Question about ION Audio iTTUSB Turntable
Purchased profile pro USB turntable from Bed Bath and Beyond Jan.30th no needle attached to arm to play recorder. Josephine
    Sergeant:
  • 226 Answers
Hi, is there a cartrdge fitted at the end or is it just the headshell.
But anyway, if you have just bought it then you will have to tell them asap, explain to them and they may send you one through the post.
But if it is not replaceable then they should change it by courier btu not through your expense.
In fact I would have it replaced, as it may have been a demo unit.
Please read this -
http://www.bedbathandbeyond.com/policyReturns.asp?order_num=-1&
It looks like there will be no quibbles about changing it, either online or in a shop.
Good luck
Anthony
Posted on Feb 02, 2010
The needle arm won't lift and go to the record
Pull the turntable off the mount and look at the loading mechanism, I will bet you will find a broken piece.
Jul 01, 2016 | Audio Players & Recorders
THE TONE ARM ON MY ROCKOLA 459 SLIDES OVER THE RECORD WITHOUT PLAYING.
Hi
It sounds as if the tone arm has become unbalanced. Make sure the turntable is on a firm flat horizontal surface and at the opposite end of the arm from the needle there will be a weight and a means of altering the position of weight on the tone arm. This weight keeps the needle on the record but only lightly when positioned correctly. If positioned too far from the pivot post the needle will as you have experience skip virtually straight across the record. You need to adjust the weight so that the needle just sits in the groove and plays without being too heavy. It is best to use a record you are not too worried about for this testing as the test record can sometimes get scratched.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 11, 2014 | Audio Players & Recorders
Record player repair
The top arm that swings over the spindle will control the automatic return. Leave the unit off. Swing the overhead holding top arm over and manually load a record. Now switch the top arm over the niddle spindle. Make sure that the switch is set for 7", 10" or 12" (45, 78, or 33). Manually place the tonearm at the start of the record and flip switch to 'play' (not reject or auto). It should play the whole record and automatically eject at the end and then shut off. Leave the arm swung over the middle after you loaded the record. Good luck. Let me know if you have any more questions.
Aug 18, 2014 | Audio Players & Recorders
Needle jumps on all new vinyl, but plays old records fine. New vinyl plays on other turntables without a problem. Do you have any suggestions?
Adjust the balance force up. This is a counterweight on the back of the arm. For most needles it is 1-2 grams.
Jul 06, 2014 | Crosley Audio Players & Recorders
After sitting unused for many years, I just
Hi, Does the arm have a lever to lift the arm up, also called a cue. I had an arm where it did exactly the same thing and found it to be the lifting device. What turntable is it you have?
May 12, 2010 | Audio Players & Recorders
Digitech turntable - skipping stylus and arm
You might need to apply more pressure to the stylus. There should be a weight on the end of the arm, it should have a control to move it up and down. The only other thing is the stylus damaged from transit?
Feb 02, 2010 | Audio Players & Recorders
Tonearm lifter in UP position - how to fix
I have also had this problem with the same model turntable. I opened mine up and the problem seems to have been that the grease on the arm lift and cueing lever was gumming up the linkage between the two. (I suspect that my turntable hadn't been used in some time.) I managed to free up the parts by manually working the the arm lift (pressing it down) several times. I'm not sure that I needed to open up the chasis for this fix but it did help me to see what was going on. Good luck with yours.
Tim Orange
Mar 20, 2009 | Technics SL-BD20D Turntable
Proper cleaning of old vinyl record albums
Get yourself a nice carbon fiber brush. Purchase some record cleaner or just get some isopropyl alcohol 90% (it has less impurities). Secure the arm of the turntable so you don't scratch the record and put the record on it. Put some of the cleaning solution on the brush..not the record. Put the brush on the record and turn the platter counter clockwise to work the dirt loose. Check the brush and clean it if need be and repeat. Take the record off and clean the turntable. Flip the record over and repeat the cleaning process. That should do it. Thanks for stopping by and come back if you need more help. If you don't mind, rate my answer appropriately. Thanks.
Jan 19, 2009 | Vivitar ViviCam 10 Digital Camera
Can i install a turntable to my technics sc-dv290
ION has just released a turntable that connect via USB! You can now play your lp's on anything that accepts usb cables. It is available at Bed, Bath, and Beyond. Also, there are many various turntables available that connect via RCA cable. Bet Buy and Circuit City both carry mdels that will hook to your unit via RCA cable. They have some models on sale at times for under $90 bucks! Thanks for using FixYa! And don't forget to rate my solutuion! Good luck, and Happy listenng!
Jan 13, 2009 | Technics SC-DV290 System
ION Audio iTTUSB Turntable Logo
138 people viewed this question
Top ION Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Jose Ma DM.
Jose Ma DM.
Are you an ION Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
