Question about Brother HL-5240 Laser Printer
A piece of paper is stuck inside. I tried to pull it out from the paper tray end but it has now receeded and I cant print or get it out, any ideas?This occurred when I stopped the print run mid- print by turning it off because I had made a mistake. How can I open it to get the paper out? Thanks
    President:
  • 2,306 Answers
Just open the front door and take out he toner/drum cartridge, remove the paper cassette, best is to pull the paper forward toward the inside of printer, if none is visible you can push an index card up from the front to push out any scraps.
Posted on Feb 01, 2010
Testimonial: "Thank you so much, its the silly little things that annoy the most! All working fine now."
I HAVE JUST GOT A PIECE OF PAPAER STUCK IN THE PRINTER AND CANT GET IT OUT
Turn off, unplug, and open the printer. Wait for some time to let the printer cool down. Pull out the print cartridge, if you do not see the paper jam. Gently remove the paper by pulling it. Inspect the rollers.
Jun 18, 2015 | Office Equipment & Supplies
ESP5200printer,new,paper jam message
Hi slicknick58,
Paper jam message occurs when there are stuck papers inside the printer. There are several ways on how to correct this problem, either you remove the visible stuck paper manually or replace the toner or ink cartridge. Below are the steps you'll want to follow when this problem still occurs.
1. Turn off the printer. Turn the printer off and on to see if it can automatically clear some or all of the jam.
2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it. Remove any paper trays. Inspect them for wrinkled or damaged paper.
3. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.
4. If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
5. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
6. If the paper does tear, try rotating the roller gears manually to free the paper . Don't force anything.
7. Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
8. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path and try repeating the above steps again.
Hope it helps.
Thank you for using FixYa.
Apr 20, 2011 | Kodak ESP 5 Printer
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    Hi, how do fix a paper jam? 1st page printed ok, 2nd page jammed. I pulled it out backwards but the centre of the page was torn and a small piece missing. I can't see where I can clear that small piece of...
    Unplug the power cord and open the cover and remove the TONER and try to look I inside around the roller and try to manually roll the roller and if you can see the paper try to pull is slowly.
    Have a nice day and do not forget to rate please...!
    Feb 11, 2010 | Brother HL 1240 Printer
    Paper stucked inside
    Open the top cover.
    Pull out the toner / developer units and look for paper under neath.
    In the rear, pull open the access door.
    remove the paper tray and look for misfed paper.
    Dec 12, 2009 | Kyocera Mita FS-820 Laser Printer
    Brother 2040 paper light .. continuous red
    If you removed a piece. But more remains it must also be removed. Look closely along the paper path for something that will release to provide access to the path.
    May 03, 2017 | Brother HL-2040 Laser Printer
    Paper jam!!
    Please perform the below steps.
    1. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
    2.
    Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
    3.
    Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
    4.
    Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
    5.
    Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
    put the cables back and switch on
    Aug 25, 2008 | Brother HL-2070N Laser Printer
    Printer won't feed the paper through.
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Lets try few troubleshooting for paper Jam issue.
    locate and slowly pull out the stuck paper, perform the following steps:
    2. Open the printer cover.
    3. Locate the stuck paper.
    4. Remove the paper.
    5. Close the printer cover.
    6. Power the printer back on.
    Locate and Remove Any Obstructions Inside the Printer and Input Tray
    1. Open the front cover and make sure the kickstand (if there is one) is engaged.
    2. Locate and remove any obstructions within the printer, such as paper pieces, staples, tape, or other objects.
    3. Close the cover.
    4. Remove all paper from the input tray.
    5. Inspect the input tray for any obstructions.
    6. Remove any visible obstructions.
    7. Reinsert the paper.
    Adjust the Printer Paper Guides
    Extend the front paper support on the printer.
    Try a Different Piece of Paper in the Printer
    1. Take the top 10 sheets off of the **** of paper.
    2. Verify that the remaining sheets of the **** are not wrinkled or dirty.
    3. Replace the remaining part of the **** back in the printer.
    Reseat the Dell Printer Power Adapter.
    If your printer has a momentary loss of communication with your computer, it may be necessary to reset the printer to re-establish communication. You can reset a printer by unplugging the printer power cord from the electrical outlet and from the back of the printer for 10 seconds then reattaching the cord at both ends.
    Try a Different Type of Print Media
    Many image quality and paper feed issues are caused by the type of print media being used.
    Try a different type of print media that is specifically made for this printer.
    When there is no different print media available, take out the top half of the stack and flip it over.
    Try holding the printer upside down and shake it moderately
    Make sure you remove all the cables from printer before performing it
    Check with manufacturer if printer is still covered under warranty...
    If yes then get it replaced.....or else get a new printer
    Aug 24, 2008 | Dell 922 All-In-One InkJet Printer
    HP 6210 All-In-One
    Open up the top and look into the cartridge/paper print area. Look in the corners, Sometimes little pieces of paper can still be stuck there. Once you are convinced that the paper and cartridge path is clear then...
    Pull out the paper tray. Look inside the opening. If there is paper there then pull it out.
    Take all of the paper out of the paper tray.
    Turn it over (paper on top is now on the bottom of the tray)
    Try it now.
    Jun 20, 2008 | HP OfficeJet 6210 All-In-One InkJet...
    False paper jam
    Maybe the sensor flag has become dislodged from its mountings or a scrap of paper is stuck in the sensor.
    Oct 16, 2007 | Sharp AL-1655CS Copier
    Brother HL-5240 Laser Printer Logo
    130 people viewed this question
    CheckitRight
    CheckitRight
    Ron Dufek
    Ron Dufek
    James Cagle
    James Cagle
