Question about Kitchen Ranges
Broken glass cook top - Kitchen Ranges
  • 725 Answers
We have parts for all brands of appliances. We need your brand and model number and we can send the correct part out to you asap.
Just contact us at;
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM until 7 PM CST and we'll be glad to help you.
Thanks, Ella
Posted on Feb 02, 2010
My Maytag glass cook top PER5710BAQ stove has broken cook top are the similar product model tops compatible or do I need to buy the exact top... IE could I buy an amana cook top or whirlpool since they are...
It will depend how the tops electrical terminations are. Many internal/fuses/switches/elements are the same, but though may tag is the parent manufacturer it always isn't interchangable. Like a Pontiac g6 and Pontiac sunfire...
They're both 2 door cars
Both made by Pontiac
Some parts are identicle
But some aren't.
Nov 12, 2014 | Kitchen Ranges
Tip
Replacing a Glass Cook Top
This advice is for Electric Ranges equipped with glass smooth tops. If it becomes necessary to replace the cook top due to wear or damage, here's some helpful tips on how to complete the repairs yourself. NOTE: Cook tops are NOT cheap. Prices vary between models, but most are in the $200 to $300 range. With added labor charges, this repair can cost over $600 from an appliance repair company.
WARRANTIES: Most warranties DO NOT cover cosmetics. That is, if your cooktop paint starts to wear off, most manufacturers will not replace it. Warranties also DO NOT cover accidents such as dropping something on the top and breaking it. Warranties DO cover blistering, warping and heat related breakage (if you are using the recommended cookware). This is why it is important to follow all the manufacturer's use and care instructions that come with your range. I know this does not include ALL manufacturers, but this is true with most.
This is a recommended two-person repair job. Please read through the instructions carefully before starting the repairs, and follow any safety recommendations.
1. UNPLUG the range before servicing. There are dangerous voltages still present even with burners turned off.
2. If the old cook top is broken, you will need to get rid of a much of the glass shards as you can and thoroughly vacuum the area around the oven box. Use extreme care when handling broken glass. Wear safety glasses and gloves.
3. There are a few screws located under the front edge of the cook top. You will need to open the oven door to see them. Remove these screws and the top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
4.On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, Follow these steps:
  1. Unplug the cook top and leave the elements in place.
  2. Place the whole cook top assembly face-down on a soft surface (like some old towels, or a blanket).
  3. Remove the surface element assembly leaving all the elements wired together.
  4. Place the new cook top face down in the same manner and lay the surface element with wiring harness directly on to it and screw in place.
  5. Install the new cook top back on the range and you are DONE.
5. If the wiring harness does NOT unplug, follow these steps:
  1. There are a series of screws holding the element assemblies in place. Leave these assemblies wired together for ease of replacing. It is recommended that a second person holds the assemblies in place to support the wires until all the screws have been removed.
  2. Lay the intact element assembly, with wires still connected, on top of the oven box. Handle the surface elements with care. They are very fragile. Care also must be taken not to handle the element coils or ceramic material. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure.
  3. If you have to remove the elements, individually, make sure you write down how the wires were connected to ensure you reconnect them in the right order. Make sure you also take note of the numbering scheme on the element and make sure you place the mounting brackets in the same holes that they came out of. Use care when screwing into the new cook top. CAUTION: The screw holes are usually painted and a little force may be required to thread the screws. Do not apply too much pressure on the glass, or you can damage it.
  4. Prop the new cook top in place and install the surface element assembly from underneath. A helpful hint: Use some duct tape to hold the assembly until you have screwed it back into place. Don't forget to remove the duct tape when completed.
  5. Lower the new cook top into place and secure with screws.
    Good luck and I hope this helps.
on Mar 02, 2010 | Kitchen Ranges
What kind of glass cook top repair creme do I need for Firdgidaire Model FEF353BFW
Hi stormsdestin - Thank you for your post! The electric range, model number FEF353BFW is recommended to used warm soapy water to clean the electric cook top. If your cook top is broken or damaged, you may want to connect with a local servicer who will be best equipped to pinpoint the problem. However, if you are requesting information on what kind of cook top repair creme may be use I would personally suggest contacting the manufacturer directly.
Apr 06, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Glass top Broke
the manufactrurer offers a 5 yr mfg warranty for thermal breakage however you need a certified repair establishment to obtain the part under the warranty, you can try calling the mfg yourself and explain that there is a strange lloking broken area in the glass and they may dispatch a local service provider to help you with the problem DO NOT MENTION BROKEN GLASS OR LID OR MOISTURE just say strange broken are on cooktop, otherwise thery are 400$ plus
Sep 12, 2009 | KitchenAid KESC307 Electric Kitchen Range
Broken glass top on my Maytag Schott Clean (upper
u have to replace the whole top and its about 400 to 500 dollars just for the part cheaper to buy new
Mar 20, 2009 | Maytag MER6772 Gemini Electric Kitchen...
REPLACE CRACKED GLASS COOK TOP
First of all, if the cook-top broke as a result of a manufacturer defect, the repairs should be covered under the manufacturer's warranty. In this case, the repairs would be done at no cost to you. If, however, the glass top was broken as a result of the consumer, the repair will not be covered (even if it is still under warranty). If this is the case, it does not require an engineer to replace a glass cook-top. It can be time consuming, though. If you are somewhat savvy with fixing things, it can be accomplished by the average do-it-yourselfer. The following link explains how to replace most glass cooktops:
http://www.fixya.com/support/r391448-replacing_glass_cook_top
The tedious part of replacing the cook-top is carefully removing and handling each burner element. These are usually ceramic and are very fragile. You must be handled with care. If there is no common disconnect, you also will be required to unplug each burner assembly one at a time and label the wires. A digital camera can come in very handy for this as well. The easiest way to do this is to remove the old shattered cook-top, first and lay it side by side with the new one. Remove and install one burner element at a time.
If you wish to pursue this and require additional assistance, please let me know before you rate the solution. I hope this helps you.
Jan 28, 2009 | Whirlpool GR773LXSS - Stainless Steel...
I cracked my stove's ceramic glass cook-top
replace the glass. it may be expensive but usually fairly easy
Jan 04, 2009 | Ovens
Glass top broken
All you can do is to have it replaced.
Most housemold insurance covers for this sort of accident.
Dec 14, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Broken glass steamer bowl
glass breakes you can fix it so replace it
Sep 08, 2008 | Cook's Essentials Cooks Essentials Arome...
I have a Kenmore electric range oven Model # 79095201103 that has a glass top. The top cracked and I ordered a new glass top for it. What steps do I need to do to replace the top. Is it complicated???
Here ya go...
Apr 06, 2008 | Kitchen Ranges
Kitchen Ranges Logo
100 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
