does this.
Try right clicking on the desktop, select properties, in the pop up box, select the scren savers Tab and at the bottom it should have a button for the power options.
Click that, in there you should see several new tabs partaining to your power options. one has some drop down boxes that lets you set what it does when the lid is close, when you press the power button and when you press the sleep button.
I would try turning the, " turn off screen option" to off and see if it still does it.
It usually says. 'When I close the lid to my laptop, i want it to: " then it will list the options.
Also turn off the standby settings if you want so it doesnt go into standby every time you walk away for 5 minutes.
Just set it how you want. but for now, just disable the close lid options so we can see if it still does it.
Good luck and let me know.
Jan 07, 2009 | HP Pavilion dv4000 Notebook
Neptune TL error code op
This forum member’s solution is going in the right direction I’m going to give you a bit more info to troubleshoot the issue if you want to DIY the repair. You have lost signaling from the left lid lock to the control board. The lid magnet could be out of position here is a quick check to try. Raise the lid then press Spin Only key, press on and you should throw the OP alarm to the console. With the lid open place a magnet on the left bumper as shown in this pic. If the OP alarm fails to clear we rule out the lid magnet as out of position.
Next step is to raise the washer top as shown on page 34 of the Service Manual
The Service Manual for reference. Sears Parts Direct for reference.
To raise the top of the machine insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. See page 33 of the SM for putty knife insertion point.
Disconnect the washer power cord. We can try to reseat the Left Lid Lock a couple of times to see there is there is corrosion causing a issue. Removing the plug is difficult so be careful. See page 34 of the SM, the plug you are going to reseat is shown in the pic on page 34 next to the tech’s thumb in that pic. After reseating a few times power up the machine try a Spin Only cycle, close the lid and hit the on button and see if the left lid lock is signaling the control board that the lid is closed. If you still take the OP alarm then it’s time to remove the left lid lock and inspect for corrosion or a broken wire on the magnetic reed relay. Some owners have found that corrosion has caused the soldered lead ends on the on the magnetic reed relay to break off. They can be soldered back on. See pic’s for corrosion issues and the lead that has broken off the magnetic reed relay.
Follow the SM to remove the left lid lock be careful when you release the tabs on the left lid lock case halves for inspection they break of very easy. Post back if you still need help. If you need to replace the left lid lock here is the part number 25001048 and a link, another. Good luck.
Sep 30, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Screen problem Hp dv1000
The main two causes for this, are the inverter, which supplies the screen with the proper amount of power in order to function correctly, or the screen. If the inverter isn't puting out enough power it will cause the screen to darken or black out completely. Start by checking the screen connections. If all the connection are properly seated, the it's either the inverter or the screen it self.
Jun 20, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
166 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
