Are the tension arms up? if so, the unit needs looking at to determine the cause of the fault. These X series decks are not the easiest units to get corrected because of the many features and the servo tension system they employ. I have one on the bench now and have been doing Teac decks for over 40 years. I can help if you need a Technician and I can direct you to guys I know if you are no near Chicago.
These units are mechanically in need of a good cleaning and application of new grease in the slide plate mechanism. The Play idler that was in the last one i rebuilt was sent off to Terry'srubberrollers.com to have it get new rubber on it. There is certainly a lot of work to be done on these units but they can be made to work again. Personally though, I would just get a Teac A2300S or SX and use that as the overall maintenance and longevity will be better in the long run. I have serviced hundreds of them and I still do. The design of the Teac is not so much dependent on all kinds of mechanical parts as the Sony is. The last TC366 I worked on took about 4 to 5 hours to correct all it's problems. Then when you are done you still have a lever activated deck where the Teac is a solenoid deck with remote capability. I worked at both Sony factory Service and Teac Factory Service so I have had experience in each item.
Hi, your unit has "The efficient belt-drive system provides accurate play and control" and normally the belt lasts for long time ..i.e at least 5 years.. If you sure that it is belt ,you need to take the turntable disc (should be a security pin in the middle ) than you can access underneath of disc or some models needs to access from bottom of the turntable ,inside the receiver.. just in case ,if you need detailed user manual in pdf format pls visit he URL below.. Hope this helps! Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks --------------- User Guide for Teac LP-U200
View Table Of Contents» http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
