Question about Brother MFC-5890cn Color Flatbed All-In-one Printer
Scan settings How do I change the scan settings from the printer?
    President:
  • 2,306 Answers
On the printer you can only change the print quality with the quality button, good better or best, or the contrast settings with that button, all others like DPI for resolution have to be selected from your scan software on the computer.
Posted on Feb 01, 2010
HP Photosmart C309a default scanner paper size
Hi Norman,
Are you trying to scan from Printer to PC or Activating SCan option from PC ?
On your PC, Open Solution Center
Click on Settings option below
You will find Scan document options - select it
you will find the Size of paper set, Change it to Letter
Regards,
Sean
Jan 31, 2013 | HP Photosmart Premium C309A All-In-One...
Dell 1815dn will not scan legal size documents
I had exact same issue, could not scan in any size larger than Letter; changed Scan Default settings for paper size but made no difference. Based on dmf1984's suggestion I did same: went to Start -> Dell -> Dell Printers -> Dell Laser 1815dn -> Network Scan and changed Scan Paper size to Legal hit apply then tried scan again... problem solved92a90e38-52a9-4018-8666-d2da0be7f6f8.jpg
Feb 14, 2012 | Dell 1815dn All-In-One Laser Printer
How do I change scanner output dimension settings?
You can change copy settings in printer, cannot scan settings, you can choose desire settings in scan software while scanning.
Oct 07, 2011 | HP LaserJet M1522nf Multifunction Printer...
No preview shown after picture is scanned
If you use Brother's own software, you could: * Open it up (by the clock, called "ControlCenter" or "ControlCenter 3") * Right-click on the type of scan intended (i.e. scan to file) and choose configuration * Here are the settings controlling the scanning. If you change to "device button" on top, you'll get the settings controlling the scanning when you use the scan-button on the machine. * Change the settings to i.e. "show target folder" after scanning, depending on your requested settings.
Jun 02, 2009 | Brother MFC-9840CDW Laser Printer
Sending multiple pages in one email attachment after scanning
well go to scanning setting and change it, you change the setting to be sent one by one, if its connected to network, browse the ip address and go to scan and change the setting, if to usb cable go to the driver setting and change it, and i think from the machine setting itself can let you, so its just setting.
Mar 21, 2009 | Brother MFC-7420 Laser Printer
Pixma 130 waste absorber is full
1. turn on.
2. Press MENU, after SCAN, COPY and again SCAN - your are in a service mode.
3. Change NVRAM ACCESS and press ОК.
4. Change SET ABS-M LEVEL and set value to zero.
5. Change SET ABS-Р LEVEL (if this function not hide) and set value to zero. If this function not presents, go to next step
6. Turn off printer by a power button.
Thats all )))
Jan 21, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Cant scan 4cm x 4xm slides
The mounted slide scanning option is set for scanning 35mm mounted slides (24mm x 36mm). As far as I know there is no way to change this setting. You may want to try using the film scan option, do a preview scan, and then crop each individual slide for the final scan.
Oct 16, 2008 | Canon MP970 Photo All-In-One InkJet...
Possible to change default scan setting to PDF?
go into scan mode and select pdf, then go back to printer mode and select utility. user settings. store and current settings, then press store and it should use pdf as default
Jul 15, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Want to change default settings for scan
change the size, then utility/counter - > choose user settings - initial settings and use current settings.
should work,
May 27, 2008 | Konica Minolta bizhub C351 All-In-One...
Brother MFC-5890cn Color Flatbed All-In-one Printer Logo
159 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
