Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Does each brake light have a sperate fuse on my
Does each brake light have a seprate fuse on my bmw318is? left light will not work new bulb already tried could it be a fuse? dash electrics acting screwy too
  • 509 Answers
What year is it if it is around a 90- 97 model sometimes the wiring harness located at the drivers side trunk hinge is a bundle of wires that is in a closed rubber housing disconnect the battery then pull this plug from the trunk and cut open and inspect the wires in the tube some times they break from all the bending from the trunk open and closures
Posted on Feb 12, 2010
Fuse box and fuse number for Mondeo edge 1.8 125 6g for left taillight already tryed bulbs that's only thing left to try
maybe you have a single filament brake light bulb instead of a double element bulb.
F93 - 10A - Headlights, Brake lights, Heater Blower Relay
Dec 18, 2015 | Vehicle Parts & Accessories
Driver side brake light is not working. Replaced bulb, but didn't need to it is the same bulb that works the tail lights, which still worked. Ugh, 2006 jeep liberty. Someone said it was a brake...
THAT RIGHT IF BRAKE SWITCH BAD NO BRAKE LIGHT WILL WORK.SPRAY ELECTRICAL CLEANER IN BULB SOCKET BULB SOCKET COULD HAVE OXIDATION AND CORROSSION CAUSING POOR CONTACT.
Sep 12, 2011 | 2006 Jeep Liberty
2007 dodge caliber brake lights dont work, bulbs are good, hatch back brake light works any ideas what this could be. derek
Check the connections on the "body harness" that is located near the hinge for the decklid.this harness,if i remember correctly,is on the driver-side of the car.Also check to make that no wire has any "bare spots"that are grounding to any metal.
Feb 12, 2011 | Dodge Caliber Cars & Trucks
1999 GMC Envoy: replaced both GE 3057 lamps in left rear light assembly. Lamps both light. However depressing brake pedal does not initiate brake light. The righ rear brake light does work. The high mount...
The high mount brake light has its own fuse, so check that first. The high mount bulb is generally a stabdard type (there may be more than one bulb) or you can replace with an LED. As for the left rear bulbs not working when depressing brake pedal, check the bulbs again for any spring that may be broken. If the bulbs are still good, make sure there is sufficient contact with the socket. If still not working, have someone check it out further.
Feb 15, 2010 | 1999 GMC Jimmy
My brake, hazard and turn lights dont work, i
well u have two seprate problems the hazards and turn signals have a flasher that needs replacing if the fuse is good on the fuse box marked signals .and there is a brake light switch under the dash board near the brake pedal it has two wires on it check the wires make sure they are connected if so replace the brake light switch
Nov 13, 2009 | 2002 Chevrolet Astro
Tail lights will not come on
check fuses my 1997 mitsubishi mirage had same problem and there were two seprate fuses under the hood. also you can google the locations to all fuses
Mar 04, 2009 | 1997 Mitsubishi Eclipse
Left rear brake light stopped working but bulb and fuses are OK.
These are Dual Function Bulbs. They control the Parking Lights and the Brake Lights. This Bulb is Burnt out on the Brake Coil inside the Bulb. I have actually seen Bulbs that were Bad But you could not Tell by jast looking at them. It should be fine with a New Bulb. Please Rate My Response! Thanks!
Feb 05, 2009 | 1999 Ford Expedition
Left and right brake light doesn't work but center lights does
check behind the brake peadle for a little button that pushes in and out when the peadle is pressed(this is your brake light switch) some cars have more than one of theese. manualy let the button out if the light works the switch is good if it does not disconect the harness from the switch and take a small piece of wire and jump the two prongs on the harness if the brake lights come on then you need a brake light switch. if this doesnt work check for power at the switch. if no power you have a bad fuse if there is power and you already jumped the wires to the switch then you have a broken wire between the switch and the tail lights.
Dec 25, 2008 | 2001 Oldsmobile Alero
98 gmc suburban brake lights
One of two things cause this corroded or poor chassis earth at the bulb holders or the circuit board that holds the bulb is faulty.
Nov 19, 2008 | 1997 GMC Suburban
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
