Question about Miele Novotronic W1918A Front Load Washer
No power from my Miele W 1926 are their fuses to replace to restore power to open the door?
2 Suggested Answers
  • 6277 Answers
SOURCE: my miele metronic w 1926 has red light flashing on
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 20, 2011
I have a Miele CVA4070 Coffee System that won't power on. Can you tell me where the fuse is located for this machine?
there is a main power swich on the wall of the machine right over the ground coffee storage bin in the upper left corner of the machine. you have to open the stainless door, and look way up in the back left corner. tiny little rocker switch. try that, and then the touch panel should be on.
May 10, 2011 | Miele CVA4070 Coffee Maker
Miele Dryer Problem
HI,
If your dryer doesn't work at all, it could be because of problems with:
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Aug 06, 2008 | Dryers
Can't open oven door
Hi 1926,
I think you will have to go to your Circuit Breaker panel and turn the power supply to the oven off then back on after waiting for about 15 seconds. Try opening the oven door when the power is turned off. If this does not fix your problem ,please post another comment in this thread. I will respond. good luck.
Nov 21, 2007 | Maytag MER5770 Electric Kitchen Range
My miele metronic w 1926 has red light flashing on the drain value. what can I do to correct the problem? The machine won't let me open the door.
John C
Mar 20, 2011 | Miele W1926A Front Load Washer
Miele G892 dishwasher stopped working. No lights at all. There is power from the outlet to the block behind the kick plate. According to manufacturer, there should be lights even with the door open so this...
This seems to be a failure of the main program controller unit.It needs to be confirmed that the unit received power, if so the controller is faulty.
Check if there is any fuse , check if there is line break to the unit.
Mar 12, 2011 | Miele Touchtronic G892 Built-in Dishwasher
Need waterpump for my 2001 miele 1926 can be used
This is a really common problem that most people send hundreds when they can fix it themselves. Power off your washer, put it on its side. Your going to see four to six silver bolts with hex heads located in the center holding in a plastic device known as the filter assembly. Remove the screws and find any hair inside the assembly. Remove the hair and put the screws back in. Even the smallest amount of hair inside the filter/drain assembly will cause this problem.
Jan 23, 2011 | Miele W1926A Front Load Washer
Reduced spin, still soapy
please check if this type is using Belt to spin the drums, usually the belt is loose or damaged and need replacement.
To check the tension of the belt, Switch OFF or pull off the power cord for safety. Open the access cover , press the belts to check. Replace it if necessary
Idea:
If the belt slips the speed of the spinner is slow.
Dec 12, 2009 | Miele Washing Machines
Our miele condenser dryer with the miele washing machine will often trip the whole house's electricity. Sometimes it will trip on the house circuit board. while other times it trips the external trip...
have the neutral power connection on that circuit and back to the main house panel and then have the neutral connection checked at the power companies side also, it sounds like you have a high resistance neutral connection somewhere in the circuit and its looking for another return path due to the high resistance on the line to another feed circuit line to make connection
Dec 07, 2009 | Miele Novotronic T220 Electric Dryer
Mielepremier novo. No power though plug fuse OK. Door won't open.
I had the same problem with a Miele W828. I removed and reinserted what I think was a condensor where the power cord is attached, after which it was OK. I assumed that it was loose but might have just been lucky in bumping something else back in place when I tipped it onto its side.
Mar 28, 2009 | Miele Novotronic Premier 500 Front Load...
Miele Washing Machine - Novotronic W827
Give the door a firm push shut (even if it appears shut already). There is a safety mechanism that stops the door opening when drum is turning and it gets its knickers in a twist sometimes. Happened to me twice in the last 5 years and can never remember how to fix so end up ringing Miele support who are always helpful. Next time I'll look here first!
Oct 31, 2007 | Washing Machines
Miele Novotronic W1918A Front Load Washer Logo
151 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
