Question about Apple iPhone 3G
My iphone 3g has a blank screen and won't do anything, what can i do to make it work
    President:
  • 239 Answers
Try a reset. Hold the sleep button and the home button together until phone turns off and release buttons when you see the Apple logo. The re-boot should take a min or two. This generally solves a lot of problems.
Jim
Posted on Feb 07, 2010
    Problem Solver:
  • 5 Answers
Posted on Jul 10, 2010
SOURCE: iPhone 3G Battery Life
hi guys!!!
mine has improved quite a bit in da last few days..follow da instructions 1.RESET NETWORK SETTINGS 2.SWITCH OFF ALL APPLICATIONS LIKE GPS,3G,WIFI,AUTOMATIC TIME UPDATE AND PUSH UNLESS U REQUIRE!!(SAD THOUGH!!) 3.FORCE QUIT EACH ICON INDIVIDUALLU AFTER OPENING DA ICON 4.BRIGHTNESS AT NEXT TO LOW(SWITCH OFF AUTO BRIGHT)
mine has gone 3hrs standby to 16hrs standby wit minimal usage..and 14hrs after moderate usage..its been increasing every other day..its spooky..its got a mind of its own..A.I kinda!!!
pleasr respond if my tips helped u out..cheers!!
frm abu dhabi(uae)
Posted on Oct 20, 2008
Joed911
  • 4338 Answers
SOURCE: Iphone 3g 3.0 stuck on iphone apple logo loading screen
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Posted on Aug 28, 2009
Testimonial: "the last option helped alot thanks x"
  • 150 Answers
SOURCE: iphone 3G screen not working after dropping. Not
It sounds like you have some internal screen damage, your LCD may be damaged or your digitizer. A professional will need to take your phone apart and determine the cause.
Posted on Dec 31, 2009
bahratt
  • 561 Answers
SOURCE: My iPhone 3G suddenly stopped working. The screen
In certain situations, an iPhone will automatically go into recovery mode after an update or restore issue. If your device is already in recovery mode, you can attempt to restore using iTunes.
Please follow steps on this link http://support.apple.com/kb/HT1414
Note: Restoring your device will delete all the data from your iPhone or iPod touch, including songs, videos, contacts, photos, calendar information, and any other data. All iPhone or iPod touch settings are restored to their factory condition.
Posted on Jan 12, 2010
  • 4 Answers
SOURCE: My Iphone 3G won't connect to home wifi.
you can try to set your wifi same as your husband's one, check the wep code and wifi shold be enabled.
try this and give feed back!
good luck
Posted on Jun 30, 2010
My iphone won't turn on
Try plugging it into a computer and putting it into DFU mode or recovery mode. If you search how to do so on youtube there are step by step directions. If it does enter DFU or recovery mode then restore the iphone.
Feb 18, 2013 | Apple iPhone 3G
White screen the phone won't turn off
Here is the link that might be useful, hope it helps: http://phaktor7.wordpress.com/2008/12/17/iphone-3g-white-screen-of-death-solution/
Dec 25, 2012 | Apple iPhone 3G
The screen lights up but blank white, it won't do anything including switching off
The first thing to check weather your phone is working fine is by plugging your iphone to a computer using you usb cable.
* If the phone have been detected in normal way when itunes comes out and give complete details and information of your phone,it seems your phone LCD screen has the problem,it somehow need replacement.(bringing it to apple center is the solution for parts replacement.)
* But if then phone have been detected as recovey mode,your phone firmware seems to have problem,by somehow fixing this basically,try to press and hold POWER + HOME button simultaneously for about 20-30,then see if the phone sets to normal.
If not,then you need to restore the phone by following this procedure : FOLLOW ME
If you have some concerns,please let me know and i get back to you as soon as possible.
Thank you for visiting FixYa...
Aug 22, 2011 | Apple iPhone 3G Black Smartphone
I dropped my iphone 3g and cracked the screen....I replaced the screen and now the bottom half won't work...it says slide to unlock...and it won't slide...but the top that says slide to turn off...
Check the 2 pins connected on the home button if touch the interface of the board,might not hitting that is why the slide unlock not working.
Jul 21, 2011 | Apple iPhone Smartphone
Hi My iphone 3G screen has gone blank, u can hear it ring and recieve texts but can not do anything? Please can you help.
obviously, the problem is from the screen. This phone is working but the screen is defective for one reason or the other.
You need to have the screen replaced and problem would be solved.
There is nothing else wrong with your phone other than the screen.
Let me know if you would like to replace the screen yourself or not.
Good luck.
Jun 13, 2011 | Apple iPhone 3G
Iphone 3GS- only get the apple loading screen.
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Nov 29, 2009 | Apple iPhone 3G
Nov 20, 2009 | Apple iPhone 3G
I updated my iPhone 3G to 3.1. Now it has crashed and keeps showing me a cable and iTunes logo. Each time I plug it into the computer, it says ''iTunes Store cannot process your request error -6807''. It...
switch off iphone ,hold down power and home button for exact 10 second and then release power button and keep on holding home button until your itunes detect and then you can upgrade your iphone 3g
Sep 27, 2009 | Apple iPhone 3G
Set up delta email account on iphone
Go to settings on home page.  Then to "mail, contacts, and calenders". Then "add accounts". Fill in the blanks with your account info and it should work.  I know this sounds simplistic but that's really all there is to it.
Apr 08, 2009 | Apple iPhone 3G Black Smartphone
IPhone 3G... My screen will not allow me to do anything!
Sounds like your digitizer has failed. There's nothing you can touch on the screen, right?
Apr 02, 2009 | Apple iPhone 3G Black Smartphone
Apple iPhone 3G Logo
362 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
