Question about McCulloch Garden
Chain not getting oil
I have a old McCulloch 3516. The chain saw that is not getting oil. Is this a difficult repair? I can borrow my son's Husqvarna 141 but I prefer the McCulloch over the Pouland product.
    President:
  • 2,220 Answers
Extremely difficult! If the oil pump or worm gear is defective it may be the most difficult saw to repair. This is the only saw I have seen with the oiler mounted behind the fly wheel.
Your basic model number is 600035. There are 11-, 21-, and 22- prefixes used with 600035s. There are also a ton of suffixes with the 600035s. I think the suffix is on your saw immediately after the basic model number somewhere (usually on bottom of older Macs along with the serial number. The dash of the serial on older Macs is the prefix). I must defer to you to find your exact IPL, here:
McCulloch IPLs
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
I chose this one as an example "22-600035-58" for an IPL
http://www.ordertree.com/modelinfo/MCC/22-600035-58-Mac-3516-IPL-211229-01/139.22-600035-58-Mac-3516-IPL-211229-01.1.59.1.html
The "Powerhead Assembly" lists an oil pump (1) and a worm gear (10). These are the most common failure on most saws but Macs have many more hoses than most. There are oiler components on at least 2 different details. It appears the oil pump is on the starter side of the engine. and you may need to remove the fly wheel for access. I would examine every connection and perhaps try the "Kit Gear/Plunger Assembly" before trying to access the oil pump and gear.
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear. Please see the IPL to aid in oiler component identification.
You can reply below with any questions. I hope you found this most helpful. Good Luck
Lou
If you opt to remove the fly wheel PLEASE reply to me first. I can probably save you a couple of headaches and may prevent component breakage.
Posted on Feb 01, 2010
How do you get to the oil filter and how do you clean it and change it.
How to clean the chainsaw's air filter - YouTube
? 3:11
https://www.youtube.com/watch?v=wozSufvtbfE
May 30, 2012 - Uploaded by iScaper1
Tips for removing and cleaning the air filter on a Stihl MS250chainsaw. ... A very dirty air cleaner, a little maintenance can help them live longer ... Poulan Chainsaw Review- Should youbuy one? ... chainsawbars.co.uk - cleaning the air filter andchanging spark plug ... Get video URL at current time.
Mac 3200 chainsaw oil tank repair - YouTube
? 3:21
https://www.youtube.com/watch?v=XXlm-o8sD6A
Jul 17, 2012 - Uploaded by conan6868
Repairing oil tank. ... Could You Fix This Mini Mac Chain Saw! ...The chainsaw guy takes the McCulloch Mini Mac ChainsawChallenge 9 23.
Mucculloch 3516 chain saw assembly - YouTube? 49:25https://www.youtube.com/watch?v=Xm4YL3pDG8cJan 20, 2014 - Uploaded by Dragracer64In this video I take a box of dirty chain saw parts that has been sitting in my attic for about 12 ... Is there supposed to be a filteron the line in the chain oil tank? .... How to replace MCCULLOCH chainsaw MAC 3516 fuel line.How to replace MCCULLOCH chainsaw MAC 3516 fuel line ...? 1:32https://www.youtube.com/watch?v=GMjXYKza-NYJan 13, 2013 - Uploaded by Lambda ITCMCCULLOCH chain saw MAC 3516 chainsaw fuel line replacement. Three fuel lines. 1) First line in the tank ...
Dec 27, 2015 | McCulloch Garden
Need to know carb mixture
fuel mixture for 2 stroke' s is 20:1
100ml of oil in 5L of fuel
Mar 13, 2015 | Oregon McCulloch 12" Chain Saw Repl. Chain...
What is the oil/gas ratio for a McColloch "Titan
40:1 is the ratio for modern saws so I expect it's the same for the older ones. Use good 2 stroke oil like Husqvarna or Stihl brands rather than the cheaper stuff you can buy at car service stations which don't really protect a saw.
Jan 05, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
No problem; using a borrowed Husqvarna 44-don't know fuel mixtures (if any). The chamber for "oil"-is that engine oil (if so, what do you recommend) or chain saw oil (if not, is there another...
The mix fuel mix is 40:1. Use Husqvarna 2 stroke oil not the cheap stuff on sale at car service stations. The chamber for oil is for chain oil which can be bought at most places that sell or hire machinery like chainsaws, lawnmowers etc.
Nov 14, 2010 | Husqvarna 44" Chainsaw Bar Fits Jonsered...
I need the gas/oil ratio for an old Pro-mac 10-10S
40:1 according to Mike Acres site, same as current recommended mix:
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/8f167f396637c29d88256c2e0073560e?OpenDocument
Oil Mix Ratio:
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch & Poulan; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
McCulloch Manuals
Operators Manuals: are much more difficult. I have dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it! If unsuccessful with McCulloch try here:
Beg for manuals thread (ArboristSite - free to join). Please use the search function first, it has probably been asked and answered.
http://www.arboristsite.com/showthread.php?t=72322
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 26, 2010 | McCulloch Garden
Need to view gas line hook up. On mac3515 chainsaw
No 3515(35cc,15"bar)s a 3516 is provided.
A McCulloch Mac 3516 model model 21-600035-59. (may not be your saw):
http://www.ordertree.com/modelinfo/MCC/21-600035-59-Mac-3516-IPL-211318-01/139.21-600035-59-Mac-3516-IPL-211318-01.1.59.1.html
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
If the above is not your saw, yours can be located here:
McCulloch IPLs
A typical fuel system and a couple of tips follow:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If properly plumbed your saw will run with the carburetor to primer hose capped off.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 14, 2010 | McCulloch 10" Electric Pole / Chain Saw
I have a MAC 3516 and need a replacement bar and chain. The original Chain and bar are not available. the saw runs good but need the primer bulb and chain bar and chain. Any ideas would be great.
Hello Eric, You can get an Oregon brand bar and chain that will work perfectly on your Mac 3516. I have this same chainsaw and keep a spare bar and chain, so I can quickly swap them out, should they get damaged, etc.
The Oregon bar and chain part numbers are as follows:
#100457 (Bar & chain combo pack)
You can also find these sold at most Home Depot, Lowe's and other hardware stores that carry chainsaws, as Oregon makes their replacement bar and chains to fit all the major brands available.
Unless your existing bar and chain are completely galled up, scored or bent/busted beyond repair, I would find a small engine repair shop or local hardware store that sharpens chainsaw cutting chains, (True Value and Ace do it in our area) and see if they can sharpen and true up the bar. The price for this is typically about 1/3 to 1/2 the price of a new chain and bar set, and worth having a spare around.
I also like having that extra aleady to use (sharp) chain, so when a neighbor borrows my saw and invariably lets the chainsaw go into the dirt (that'll dull the chain so fast!). I will always be able to use my saw, when I need to, without having to run out and get a replacement, or spend 15 minutes having to sharpen it by hand, etc.
I hope you find this Very Helpful and best regards!
Nov 24, 2009 | McCulloch Garden
Garden Logo
446 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
