Question about Acer Aspire 3000 Notebook
Wireless connection Hi, I am trying to conect to a WAP and it is not showing the point. please advise
    Genius:
  • 3,587 Answers
Check to see if mechanical wireless switch is on first..then go to network connections in control panel, and make sure it's enabled..
try that
got backup for that Acer?
Posted on Feb 19, 2008
I cannot connect to the WIFI at work, but I can connect to my WIFI network at home, and other public networks. The wireless network at work is pushed by a D-Link 8200AP with a WAP security, just like it is...
Your laptop cannot connect to your work's wireless network because the security settings (ir WAP) in the D-Link is different to the security setting in your Netgear.
The wireless card in your laptop will need the settings changed to suit the D-Link's wireless settings ie the SSID and WAP.
You will need to change the wireless card settings in your laptop back to the Netgear's wireless settings to connect to your wireless network at home.
Some wireless cards allow you to set up different profiles for different wireless networks which allow you to switch wireless networks easily by just selecting the profile for the network you want to connect to.
Jun 25, 2011 | Apple iBook G3 Mac Notebook
Hi Support team, I use Modem Motorola SB100 with Linksys WAP54G, and DLink Wireless G DWA USB Adapter to connect to Linksys WAP from my PCDesktop. Connection from the PC to Linksys is ok but can't...
peter_picasa:
You cannot use a Wireless Access Point (WAP) to connect directly to your IPS's modem. A WAP does not provide the ability to share a single IP address on the internet like a router does.
Either return the WAP for a refund and buy a wireless router or buy an Ethernet wired-only router and plug the WAP into the LAN side of that router. You would then plug the WAN side of the Ethernet wired router into your modem.
Thanks for using FixYa.
Feb 20, 2011 | Linksys Wireless-G WRT54G Router
Access point appears to have stopped working I cannot connect to wireless network but can connect with wired connection.
Hi!
If you can connect before then suddenly it stopped working, let's try to isolate the problem first. Usually this problem occurs if the the wireless has been interfered by some sort of interference like cordless phones and something like that. To address this problem, you can give it a try changing the channel of the access point. To do this, follow the step below.
> Connect your WAP directly to your router
>Open your Internet Explorer and type http://192.168.1.245
>It will prompt you to enter username and password. No username and password is admin
>When you get to the setup page, click on Wireless Tab and change the channel to either 1, 6 or 11. These are the strongest channel. Default is 6 so you may try channel 11 or 1 then click on Save Settings at the bottom.
>Now do a power cycle for 30 seconds then try to reconnect using your laptop
If that solution doesn't work, this time you can give it a try reseting your WAP to factory settings then reconfigure. To reset it, follow the steps below
1. Using a paper clip or a pen, hold the reset button located at the back of your WAP for 30 seconds then release it.
2. Unplug the power for another 30 seconds then plug it back in. Try to reconnect to your wireless network using your laptop
3. You can use the CD that came with it to reconfigure it.
If everything else fail, I'll suggest you to get in touch with Linksys support by calling 800-3267114 if you are in US or Canada.
Best Regards!
Feb 17, 2011 | Linksys Wireless-G WAP54G 802.11g/b...
Hi I have recently purchased the belkin wireless surf router and I am not sure if it is working correctly or not, as the light on the front of the router is currently blinking red.. and red doesnt really...
hi
IS THE LIGHT IS BLINK RED MEANS YOU DONT HAVE A PHYSICAL CONNECTIVITY.
PLEASE CHECK YOUR MANUAL AND YOUR CABLE CONECTIONS.
STEP1
TURN OFF ROTER AND MODEM
STEP2
CONNECT MODEM CABLE TO WAP PORT ON ROUTER AND LAN CABLE TO PC OR LAPTOP
STEP3
NOW TURN ON FIRST MODEM AND AFTER A 5 MINUTS TURN ON ROUTER, YOU WILL SEE LIGHT IS TURNING ORANGE AND AFTER THAT GREEN
READY NOW JUST ENJOY YOUR ROUTER.
ADVISE:
DONT INSTALL THE CD SOFTWARE DO ALL MANUALLY.
FOR GO IN TO YOUR ROUTER SETTINGS PLEASE LOG IN IN THE INTERFACE USING 192.168.2.1 OR JUST WRITE HTTP:// ROUTER
ANY QUESTIONS PLEASE TX ME .
TECHBELKIN
Jan 25, 2011 | Belkin Wireless Surf Router (F7D2301)
Cingular WAP settings
Hi..i am providing you with the WAP and other settings,but still if you need any help,then please contact Cingular at 866.CINGULAR(866-246-4852)
For CSD (Wireless Internet)
Function Setting
Settings Name: Cingular Wireless Internet
Home Page: http://device:home or http://device.home
Session Mode: Permanent
Connection Security: On
Dial-up Number: 14152441012
Gateway IP Address: 66.209.11.61
Authentication Type: Secure
Dial Type: ISDN (on network)
Analogue (off network)
Login Type: Automatic
User Name: WAP@CINGULAR.COM
(All upper case)
Password: CINGULAR1
(All upper case)
For GPRS (Wireless Internet Express)
Function Setting
Settings Name: Cingular Wireless Internet Express
APN: wap.cingular (lower case)
PDP_Type: IP
User Name: WAP@CINGULARGPRS.COM
(All upper case)
Password: CINGULAR1
(All upper case)
Now to set up MMS (Multimedia Services)
Homepage: http://mmsc.cingular.com
Gateway IP 1: 66.209.11.61
Port 1: 9201
Domain 1: (blank)
Service type 1: WAP
Gateway IP 2: (leave alone)
Port 2: 9201
Domain 2: (blank)
Service type 2: WAP
DNS 1: (leave alone)
DNS 2: (leave alone)
Timeout: 10 minutes
CSD No.1 14152441012
Username 1: WAP@CINGULAR.COM
password: CINGULAR1
Speed(bps): 9600
Line type 1: ISDN
CSD No.2: (blank)
User Name 2: (blank)
Password 2: (blank)
Speed(bps)2: 9600
Line type 2: ISDN
GPRS APN: wap@cingular
Username: WAP@CINGULARGPRS.COM
Password: CINGULAR1
Good luck :-)
Apr 22, 2010 | Computers & Internet
Cannot connect my WAP-0005 Access point to my router
Use AP mode ; but may really have some compatiblity issues though... Good Luck*
Mar 11, 2010 | Levelone WAP-0005 (DHWAP0005) 802.11b/g...
Psp internet connection
common is there anything you can do to fix it
Jul 28, 2008 | Sony PlayStation Portable (PSP) Console
WAP54G bricked power led blinking LAN connection shows as not connected
you did not specify where the wap is connected when you pinged it. Try this, connect the wap54g to your pc. Assign static ip 192.168.1.5 on the lan of the pc, then ping 192.168.1.245. if you can ping you should be able to access the configuration page. if the power is still blinking you can upgrade the firmware
Mar 10, 2008 | Linksys Wireless-G WAP54G 802.11g/b...
Connection to WAP
disconnect .
open internet browser
type the gateway and press enter
Nov 13, 2007 | Linksys Wireless-G WAP54G 802.11g/b...
Acer Aspire 3000 Notebook Logo
99 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
