Question about Acer XD1150 DLP Projector
Projector stopped working completely
I've only used my projector 10 times. I went to turn it on for a lecture, and the light came on for about 5 minutes, then went out, along with the fan. Nothing works!!! What can I check?
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 02, 2010
Why would my projector refuse to start with a seemingly intact light bulb?
If you only have 300 hours on it it should still be under warranty. Before doing something to void that I would check with Optoma techs.
Jul 23, 2014 | Optoma HD20 DLP Projector
Infocus IN10 projector, when I turn it on the light blinks green for a while (with no picture) and then it shuts off and blinks red (more than 5 blinks)
if Lamp or projector shuts off after running a short period of time, This is usually a thermal issue caused by excessively
high internal temperature. The high temperature
could cause a component on the controller ECA or
the power supply to fail when it gets hot.
First you need to check the fan operation, Are 3 fans, two for lamp and one for the color wheel. Check the elevation foot, if something is broke maybe something stop the fan.
Remove the lamp module.
Examine the fan assembly through the recess in the bottom case. Plug the projector in and turn it
on. Both fans in the fan assembly should start up and run for 5 - 10 seconds, then shut down
(because there is no lamp installed). This is time enough to make sure the fans work properly.
Make the same for the color wheel fan, you need to remove the top case.
Oct 15, 2013 | InFocus Work Big IN10 DLP Projector
NEC vt800 projector troubleshooting
That is a problem with the lamp. Replace it with a known good one.
Feb 27, 2013 | NEC VT800 LCD Projector
Keeps going to double red light shuts down, then it resets and turns on for 5 minutes and then turns off again, what could be the issue? thanks
I've seen this happen almost exactly on a Canon projector. The problem was the bulb. After the bulb was replaced the problem went away.
Please remember to rate this solution to show your appreciation!
Jun 01, 2011 | Epson PowerLite 7900P Multimedia Projector
Light of projector is not working
Try to turn off your projector and open it again after 10 minutes. The lamp may be malfunctioning due to overheat. This usually happens when your projector was not turned off properly. The fans inside the projector should slowly cool the lamp inside when turning it off properly causing the projector to be in a standby mode for a couple of minutes before you can completely unplug it.
Mar 07, 2011 | Optoma EX536 DLP Projector
I replaces my bulb in the sony vpl-hs10 and it still will not turn on after I reset it what do I do now? the lamp light is still lite it turns on but the lamp does not project anything
These instructions are for a Sony Cineza VPL HS3, but may be the same for the HS3.
1st thing to check - is the cover properly/completely closed - this can stop the projector from working.
Connect the power and set the projector to standby mode.
Press these buttons on the remote control in this order, for less than 5 seconds each.
Reset - Left Arrow - Right Arrow - Enter
This is required, to reset the lamp timer.
Also, something I found interesting from the internet - lamp life isn't when the bulb dies, but when a bulb has lost 10% of its brightness - so you might well be able to reset the timer and get much more use from the bulb - the image just wont be as bright.
Nov 19, 2009 | Sony Cineza VPL HS2 Multimedia Projector
Flashing green light
1. Pls check and inspect the Lamp unit.
2. If Lamp unit is okay, Then the Problem is with
either with Ballast unit or the DMD Module.
Regards
Viren
May 31, 2008 | Sharp XR-10X Multimedia Projector
Video then Black
the colorwheel is going bad and needs replacing.
Jul 27, 2007 | Dwin TransVision 3 Plus Multimedia...
XG-C50 Problem
Hello
Replace the fly-eye lens of projector.
Viren
Nov 09, 2006 | Sharp (BQCXGC50X1) Projector Lamp for...
Acer XD1150 DLP Projector Logo
147 people viewed this question
Top Acer Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
