Question about ViewSonic VX2255wmh LCD Monitor
Viewsonic VX2255wm - worked this morning - dead this afternoon?
I have a viewsonic VX2255wm. The monitor worked fine this morning. I walked away to have lunch came back an hour later after lunch and it was dead - no picture. I completely disconnected the monitor and just tried to get some response from a power up / power down sequence. The Blue power indicator light comes off and on buit nothing on the screen. Is it time for a new monitor?
  • 11,361 Answers
More likely to have problem in the power supply section, you need to open it up and look for bad caps first, post back so we can guide you further, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Posted on Feb 01, 2010
  • 644 Answers
The problem you have sounds like the inverter board has failed it can be repaired by replacing the inverter board which may be a cheaper option than buying a whole new monitor, you can do a search online for lcd repairs and spares to find the part you looking just state your make and model and price one up.
But before you do do that, and you feel confident that you could take the back cover off the monitor, you could have a look for blown capacitors, they are quite a comman fault in lcd monitors, once the back cover is off check the power supply board, it will be where the power cord plugs into the monitor, The capaciters are barrel like in shape with silver tops, check for any leakage from them or on the board surrounding the capacitors, also make sure they are fully flat at the top, if they are slightly domed or pretruded they will need to changed. post back your findings if you do find any bad caps ill will try to explain how to get the right ones and what do to. cheers.
My Viewsonic vx922 was working fine until this morning. The computer had a problem and I restored it to the original factory settings. I had to download the drivers for my Radeon card to allow me to do 2...
Looking like there is an issue with the powerboard on the monitor. This problem you are having appears to be common with this monitor, with a lot of them failing for no apparent reason
Jan 05, 2011 | ViewSonic VX922 19" Monitor Flat Panel
VS10162 back screen
The reason I ask you to hook up the viewsonic directly to the PC is to find out if the problem is in the USB adapter or in the monitor itself, you can also try your Viewsonic with other computer.
Basically just have the PC, VIEWSONIC, NO USB or the monitor. We need to narrow down the problem.
May 12, 2010 | ViewSonic VX922 19" Monitor Flat Panel
ViewSonic VA912 half screen dead after 30 minutes
first i confirmed that the problem was in lcd.then i predicted that some display chip on the motherboard are getting heat.due to which the display was performing irregular then i switch on A/C of my room.and the temperature was cool. and the monitor was working fine.
Apr 29, 2009 | IBM E54 (Pearl, White) 15 in.CRT...
DVI connection fault
I had the same problem, you must call Viewsonic to change your screen. The DVI input on the screen is dead.
Jul 08, 2008 | ViewSonic VX2255 Monitor
No power to monitor despite being plugged in
Check your video card. Is your computer booting up?
May 25, 2008 | ViewSonic VX910 19" LCD Monitor
My monitor stopped working
You need to be more specific .Post make, model, how old it is and exact problem.Is the monitor completely dead No lights power etc??
Feb 16, 2008 | ViewSonic VE175b 17" LCD Monitor
A line of Dead Pixels.
You are right it is a stuck or dead pixel, usually if it is a colred line but not grey it is a stuck pixel at the beginning of the line you can try a utility designed to flash bright colors repetedly over time to see if this will "unstick" it. Also you could have a dry joint on your TCP which would require opening it up to diagnose.
Feb 11, 2008 | ViewSonic VA1912wb Monitor
ViewSonic VX2255wmh  LCD Monitor Logo
208 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
