Question about Kenwood KAC-529S Car Audio Amplifier
My kenwood amp doesn't light up, fuse is good
My kenwood amp KAC-529 S doesn't light up, fuse, power, and connections is good- why?
  • Stephen Sedwick May 11, 2010
    is your remote wire hooked up tha right way?
    Problem Solver:
  • 31 Answers
Your amplifier has a power supply problem,contact Eric @ Capital Audio & Electronics Repair 850-339-1130 email poppa1puff@aol.com
Posted on Mar 21, 2010
The red light on my kenwood stereo amp KAC-628 will not turn on. I was wondering which wire is causing this to happen?
the power wire or the remote wire check ur fuse in ur power wire if thats good check your connection to the battery if thats all good its ur remote wire located in the back of ur head unit
Mar 16, 2010 | Kenwood KAC-628 Car Audio Amplifier
When I hook up my kenwood kac-7201 the power light
leave power connections hooked up disconnect rca and speaker wires if they still blow more than likely problem with amp
Dec 31, 2009 | Kenwood KAC-7201 Car Audio Amplifier
Amp lights up, but no power to outputs.
channels mey be burned....does the amp smell like burnt electronics
Nov 07, 2009 | Kenwood KAC-8104D Car Audio Amplifier
Does an mp3 player put out enough power for input to KAC-624 amp?
Have you connected the rca plugs to the radio or amp directly? If you've connected it to the radio make sure that the input level controls are adjusted AND available on that model (it will say AUX, INPUT, SUBWOOFER, REAR, etc.) Connecting your mp3 player directly to the amp will not have enough juice to hear sound you need to connect it to the radio first.
Oct 02, 2009 | Kenwood Car Audio & Video
Power amp wont power up
Check the fuses-should be a pair of 30 amps on the side. use a paper clip and jump power from the power+ to the remote+ and see if that lights it up-if it does than your remote lead isnt giving it juice-
Apr 06, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Amp light is on but no power to my subs!
Hi There.
When you say the 40 Amp fuse blew. Was it your mains battery fuse or was it the fuse on the amplifier? If it was the fuse on the amplifier then you may have hurt the amplifier. The Kenwood KAC-8101D is a 1000 Watt monoblock amplifier. Therefore if you say that 1 of your woofers is not playing, then it is almost certainly blown if you are sure it is connected correctly. Try disconnecting it and only running the woofer that tries to play. If this woofer is still working correctly, you will notice a drastic drop if the sound of your bass. The reason for this is because you have changed the impedance load on your amplifier due to the fact that the other woofer is not working. Have your working woofer checked and replace the faulty woofer then you should be banging again.
Hope this helps!!
Jan 30, 2008 | Kenwood KAC-8101D Car Audio Amplifier
Amp not powering up correctly.
check transistor of the unit 1 or 2 tans. bad use a tester. the unit is overload protected. replace the deffecteve parts
Sep 17, 2007 | Kenwood KAC-8401 Car Audio Amplifier
Kenwood KAC-6202 power
check all of your connections . Make sure you have a good solid ground
Apr 20, 2007 | Kenwood KAC-6202 Car Audio Amplifier
Kenwood KAC-529S Car Audio Amplifier Logo
357 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
