Question about Envision EN9410 19" Flat Panel LCD Monitor
Monitor won't stay on
Hi i have the EN9410e 17in flat panel monitor and today when i went and turned on my monitor it turned on for a second then flashed a little and shut off and it would keep doing this over and over. I tried unplugging the cables and plugging them back in and i even tried it with just the power cord plugged in but I still get this problem.
  • 11,361 Answers
More likely to have problem in the power supply due to bad caps, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Posted on Feb 01, 2010
Does this monitor have integrated speakers?
No HP Compaq 1701 17in. Flat Panel LCD dont have inbuilt speakers.Click here to see the specification.
If you like the post then please leave your comments and feedbacks
Thanks In Advance.
Oct 05, 2010 | HP Compaq 1701 17" Flat Panel LCD Monitor
Dell E173FP 17in flat LCD goes blank after about 10 seconds
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Replacement board:
http://www.lcdrepair.us
Jul 11, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
My HP vs19e Monitor went black, when I turn it off...
guest, If monitor vs19e acts same when connected to different "known good" pc then try this site for info: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ How old is this model? When was last time it worked correctly? 12fixlouie
May 19, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
My monitor stays on for 6 seconds
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htmYou can take the back cover off your monitor and look for the bad parts,replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and -connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 03, 2009 | KDS Radius RAD-7 17" Flat Panel LCD...
I have an Acer AL1716 17in flat panel monitor, and just out of the blue everything started getting a drop shadow on it. The longer the day went the worst it got, it's so bad now it's hard to make out what...
reset settings,the video out from the hardware,refresh rate etc.going to monitor.Also if this panel connection is loose it may do tricks like that.Good luck
Jan 26, 2009 | Acer AL1715 17" LCD Monitor
Same Flashing Problem
My Sceptre Komodo 19 would turn on for less than a second than turn off. Eventually, I could get it to stay up. But after a month, I couldn't get it to stay on anymore.
I found the solution on this website. There are some bad capacitors... 4 of them for about $2 worth. I replaced all four and the monitor works fine again. They are soldered in. They are polarized; they need to be installed the right way. The white stripe goes towards the “wall”.
2 are 470uf 25v and 2 are 1200uf 10v.
I ordered mine for about $10 with shipping from Mouser.com
661-EKZE250ETD471MJ1 and 647-UHE1A122MPD
Jul 06, 2008 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
AL178 17in. Flat Panel Problem: Screen goes black after about a second
hi,
I had the same problem before. I open my set to find out the faulty component are at power supply main board.
I change the electrlytic capacitor 680microfarad and a resistor burnt near the FET.
You can visual check first.Color changes and bulky form on cap and burnt resistor easily.
Have a try.
Apr 13, 2008 | Acer AL718 17" Flat Panel LCD Monitor
Squiggly Video on Mag LT825 17 in
On my Mag LT7825 17in, the video is all squiggly except for down the center. I don't know how to use the buttons on the front. Anyone have any solutions?
Dec 08, 2007 | Mag Innovision LT782S 17" Flat Panel LCD...
SAMSUNG SYNCMASTER 191T PLUS
I have the same problem. Have you found a solution?
Aug 24, 2007 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Envision EN9410 19" Flat Panel LCD Monitor Logo
200 people viewed this question
Top Envision Computers & Internet Experts
Cleverer2
castletech
castletech
Jim Goldsmith
Jim Goldsmith
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
