Question about HP Pavilion F1523 15" LCD Monitor
Hi,my hp pavillion f1523 is blank, because i lift on overnight, when i came out in the morning i find out is blank and i have try to test it with another computer, but notting works
  • 1 more comment
  • longynwosu Feb 01, 2010
    this is what happen, i was on net when an update come on screen then i lift to update, because the update was slow that's why i lift it overnight. then when i came out in the morning the screen was blank,.yes the power comes on.
  • longynwosu Feb 02, 2010
    i take it to afriend and he plug it his computer and comes on, then itake back to my computer and comes on as well but show a message to reset to factery setting and i was about reading the message and it went off again,but now my problem now is i don't know what can i it can press on the keyboard so that it can show some thing on the screen.thanks
  • jimnuggats May 11, 2010
    does it power on at all? do you have any lights on the front when you power it up?
  • 11,361 Answers
Look for bad caps in the power supply first then post back what you see inside so we van guide you furhter, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Posted on Feb 01, 2010
  • 644 Answers
Its the power board that seems to be at fault, First you will have to open the back of the monitor, there should be a few screws holding together, have a route around and find all the screws and undo them, gently prise the back off. Once off check the board where the power lead normally plugs into the monitor, your looking for cylindrical shaped componants with silver tops called capacitors,they are quite a comman fault issue of lcd monitors, First check to see if there are any brownish colour liquid resadues on the capacitors and the surrounding area, if there is the capcitor will need to be replaced, also check for domed or slightly pretruding tops they are ment to be completly flat, if there are any they will need to changed also.
Changing the capacitors require some soldering skills to desolder them from the board and resolder in the new ones, you will have to take the board out of the set in order to do this, there should be a couple of screws holding the board in place, these will have to undone, and the board removed from the metal housing.
Before changing them make a note a the value of the capacitors it should be written on the side of them, also make a note of which way around on the board they are positioned, if you get that wrong they will blow again. hope this helps post back if you need further assistance.cheers.
Posted on Feb 02, 2010
  • jimnuggats Feb 03, 2010
    There should be a few buttons on the front of the monitor, press them until you get a menu up, there should be somewhere on the menu that restore factory default, goto that one and press one of the + buttons to restore it, there may be a sleep button on your keyboard, have a look around, if there is try pressing it, it may wake the monitor up. post back if you more difficulties. cheers.
Wf 7010. When I run a print check (nozzle check), it runs like it is doing it and the paper comes out blank.
try doing 3 head cleans without printing anything. leave the printer overnight to soak the print head in the purged ink. in the morning do another head clean then try a test print.
Feb 03, 2014 | Epson America EPSON WorkForce WF-7010...
Ato x600 hp pavillion won't boot
You could try disabling the on board video in BIOS.
Feb 04, 2013 | HP Pavilion Computers & Internet
Hp pavillion f1904. powers up then blanks out
g_w_taylor, Try here first!! http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Its an old blog but just do some reading and see if something fits!! Then come back here and do a reply/comment to this response and rate it on FIXYA for others may see the light. 12fixlouie
Jul 19, 2010 | HP Computers & Internet
I have pavillion dv8000 monitor problem
What is the problem with your pavilion dv8000 monitor? i would appreciate if you can give more information on the problem with your device.
Take care.
Jun 26, 2010 | HP Pavilion F1523 15" LCD Monitor
Monitor green light comes on then it says no imput
looks like there is problem with ur signal cable check that monitor signal cable is tightly fixed or contact ur product support center.
Mar 31, 2010 | HP Pavilion F1523 15" LCD Monitor
No back light on te Pavillion F1523
I have heard a lot in my years but never Condo not even from my Grandfather who was born in 1901, however back you your question, I have not seen Diagrams for the monitors those of us who are repairing these simply make note where the caps are that need to be replaced and then desolder them and install new caps at the same value as listed on the side of the cap we removed usually you don't need to do more than 6, most times its 1, I find and all is well again. I have never had an inverter fail it has always been the power board that has issues.
Mar 21, 2009 | HP Pavilion F1523 15" LCD Monitor
Hp pavilion f1523 lcd monitor
You are not alone with this problem. Some lines (like mine) run vertically rather than horizontally. The solution - sue HP. These screens have a known fault ie the Nvidia graphics chip is known to be the culprit. The company knows all about this issue but expect us to pay to put it right - sue them, you can do it online for around £35 (UK).
Oct 02, 2008 | HP Pavilion zd8000 Notebook
Hp monitor power cord
I purchased a HP Pavillion Slimline computer that was accompanied by and HP flat screen monitor: HPw1858. My problem is that the power cord is missing. Can you help me locate somewhere I can purchase this cord?
Oct 26, 2007 | HP Pavilion F1523 15" LCD Monitor
HP Pavilion F1523 15" LCD Monitor Logo
214 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
