Hot water seems to run even when cold/cold is selected and it runs during spin cycle also. It leaked out I believe the door as it seems like it is letting too much water in drum. The last few times it was used the on light would not stay on it had to be pressed several times before the fill cycle started.
  • 129 Answers
Water vavle may be bad
Posted on Feb 02, 2010
Amana washer will not go through rinse cycle
WASHER WILL NOT RINSE:
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
Mar 28, 2015 | Amana Washing Machines
My lg wm0742hga front load washer machine over fill of water causing to leak out from the door
even when overflowing it shouldnt leak from the door? less u have a bad door seal? the water problem may be due to a bad water inlet valve? have u notice water in the tub even when ur not using it? check with a multimeter the inlet valve and the water pressure switch? blow into the water pressure switch while it is in the wash mode filling with water and if it starts washing the diaphfram is good if not its faulty. u can also checl the water inlet valve the one with the hoses attached . by running either a hot or cold cycle only and turn off the hot then turn off the cold? see if it continues to over flow with each cycle? hot then cold- GOOD LUCKKKKK
Dec 04, 2014 | LG WM0742HGA Front-Load Steam Washer with...
FE Code for model WM1812CW LG Washer
Hot water inlet valve most likely needs replacing
May 14, 2017 | LG Washing Machines
My model # is LSR8233jqo. I believe I am having a problem ith the timer unit. Wash cycle starts after setting timer and runs for a while then stops mid wash usually just before the spin cycle. If I...
o.k test the a) water supply cold. read your instr. manual some model during the cycles coming cold water other hot water, read for is acting abnormally.
b) TESt the timer see the diagram> tight any wires connector loose or corrosion, or dirty.
see the w.diagram how the timer control any function of the washer.
God bless you
Jul 18, 2012 | Washing Machines
Washer only washes with hot water
consult your owner manual about you are unsure about if the machine is acting anormally
Some machines, is running hot water during cycles, other cold water during cycles.
God bless you
The washing machine won't start if "cold water" only is selected. It will only work when "warm water" or "hot water" is selected (and even then there is only hot water filling the machine, the cold water...
Check the cold water solenoid. If a meter is not available you can swap the hot and cold wires and see if the symptom changes to hot water when cold is selected. If so the mixing valve needs replaced. If no then further testing of the wire harness and timer circuit are needed.
Eric
Apr 13, 2010 | Kenmore 13202 Top Load Washer
Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Oct 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Cold water pours in during final spin
No - the timer is the likely suspect.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 15, 2009 | Kenmore 98702 Stacked Washer/Dryer
There is something clogging your pump, dismantle it to clear it. Plug off the wall socket mains first.
Jan 15, 2009 | GE WDSR2080D Top Load Washer
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
