Question about Sony M529V Single Dual Cassette Deck
Worn belt on Sony M-529V. Where to purchase a new one?
  • 336 Answers
You can get generic belts at www.mcmelectronics.com
Posted on Feb 02, 2010
Belt slipping off although tight-burning smell cut hole in access cover
Patricia,
It could be a couple of things that need looking at. You might need a new brush roller or a new motor housing. It sounds like something is allowing the belt to "ride" off of the pulley and it could be that the pulley is worn, or the housing that the brush is mounted in is now worn and the brush sits at an angle instead of being straight across. Take your belt off and wiggle the brush while looking at the brush mount. If the bearing wobbles in the mount area, you need a new housing. Depending on when you purchased this vacuum, there might be a possibility that it might be under warranty. Hope this helps!
Jan 30, 2016 | Oreck XL2200 Bagged Upright Vacuum
The rubber belts on my sony cassette deck(TC-W380) are worn out and i need replacements.Does anyone know where i can purchase them?
Ive used o-rings from home depot with no issues before....I did a little research and the part numbers match to
http://www.ebay.com/itm/SONY-TC-WR665-WR670-WR690-WR701ES-Double-Cassette-Belt-Kit-GTD-5-YEARS-/140828351357?pt=US_Home_Audio_Cassette_Decks&hash=item20ca061b7d
I would investigate on your own to make sure, but the parts cross referenced
Aug 20, 2012 | Sony Dual-Deck Cassette Player/Recorder...
I have a Sony PS-LX250H that was put into storage and moved twice while I was in transit between residences. Since I got to my new place I haven't been able to get it to work at all even after rep
hi
check the belt it might be loose...
elasticity of the belt is ... no more :(
try turning the plate by your hand and see what happens
Good Luck
May 09, 2017 | Sony PS-LX250H Turntable
Does my Honda CR_V Executive 2002 have a timing belt or chain & when should it be changed
It has a timing Belt and it should be changed not later than 70.000 km. If you are the original owner then you know the actual maint. on the vehicle. If you purchased it 2nd hand depending upon where you purchased it... there could be a new belt installed. An old belt will be dirty in the ribbed tooth area and the outside of the belt will show wear on the belt part number label. A new belt the tooth area will be clean and the outside of the belt will be almost glossy while the belt number label will not be worn.
Thanks for choosing FixYa,
Kelly
Sep 09, 2011 | 2003 Honda CR-V
I would like to locate belts for m-529v cassettee-corder
Hi, we can supply belts for your Sony. Styluscity@gmail.com
Sep 13, 2010 | Sony M529V Single Dual Cassette Deck
Readmill suddenly stops
This machine has what they call a thermal switch. It is designed to
shut the machine off if it gets too hot. This heat is caused by
friction. Friction is caused 99% of the time by the walking belt or
the drive belt. If it is the drive belt then it can be solved by
either applying a treadmill lubricant (must be made for treadmill
belts) or by purchasing a new belt. If you feel the underneath side
of the belt and you feel a screen door type feeling you just need
lubricant. If you feel a smooth surface you will probably need a
new belt. If you have lubricated in the past year and your belt has
the screen door feel then take off the motor hood cover and check
the drive belt. If it is worn then you will need to replace that.
You can purchase either of these products from the manufacturer, at www.iconservice.com. a couple of other places that may have them for discounts are www.ebay.com, www.fitnessrepairparts.com, or www.treadmilldoctors.com.
Aug 06, 2010 | Reebok Rt1000 Treadmill Walking Belt
Why is my vhs tape immediately ejected from my Sony DVD/VHS machine, tapes will not stay in long enough to record or playback.
mechanical problem usually in rubber belt types it has to replace new belts for it was already worn...
Dec 31, 2009 | Sony RDR-VX521 DVD Recorder/VCR
Traction Belt (new) continues to slip off of drive plate.
Sounds like you may need to replace the pulley as well. It has likely worn out of specification.
I recommend that you contact your nearest authorized service center, or contact Toro directly for assistance.
I trust this information proves useful.
Oct 02, 2009 | Agri-Fab Agri - Fab Snow Blower - 42"
Sony PMC-DR50 Shelf System - need help installing new belts
look at the front side of a motor,you will see two screws,remove it,and that's it,change your belt.
Jan 21, 2007 | Sony PMC-DR50 Shelf System
148 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
