Question about Samsung Televison & Video
Poor picture quality on Samsung LNT405 LCD TV
I purchased a 40" LCD Samsung television about a month ago. The model according to Future Shop is LNT405. On the back of my tv it says it's model LN-T405HA (not sure if that makes a difference or not). I am using a regular motorola cable box instead of a HD box. The picture isn't very good. It almost has a snowy look to it. Any suggestions on how maximize or better my picture until I decide to upgrade to an HD box? I kept the picture at the factory setting b/c I wasn't sure what settings I should try & alter. Any suggestions???
    Top Expert:
  • Samsung Master
  • 75,767 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Posted on Apr 29, 2017
SOURCE: Picture quality and sound
than the tuning coil of circuit,like 39mhz coil or other circuite related with I.F. and detection section coil or any p.f.will be damaged if it should b currect than replace the tuner
Posted on Mar 07, 2007
  • 280 Answers
SOURCE: Best Picture Quality
The set may not be at fault. If you are on cable some channels are still in anolog and some are digital. if you are on a nolog channel the picture will look preaty bad compared to the digital ones.
Posted on Jul 03, 2008
  • 5 Answers
Check this link out. I think it should give you all the info you need for optimal picture settings.
http://help.cnet.com/samsung_LN_T4061/9602-12576_39-0.html?messageID=2510125&tag=tip-2510125&kw=samsung+LN-T4061
Posted on Jul 15, 2008
  • 14 Answers
SOURCE: sound issues Samsung series 6
The speakers that come with built into the units are very limited at best. Better than the old 4" speaker that came in TV sets from the old days, but not by much. Ask if you are not expecting more out of the output than is reasonable.
I would offer that the true design intent is to hook the HDTV into a home surround system, a home system is optimized for and designed for your listening pleasure. I'm guessing that your HDTV is an LCD with a sound bar at the bottom, if so it is for general use and not intended for critical listening.
I have a 61" Series 7 DLP and even with larger built in speakers, the difference is night and day between my surround sound system and the HDTV stand output.
john
Posted on Aug 20, 2008
  • 22 Answers
SOURCE: Red Vertical Burn Line on LCD Screen
Try changing the picture setting on the television rather than from the picture box.
Posted on Sep 09, 2008
Sinotec
check the antenna u may be getting poor reception,if the video is ok on dvd then the antenna is , if not the tv is faulty on its video output need a tech to check it
Jul 10, 2013 | Televison & Video
After about ten minutes the picture goes blank but
It sounds like the main board may have went on the TV. It should be not that costly to replace
Sep 26, 2009 | Samsung LE40R74BDX 40 in. LCD Television
Failed Samsung 40" TV
sorry to gave u a bad news bad the color card is the all panel , tell me the model # and i would check how musch is the parts
Mar 15, 2009 | Samsung HCL4715W 47" Rear Projection...
Poor Quality HD Picture
The lamp would make you picture dark.The colorwheel will affect color quality.If brightness is an issue = lamp.If color is the issue = Colorwheel.
Jan 12, 2009 | Samsung HL-S4666W Television
Samsung le40a lcd - picture quality
Hi - I have some suggestions. The following factors effect picture quality:
1. Source (because LCD TVs have much higher picture quality than traditional CRT "Tube" TVs, the worse your source material, the worse it looks on a LCD TV).
DVD and Sky/Digital TV should look excellent on this TV when connected with a good quality Scart lead (nothing too expensive, but a Oxygen Free Copper Gold lead may help) directly into one of the TV's Scart inputs (avoid using "switching" boxes for multiple equipment).
Also, bear in mind that this is a HUGE screen (40 inches I think) and will REALLY show up bad source material.
The best advice I can give is, if you have HD-ready equipment use HDMI connections for everything (ideally with an HD-uplscaling DVD player which will "improve" the quality of standard DVDs on the TV - I recommend models by Philips) and check that you are in "Movie" or "Cinema" mode on the TV.
Make sure that all of your equipment, like your Sky digibox, is set to 16:9 mode (not 4:3) aswell to preserve the true widescreen aspect ratio.
Hope that helps!
Dec 31, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Picture quality
i have a similar problem, when watching football the picture is terrible,but when im watchin ordinary tv its great
Dec 28, 2007 | Samsung LN-R409D 40 in. LCD Television
Nov 13, 2007 | Samsung LN-T4061F 40 in. LCD HDTV
Samsung lcd tv le32r8 (Picture - Movie setting)
The TV is probably in Shop mode, when your TV is initially turned on you can choose between Shop mode or Home Mode.
In Shop mode the TV automaticly returns to the standard setting after a while, they do this so customers can "play" with it.
Press down de Volume button and then hold down the Menu button for five seconds on the side panel of the tv.
Oct 25, 2007 | Samsung LN-R409D 40 in. LCD Television
Televison & Video Logo
252 people viewed this question
Jerry Greenberg
Jerry Greenberg
