Question about Ahead Software Nero 7 Essentials Suite Full Version OEM
Windows 7 nero image drive not found!!
Problem in installing nero in windows 7!! the nero image drive in tools has not found?? can somebody help me plsss!!!
  • 4 Answers
Como faço pra instalar o nero aki pois esta pedindo o numero serial
Posted on Feb 03, 2010
I need the tool named "bootsect.exe"
Why use bootsect?
Easiest and working tool I found to create a bootable USB from an image is "Rufus", found here: Rufus Create bootable USB drives the easy way
I made a bootable USB for Windows 8.1 installation and confirm that it worked.
Hope this helps.
Oct 03, 2014 | Microsoft Windows 7 Professional 64 Bit 3...
Tip
How to Boot and Install Windows 7 from a USB (even without an ISO file)
While searching in internet I found 3 ways of doing this thing. I will explain all of them here.
1st Method: (The simple one) * Requires a valid ISO image.
Download Microsoft's official tool to install Windows 7 from your USB stick.
Links below:
From CNET: http://download.cnet.com/Windows-7-U...?tag=mncol;pop
MS Store: http://images2.store.microsoft.com/p...B-DVD-tool.exe - Microsoft Store Info Here.
To install the Windows 7 USB/DVD Download tool:
  1. Click to open the Windows 7 USB/DVD Download tool installation file.
  2. When you are prompted to either save the file to disk or run it, choose Run.
  3. Follow the steps in the setup dialogs. You'll have the option to specify where to install the Windows 7 USB/DVD Download Tool.
Note: You need to be an administrator on the computer you are installing the Windows 7 USB/DVD Download tool on. The tool requires the Microsoft .NET Framework version 2.0 or higher.
2nd Method: (Reliable method, Supports multiple types of image files) Requirements:
Now insert the USB drive, run UNetbootin, and select Disk Image as ISO( or select the type of image file of which you have).
Browse your local drive for Windows 7 that you downloaded and click Open.
Now Select Type as USB and choose the drive.Once done, it will look like a bit similar to the screenshot shown below.
unetbootinmainwindows77.png Click OK and it will begin extracting all installation files to the USB drive. The whole process will take some time(10-15 minutes), so have patience.
Once the installation is complete, reboot your computer. Now while your system is starting up press the appropriate button(usually F1, F2, F12, ESC, Backspace, or Escape) to bring up Bios Boot Menu. Change the startup order to boot USB by default, usually you will have to press F6 to move the selected USB device on top. Once done, save changes and restart the system.
3rd Method:( Try this if both above methods are not working) Using Ultra ISO application.
1) Download the free UltraISO trial by clicking on this
2) Start UltraISO as administrator
3) "Burn" the iso image to the USB stick by following these steps
With UltraISO:
- Open the image of Vista/Win7 with UltraISO
- Under BOOTABLE tab choose WRITE DISK IMAGE
- Choose your USB stick under "Disk Drive"
- Choose a method (It's recommended to use USB-HDD+)
- Press Write
PS: Make sure to change your BOOT order in BIOS to boot from your USB drive first.
on Oct 06, 2010 | Computers & Internet
At times it will tell me my files are missing or it will not let me do an install ?
the fact that it tells you the files are missing when you are trying to do an installing from the disk it means the disk you are using is either corrupted or has parts that can not be read..The thing to do is try to do an installation from the windows ..and this way you will succeed (and avoid the possibility if the disk player is the one making problems )
another thing is to try and burn the windows disk again ..Download a image ..and after that use Nero or another tool to burn a boot-able disk ..and use it to install ..
now ..depending on your computer configuration ..you can choose what to install ..but if you want you can even install windows 7 if it supports it ..for that you need more than 1G cpu and 1g of ram on your computer and at least 20 G free in C drive .(remember this drive need to be formatted so all files will need to be moved if you want to keep something )
here are some images I used with success ..
http://thepiratebay.org/torrent/6887809/Microsoft.Windows.XP.Professional.DECEMBER.2011
or windows 7
http://thepiratebay.org/torrent/6839618/windows_7
for this you will need the loader if it is not in the folder ..(search on same site )
for to be able to download these images..you need a torrent client program ..and I would go for this one ..
http://www.utorrent.com/
to download..just install u torrent ..and after that go to the page ..and click download this torrent (ignore the big download button case it is a spam )
it will start in utorrent my default ..and when it is all downloaded..you can use Nero and burn the image to the disk ..to do that ..just install Nero ..and double click on the image ..and will open Nero automatically ..
for windows 7 ..you can even try a tool to load it on a memory stick and install it from there by pressing the key for boot menu on start ..and after that choose to boot from the usb ..(or if the boot do not work ..just start the installing from the usb flash directly in windows.
here is the tool I mentioned..
http://download.cnet.com/Windows-7-USB-DVD-Download-Tool/3000-18513_4-10972600.html
if you try to use this tool in windows xp ..you will need to install a couple of fixes ..cause it is made for windows 7 ..but they are available on teh net and the program leads you to them automatically ..
and the tool works cause I use it like this all the time ..and it can also make a boot-able disk or a boot-able usb ..your choice ..
let me know if you have additional problems and please rate my answer..to help my activity here ..
Dec 21, 2011 | Dell Vostro 220 Desktop Computer
Find serial number nero 7 7.10.1
when you install the nero 7 software it automatically take the serial number other wise give this serial number and try
4C85-200E-4005-0004-0000-3M00-0800-35X3-0000-404C-EXCC-1451
ok bye...................
Feb 04, 2010 | Ahead Software Nero 7 Essentials Suite...
Nero 7 essentials disc but when i try to install it it comes up with message this version dose not support vista
Windows Vista is supported by Nero 7 since the version Nero 7.5.7.0.. Older versions of Nero 7 do not support Windows Vista. If you are trying to install Nero 7 from your original disc it is likely that there is an older version included on this disc. If you want to install Nero 7 on Windows Vista please be sure that you will only use latest Nero 7 version, you can download from the below website. Also please be sure that there won't be any rests of old Nero 7 versions on your system by performing the following steps:
1.
Start uninstalling all old Nero 7 applications and files from your computer using the Nero 7 CleanTool
Download the Nero 7 CleanTool using the following link:
Click here.
Save this file to your desktop.
Unzip the ZIP-file with WinZip or WinRAR and save the content to your hard drive.
Double-click on the unzipped EXE-file to start the CleanTool.
The window “Nero General Clean Tool” will open. The installed Nero version will be displayed.
Activate the checkboxes in the displayed Nero version.
Then click the “Clean” button.
A status window will open.
The execution of the tool may take several minutes.
Please wait until the progress bar has moved completely to the right.
In the window “Nero General Clean Tool” click the “Exit” button as soon as the erasing procedure is completed.
Reboot your computer.
The Nero 7 CleanTool has removed all Nero entries from your computer.
2.
To install the latest Nero 7 version, please proceed as follows:
(Note: do not install a previous Nero 7 version from an installation CD now, but download and install the latest version of Nero 7 from our website. All Nero 7 download versions have the full range of functions as an original Nero 7 installation CD. There is no need to install a previous version of Nero first.)
Download and install the latest Nero 7 version from website using the following link:
Click here.
Double-click the downloaded Nero 7 installation file to start the installation.
Enter your Nero 7 serial number during the installation to make your Nero into a permanent version. (The download without a serial number is a trial version only).
You now have a newly installed version of Nero 7 on your computer.
Jul 17, 2008 | Computers & Internet
Nero 7 wont work on vista
What error comes up?
Nero 7 is not made for vista, however I got it to work..
General System Requirements
  • DVD-ROM drive for the installation
  • Windows® 98/98SE/ME/2000 (Service Pack 4 or higher), Windows® XP, Windows® Server™ 2003, Windows® Media Center Edition 2005,
  • Windows® Internet Explorer® 5.5 or higher
  • To install Nero 7 you must have administrative rights for all operating systems higher than Windows® 2000.
Processor and Installed Memory
  • For writing audio and data discs: 800 MHz Intel® Pentium® III processor, AMD™ Sempron™ 2200+ or equivalent, 128 MB RAM
  • For TV recording, DVD and video authoring: 1.2 GHz Intel® Pentium® III processor or AMD™ Sempron™ 2200+, 128 MB RAM
  • For capturing and burning in real time: 1.6 GHz Intel® Pentium® 4 processor or AMD™ Sempron™ 2600+, 128 MB RAM
Hard Drive Space
  • 1 GB hard drive space for standard installation of all components
  • Up to 9 GB free hard drive space for DVD images and temporary files
Display Settings
  • Microsoft® DirectX® 9.0 or higher • Graphics card with at least 8 MB video memory and minimum resolution of 800 x 600 pixels and 16-bit color settings. However, 24-bit or 32-bit are recommended.
Optical Device
  • CD and/or DVD/DVD-RAM recorder
Sound Devices and Speakers
  • 16-bit Windows® compatible sound devices and speakers • Installation of the latest WHQL (Microsoft® Windows® Hardware Quality Labs) certified device driver recommended
Nero 8 was
Nov 29, 2007 | Microsoft Windows Vista Ultimate Edition
Ahead Software Nero 7 Essentials Suite Full Version OEM  Logo
876 people viewed this question
Top Ahead Software Computers & Internet Experts
celos
lemesee
Are you an Ahead Software Computer and Internet Expert? Answer questions, earn points and help others
