Question about Refrigerators
Lights are on, not cold
I have a frididaire electrolux refrigerator. I believe th motor or something blew out. Lights are on and it is not working. cleaned the coils, no change, fan is working
    Genius:
  • 1,044 Answers
Check the thermostat settings. It should be on Hi cold,or maximum cool Also check if the gas has not leaked out.
Posted on Feb 01, 2010
Electrolux dishwasher edw5505ess Lights are on motor humming, changed the float pump AND the water inlet module. Still does not work Still humming and light on though...
The motor is jammed and will burn out if you keep leaving it like that. Something could be jamming up the mechanism and causing your issue.
Nov 20, 2015 | Electrolux Dishwashers
What is wrong with electrolux cooker hood when ive changed new bulbs, the extract works but lights don't.Did make a bang when old ones blew?
Good Afternoon friend, thanks for your post!
From what you have described your Electrolux hood is working properly but the lights are not coming on. I understand that you heard a bang when the old ones went out it could be possible that your receptacle is bad or wire has shorted. I would suggest having a technician out to properly diagnosis your hood. They have the appropriate tools and knowledge needed to pinpoint the reason your lights are not working properly. Good luck. -Matt
Feb 22, 2015 | Electrolux Kitchen Ranges
REFRIGERATOR NOT COLD
Frididaire is owned by electrolux and your problem is a thermostat has gone bad, there are several that control the fridge side. You will have to test each one individually.
Jun 30, 2012 | Frigidaire Refrigerators
We have just moved to a house with an electrolux ERF2831 fridge freezer. The fridge appears to be working OK, but sometimes the green pilot light and the amber fast freeze light flash alternately. When...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 17, 2011 | Electrolux ERF2831 Bottom Freezer...
Both freezer & refrigerator are not cooling/freezing. Lights work.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Nov 28, 2010 | Electrolux Refrigerators
I had no cold air in my refrigerator so i pulled it out and blew all the dust off the motor then i pulled a panel off the back and it had wires behind it with a mother board the panel must of touched metal...
ON SOME MODEL THEY DO HAVE A LITTLE BLACK RESET SWITCH. MOST LIKELY YOU WILL BE REPLACING THE BOARD. NO COLD AIR, WAS YOUR COMPRESSOR RUNNING?
Aug 04, 2010 | GE Refrigerators
Does not get cold; after a lightening storm blew the breaker, the refrigerator and freezer does not get cold. Lights and fan work.
Sounds like the main control may have been damaged. try unplugging for 5 minutes and then plug it back in. Other wise a service call is needed.
Aug 26, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Hussman hgm2ts
hi . thanks for the question . its very hard to say what blew . it could be very expensive or not . but to see what 240 volts did .call in a tech for an estimate. thanks the appliance doc
Oct 01, 2008 | Hussmann HGM-2-TS Commercial Refrigerator
Light is on but not cold.
My Freezer is working But my Refrigerator side is not getting cold like it should it is a GE modle
Jan 14, 2008 | Frigidaire FRS23KF7AB Side by Side...
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
