Question about NComputing L230 Network Terminal
Can i used printer to ncomputing L230 in a
Can i used printer to n computing L2309as a client) in a supermarket as a cashier, to print out bill of transaction
Yaes use this printer only usb not lpt port
Posted on Feb 04, 2010
Problems in n computing L230 model not working in windows 7
Hi!
Please download and install the latest software for your operating system from here:
http://www.ncomputing.com/softwaredownload
Hope it helped.
Aug 27, 2011 | NComputing L230 Network Terminal
After installing SP1 on Windows 7 home basic stopped connecting terminal L230. The client sees the server but when trying to connect an error about can not connect. On the server side I see that the L230...
Hi
Not clear whether you installed SP1 on the client or the server.
Try resetting or powering off and on the L230 and let it reintroduce itself to the network.
Also restart the computer that had the SP1 installed on it.
If none of the above resolves the problem, enter Network settings on the client and ensure that Neywork Discovery and File Sharing are not turned off. If they are off, enter Network and Sharing Center and use the Drop Down arrows on the right to turn them and any other desired options on.
Hope this helps.
Aug 24, 2011 | NComputing L230 Network Terminal
SAP with Ncomputing, its works?
It should work fine. As long as the SAP client is 'multi-user' aware then you're good to go. One 'acid test' is to see if the SAP client will work on a Terminal Server or a Citrix Presentation server and in this case it does. The NComputing solution, conceptually at the application layer, behaves much like TS or Citrix, thus looking for those solutions is what you'll need to know for NComputing. Here is the website I found about how to setup specific INI files for Citrix to get the SAP client working. My recommendation would be to test as is out of the box with two NComputing seats, simultaneously. If that fails, then try the suggestions on this website: http://community.citrix.com/display/adi/SAP+GUI+7.10+on+Citrix+Presentation+Server.
Aug 16, 2011 | NComputing L230 Network Terminal
Como hago para resetear a la configuracion de fabrica un ncomputing L230. no encuentro nungun boto de reset
The L230 does not have a factory reset. If you need to clear a forgotten password, simply call NComputing's Tech Support at 888365-1210.
Jul 19, 2011 | NComputing L230 Network Terminal
Cannot connect server ...... client PC diplay this message
Can you PING the L230 device from the server? In other words, are you confident there is a clear IP path from server to device? Also, if you're running on XP, turn off the XP firewall as a test. If that works and you still want to run with the firewall on, then you'll need to specify specific ports to be opened up on your firewall or your domain's firewall policy. Those ports, as listed from NComputing's website are:
Port Exceptions
  • For L-series device connection
    • TCP: 27605, 27615, 3581, 3597, 3645, 3646
    • UDP: 1027, 1283, 3581
  • For vSpace registration
    • TCP Port 3630
    • Point to:
      • register.ncomputing.com
      • or 85.214.107.229
  • For vSpace Update
    • TCP Ports 20 & 21
    • Point to:
      • 70.182.176.102
      • or 81.169.173.128
      • or 81.169.173.128
Jun 12, 2011 | NComputing L230 Network Terminal
I have ncomputing L300 thin client with usb port. I attached Cannon Laserjet LBP2900 to thin client usb. also installed drivers on host. printer is detected & shows printer ready. but when i give...
Since you posted this four months ago, there has been some major updates from NComputing to improve the USB architecture. This should improve support for peripherals such as your printer. Download the latest software for either W2K3 (v4.9.5) or W2K8r2 (v6.1.3) and update your system. Lastly, it is critical, and I mean absolutely critical, that you update the firmware on the L300 as well. The firmware is included with the vSpace update so once the host is updated, go to the L300 and tell it to update the firmware. The current firmware version that works with v6.1.3 or v4.9.5 is v1.4.1. As of this writing, 8/16/11, those are the current versions.
Apr 21, 2011 | NComputing L230 Network Terminal
I m using SUSE 10.2 on it i m using Ncomputing L-230, the USB of this device is not working on client side, any one help me
Have you contacted NComputing Support for help?
I am assuming you already requested/downloaded the drivers from http://ncomputing.prefinery.com/betas/32.
Contact Tech Support at NComputing for help either thru their website (www.ncomputing.com) or call directly at 1-888-365-1210 x1.
May 09, 2009 | NComputing L230 Network Terminal
L230
if you connect power usb hub or use 1.1 usb web cammera
Dec 27, 2008 | NComputing L230 Network Terminal
NComputing L230 won't connect to host
First Please check your Lan IP Address for host pc.
change IP address and subnet mask on L230
disable firewall or any antivirus that is blocking ports.
Then you will get connected.
Aug 13, 2008 | NComputing L230 Network Terminal
NComputing L230 Network Terminal Logo
964 people viewed this question
Top NComputing Computers & Internet Experts
Tom Chichester
Dan Shibata
Dan Shibata
Are you a NComputing Computer and Internet Expert? Answer questions, earn points and help others
