Question about Microtek 211SD 21" LCD Monitor
Monitor makes popping noise when power is on.
When I turn the power on my microtek 211 sd monitor it will make a popping noise and that is all it will do. I have emailed microtek support and received no reply, called them and waited for 45 minutes on hold and still did not speak to anyone at microtek. Does anyone have any suggestions or advice for troubleshooting
Guest: I had the exact same problem with an identical monitor, Located the defective capacitors and replaced them. However, finding the exact type was very hard to do 1000MFD 25v 105 degrees C. I was able to make the monitor work today with a similar component with a rating of 1000MFD 25v 85 degrees C. I am hoping that this will do the job. Novice
Posted on May 22, 2008
  • novice1990 May 22, 2008
    Thanx Kishkane.
    Scholar:
  • 198 Answers
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
It sounds like you might have blown out a capacitor, located in the heart of the monitor circuitry.  WARNING: do not attempt to access this yourself due to the high likelyhood of electrocution to you and others around you.  You'll be fried faster than a piece of chicken from KFC.Step 1.  If you decide to disregard this warning, wear protective eyewear and do not stand in a puddle of water while working on your monitor.Step 2.  Before beginning circuit repair, unplug your monitor from the outlet and let it sit for at least 75 days to give time for all stored electricity to drain out.Step 3. Using a trial and error method, guess which capacitor is working improperly and replace it.Once repairs are complete, plug your monitor back in and see if its working correctly.  If not, repeat steps 1, 2 and 3 until it does.Hope this helps.- The Fixfox
Posted on Jul 01, 2008
My Microtek 710S Monitor screen goes black if left unattended for one minute. What do I do to keep this from happening?
Check the power setting of your PC.
  • If you are on windows;
  • Click on start button
  • If you have vista or windows 7, type "poweroptions" into the search bar.
If not, open control panel and find the power options inthere
  • In "power options" you can change when the displaygets turned off and when your PC will go to sleep, just change these settingsto the time you want, e.g. 2hours
I can offer support for other OS if required
Mar 02, 2011 | Microtek 710S 17" Flat Panel LCD Monitor
I lost my installer of my microtek scanner
I can't send it to your email address, but I can post it here for you.
Before you begin downloading the needed software, I implore you to disconnect the Microtek scanner from your computer. Unplug the USB cable FROM the computer.
[It isn't wise to leave a USB cable unplugged, and connected to a computer]
Also, if the scanner is turned on, turn it off. Unplug it from power.
Are you using Windows XP? (Either version. Home or Pro, doesn't matter)
If so, this is Microtek Support, and the download page for the ScanWizard 5; version 6.32 software, for your Microtek Scanmaker 3840,
http://support.microtek.com/downloads/drv_specific.phtml?cnntn=c&x=11&y=16&slct_os=8&step=2&prod=32&byctgy=1&drvgrp=489
Under the Description heading, (In the blue bar), you will see -
ScanWizard 5 version 6.32
To the right you will see - Main Installer, in blue.
Left-click on Main Installer
A small window will come up.
Opening drv_sw5_v6_32_ad.exe
Click on Save File
If you do not have your downloads set to save to your My Documents folder, (Start>My Documents),
this file will be saved to your desktop screen.
In either place, when you see the file, Double-click right on it.
The Installation Wizard will come up, and lead you through installing. (I advise just clicking on Next, Next, and Finish. The Installation Wizard will put the file in the appropriate place. You do not have to make any changes)
This software download has the needed drivers.
On the same page, (You may want to bookmark the page for future reference), you will also see a Help Guide listed.
It's the third file down that is listed.
ScanWizard 5 Online Help
Should you not be able to download these files, I suggest it is your anti-virus settings. Sometimes an anti-virus program, will recognize certain downloads as a virus, and not bonfide software.
After you have installed the ScanWizard 5 version 6.32 software, you may be asked to restart your computer. If not restart it.
After Windows is running again, and all your Start programs, plug the USB cable from the scanner into your computer. Now plug the scanner into power.
WAIT 1 minute, then turn the scanner on.
You should see a pop-up out of your task bar, at the bottom of your monitor screen. "Found New Hardware", and perhaps another one, "Found Microtek scanner"
Should you need any additional help with this, please come back, and post it in a comment.
Oct 10, 2009 | Microtek scanmaker 3840
Microtek 997M monitor doesn't stay on...
The inverter is the most common item to fail on a LCd monitor. Capacitors usally fail the most. Are the tops of any of them popped up. If you had any shorted transistors the fuse would probably be blown. Usally labeled F1. I would replace all the capacitors first and go from there. Capacitors are cheap.
Jun 20, 2008 | Computers & Internet
Computer making noise
Monitor clicks, pops, or makes other noises. Issue: Monitor clicks, pops, or makes other noises.
Cause: This issue could be caused by any of the below possibilities:
  1. Monitor degaussing.
  2. Monitor changing resolution.
  3. Monitor syncing with the video card.
  4. Monitor warming up.
Solution: Noise when turned on or off It is normal for standard computer CRT monitors to make a click, pop, crackle, hum, buzz, or other type of noises when they are first turned on or turned off.
Noise when monitor goes into standby mode When the monitor enters a "standby mode" or "power savings mode" this is similar to the monitor being turned off. It is completely normal for the monitor to make a noise when the monitor enters this mode.
Noise when opening Microsoft Windows or other operating system or when opening a game When a computer opens its operating system, for example, a computer opening Microsoft Windows or when a user runs a computer game it is very common that the monitor will need to switch its resolution of the operating system or game. When switching resolutions it is normal for the computer monitor to make some type of noise and/or for the computer monitor to flick or flash.
Noise during normal operation If the computer monitor click, pops, or flashes while it is being used this is not normal operation. It is very likely that the monitor may be failing or a component within the monitor has already failed and could also potentially be a fire hazard. We highly recommend that the monitor be repaired, replaced, and/or looked at by a qualified technician.
Additional information:
  • See document CH000302 for additional information and other noises that may come from
Jan 16, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
Microtek 211SD 21" LCD Monitor Logo
456 people viewed this question
Top Microtek Computers & Internet Experts
William Miller
William Miller
Michael Deni
Level 1 Expert
ray gallant
Are you a Microtek Computer and Internet Expert? Answer questions, earn points and help others
