Question about Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360)
BT HomeHub wireless router which cannot connect to the XBox 360
We have a BT HomeHub wireless router with 2 laptops finding the signal easily enough. However, my son's XBox 360 with a new wireless adapter N (black model with 2 antenae) does not read the signal. We have keyed in the wireless hub code and even manually input the IP address. It still cannot connect to the hub. Any ideas please?
    Problem Solver:
  • 6 Answers
Your router may have incorect connection settings. what i mean is that your router may have security on that rejects connecting to adapter. check if the xbox can connect to the internet via ethernet cable. this will tell for sure if the 1 the adapter cannot read the signal or 2 the adapter is not able read any signals. to test if its the adapter, try searching for other signals.if you find any other signal it means your router. is rejecting to send the signal to the xbox.
Posted on Feb 06, 2010
I have just got in broadband but my xbox aint picking up my wireless signal upstairs,ive got the wireless adapter for the xbox,its picking up a few neighbours network connections,surely my xbox should be...
It is possible that the Xbox will be unable to pick up the wireless signal being transmitted by your gateway because the signal is too weak.
The connection speed of your internet has nothing to do with the strength of the signal. The best way to test this would be to try to connect to your wireless internet on a laptop while sitting near the xbox. If you cannot, you will know that the signal isn't powerful enough to reach that location.
There are three common options to amplifying your signal if necessary.
1) Purchase a High-gain antenna for your wireless gateway
2) Purchase a wireless repeater
3) Purchase a new router/gateway with a longer range capability. A "Wireless N" enabled router would be optimal for this application.
Apr 12, 2011 | Microsoft Xbox 360 Console
Wireless Network Adapter Xbox 360 (SKWIFIX360): My wireless adaptor on my xbox 360 won't connect t...
1) Reset the router then the xbox.
2) If it still does not work, Change the security code for your wireless on your router. Then connect using that security code on your xbox.
Apr 28, 2010 | Microsoft Computers & Internet
I just subscribed to wireless internet, what does my son need to hook up his xbox wireless
Your son will need a long enough ethernet cable to run from the router to the console,or a wireless xbox adapter, these in the uk cost about £45 they are prone to lagging if the console is too far away from your wireless router, I would recommend buying 2 comtrend powerline adapters, about £30 off ebay, they use your existing power cables that run through your house, so no infuriating lag.
Hope this helps.
Mar 18, 2010 | Microsoft Xbox 360 Console
I just bought a wireless xbox 360 adapter, but there seems to be one problem. My xbox cant find any networks. I've been thinking its because my internet is apart from the main building of my home and is in...
The newer 2.4Ghz or 5Ghz wireless routers should reach a couple of hundred feet. Make sure you do not have your SSID hidden. If you do, you will need to manually enter it into the xbox settings along with other security you have on the router.
Jul 08, 2009 | Microsoft Wireless Network Adapter Xbox...
Wireless adapter for xbox 360 isconnected to bt wireless broadband because the light on xbox is green, but IP failed
try going to your router page and find all the information on your ip address and everything else and put it in manually
Jan 16, 2009 | Microsoft Wireless Network Adapter Xbox...
Xbox 360 wired or wireless
yes, just dont run more than 2 computers while playing..from your router..
Jan 02, 2009 | Microsoft Wireless Network Adapter Xbox...
Which is faster hard wired or wireless xbox 360 network adapter
You will be fine either way. I prefer wireless because obviously no wires, but i have never seen any difference in speed with wired/wireless connections.
Wireless not working from netgear wg311 to a new bt homehub2
Hi Backatya,
Check what kind of security you upgraded BThomehub 2 uses. Since the hub supports more security-types then your adapter does, I suspect an incompatibility there.
You can solve it by connecting through cable and changing security to WEP or WPA (not WPA2).
Regards Ronnie
Dec 15, 2008 | NetGear WG311T 802.11g/b (wg311tge)...
Xbox 360 live on wireless router
In theory you should be able to "share" your internet connection. I use a Linksys WRT54GS wireless router and I have a Linksys Game adapter on my son's 360. He has not complained about lag or slow server times unless other intensive bandwidth is being used.
Nov 09, 2008 | Microsoft Xbox 360 Console
Xbox 360
The Xbox 360 does NOT have an "internal" network adapter, you'll have to purchase one separately (I believe they retail for around $99) in order to connect wirelessly.
If you DO NOT purchase the wireless network adapter then you'll be forced to connect with an Ethernet cable.
Jul 18, 2008 | Microsoft Xbox 360 Console
Open Questions:
See all Microsoft Wireless Network Adapter Xbox 360 Questions
Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360) Logo
652 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
