Question about HP Officejet Pro 850 InkJet Printer
Scans are too large...
We have to scan several large images into this machine... I have a problem with items being too large, unless you go through and email it from the server. We share computer in our office with 5 people, and would like to be able to scan and email from all 5 computers. Does this printer have capability to scan and email from all 5 desktops, or can it only scan and email from server.
The options on the Scanner are scan to device,scan text(too large for 20+ page docs we have)scan doc, scan picture,scan doc pdf,EMAIL doc PDF... all are too large except EMAIL option. Email option can only be used on server. Is there any way we can change size of the scans that are being complete? OR is there a way that we can access email scans(which are small enough to email) on the other network computers in our office?
    Problem Solver:
  • 18 Answers
While scanning try reducing the DPI of the scans. this will make the image smaller in size but it will effect the picture quality very little. but do keep in mind that the dpi must be atleast 70 for better picturization
Posted on Jun 28, 2010
We have a Canon Image Class MF5900. When we put items through the feeder on the top of the machine to feed through for either copying or scanning we get the copies/scans but they also have line through...
Yes, this machine has what the call a scanning glass.Its the small thin glass where the paper goes down through the doc feed.its on this glass. A real close visual or take a clean piece of paper. Wad it up a and clean glass with that paper. It works. But if you don't have a line when you print or from the platin.(glass,main).its on that reader glass.
Feb 13, 2015 | Canon Office Equipment & Supplies
Document is scanning upside down
Easiest way to confront this problem is to rotate the material being scanned.
If you find the image of the item is being inverted then simply rotate the material being scanned by 180 degrees.
Additionally most scanning software will have a ROTATE function where you can rotate the image of the scanned material, usually in 90 degree increments which can be useful for editing purposes. You may find this function under Edit or Image in your scanning software.
Good luck! William
Mar 02, 2011 | Canon DR-2050C Path-Through Scanner
My Epson Perfection 1650 Photo scanner keeps producing scans that have a 3-4 inch bright panel vertically down the middle. The image is visible, but the outer thirds are quite darker than the middle...
Make sure all the scanning settings are correct first then set everything first before you preview image then hit scan.
make sure the size is correct drag the image on the prview screen make ths dotted lines frame your image then scan
remember you tell the machine what to do by setting it, if you dont the machine trys to do thevscan its self. Good luck, have fun
Feb 08, 2011 | Epson Perfection 1650 Photo Flatbed...
How do I scan several pages to email
Create a directory called Scans on your C drive
Scan each of your images and save them as a.jpg or whatever to the Scans directory.
Open a new eamil go to the top bar and hit Attach
Navigate to the Scans directory then hold down the shift key and click on the files you want to send
Hit Attach and they will appear in the box on your email
Send an normal
You can add picture in the same way , just make sure that you place the cursor where you want each picture to show on the body of the email
Jan 25, 2010 | HP ScanJet 2400 Flatbed Scanner
How to scan slides with Visioneer 9520 USB Scanner - it scans who
I have successfully used my Visioneer 9520 to scan 35mm slides, and they came out perfect. To do this, in my image editing software, I select File/Import/Acquire/Visioneer ScanManger Pro. This opens the VIsioneer scan manager window, where I select "Scan 35mm using:" and then I choose the desired scanning configuration, e.g., "35mm Better, 35mm Best, Custom" etc. See image below.
BTW: After several moves, I have lost my 35mm scanning template. Do you know where I can get another one, or do you know someone who could actually scan theirs and email the image to me? I could then create a duplicate from heavy black construction paper or card stock.
Jul 26, 2009 | Visioneer OneTouch 9520 Flatbed Scanner
How do we set up proper ftp server connection to receive scanned images with our Toshiba 232. the current file path is \\10.0.1.5/Scans\ but when we try to scan we get a FILE STORAGE ERROR. we have entered...
the path is all \'s not /'s. 10.0.1.5 needs a shared folder named scans and the copier needs a users valid login name / password for the computer sharing the scans\ directory.
Apr 01, 2008 | Toshiba Office Equipment & Supplies
Epson 3490 does not find the slide I put in the correctly positioned provided frame
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Dec 28, 2007 | Epson Perfection 3490 PHOTO Flatbed...
35mm Color Slides
Here they are for Mac and PC
If you receive a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
Mar 15, 2007 | Epson Perfection 3170 Flatbed Scanner
HP Officejet Pro 850 InkJet Printer Logo
703 people viewed this question
Seeker5211
Seeker5211
