Question about HP Photosmart C6180 All-In-One InkJet Printer
Error code- print system failure code 0xc18a0501
Solution posted here is straight off the HP support site and didn't work for me. However, elsewhere in this forum is something that did!
1. Power down the printer (use on/off button) and remove power cable. Wait 2 minutes.
2. Hold down Help and OK buttons together while plugging in the power cable.
3. I held the buttons for around 5 seconds and when I released them, the printer seemed to go back to a hard reset - all sorted!
Hope this helps!
R
Posted on Feb 08, 2010
  • ib_angelique Jan 31, 2011
    I had the exact same problem on my C6180 and it worked for me!!!!! Thanks!
  • Roger Lancaster Nov 12, 2012
    Same problem. Worked a treat for me. Roger
  • 4,041 Answers
Hi I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. Error 0xc18a0201 with HP printers Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Posted on Feb 02, 2010
I did both the power shut down, press help and ok, then the USB cable/cartridge removal. I also removed/replaced some of my cartridges. Last I did another shut down of my computer, just for fun. None of the these seemed to work. My last attempt before going out for a new printer was to swear at it profusely. This, or the culmination of all the previous attempts finally worked.
It took over an hour to recalibrate and work through its processing before it was ready to print again but it seems to work well now. No idea what went wrong or what worked.
Posted on Jan 09, 2011
SOURCE: Ink System Failure
I myself have not tried this, but apparently it came from HP.
HP Photosmart C5180 show ink system failure message
This was what I was told to do for my C5180. First they told me to do a power drain. This is done by pulling out the power cable and then holding the on/off button for a minute, then putting the power cable back in (this didn't work).
Then we did a master reset. Unplug the printer, then pressing the help and ok buttons simultaneously plug it back in. This sorted it. :)
Have to say it looked like this whole process used up shed loads of ink, so by the time I had finished I needed to replace 3 cartridges!
Posted on Apr 22, 2008
pineworks
  • 4041 Answers
SOURCE: Error:0xc18a0501 on HP Photosmart 3210
Hi I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
5. Wait 60 seconds.
All The Best: Pineworks
go with best solution from sweetie11881 it really works! I had almost given up and called a repairman with a quote of $90 for half an hour just to see what was wrong then 120.00/hr for repairs that they may not be able to fix!
Posted on Jan 23, 2008
  • 71 Answers
SOURCE: HP 7280 All in one problem Ink System failure Error 0xc18a0501
1. Try to remove and reinstall the Ink Catridges. Be sure it is lock in place on the ink cartridge holder.
2. Turn off the Printer and unplug and replug the power adapter.
3. Uninstall and reinstall the printer driver.
Posted on Jun 16, 2009
rulds2008
  • 3866 Answers
SOURCE: can't print on Photosmart 3110 all in one
This is a result in a print head failure or the use of non HP ink ether or there right you need to service the unit part will be needed if the maintance does fail. If your using non HP ink stop its use and purchase HP ink you be glad you did!
Posted on Nov 17, 2009
Got ink system failure code # 0xc18a0501 on HP Photosmart C7280 a-i-o and no amoun of shutting down and restarting will help. What can I do?
  1. Press and hold the "*" key.
  2. Press the "#" key and release both keys.
  3. Display should say "Enter Special Key Combo"
  4. Press and release in sequence the "1", "2" and "3" buttons. The screen will say "support"
  5. Press and release the right arrow button until the display says "System Configuration Menu".
  6. Press and release the "OK" button.
  7. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
  8. Press and release the "OK" button.
  9. Display should say "Hardware failure status: Clear. Press OK to clear".
  10. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
  11. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears.
PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
  1. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
  2. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
  3. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
If it did not print out a diagnostic page:
  1. Is the error message still being displayed on the printer?
  2. Print a self test page to check the functionality of the printer.
  3. Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
May 04, 2011 | Computers & Internet
Its giving error code 0xc18a0501 ink system failure.how can i fix this?
If systems problem, just install and reinstall the printer software to correct the setting.
Dec 07, 2010 | HP Photosmart 8250 InkJet Printer
Reset the product:
5. Wait 60 seconds.
Jan 31, 2010 | HP Photosmart 3210 All-In-One InkJet...
Can't print on Photosmart 3110 all in one
Nov 17, 2009 | HP Photosmart 3310 Printer
Ink systm failure on HP photosmart 3210 error 0xc18a0501
The "Ink System Failure" error is causes by air in the ink feed tubes. We have a step by step guide purging the air from the feed tubes posted on our web site. Go to our site at: www.ccl-la.com , click on the printer repair page link and then the HP link. Follow the steps and you should be back printing in no time at all.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Oct 30, 2009 | HP Photosmart 3210 Printer
HP 7280 All in one problem Ink System failure Error 0xc18a0501 I have tried shutting down even reset the system, but it still produces same error code.
Jun 16, 2009 | OKI C3400n Laser Printer
I have got an error code, it reads 0xc18a0501. How do I resolve it?
Try
Reset the product:
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
Jun 11, 2009 | HP Photosmart D7160 InkJet Printer
Ink System Failure
Reset the product:
  5. Wait 60 seconds.
Nov 09, 2008 | HP Photosmart D7160 InkJet Printer
Ink System Failure
I just had this problem with a HP C5150 and I found this bit of conversation on the web and it worked for me.
My error code was 0xc18a0501 and the following steps did resolve my issue, hope it helps you as well.
  • OK I had the hp error code 0xc18a0001 problem and here is the conversation I had with the tech.....
    james cowan: hp error code 0xc18a0001
    Earnest: I will assist you in this regard
    james cowan: great
    Earnest: I understand that a error code with 0xc18a0001 with "Ink System failure" is displayed on the front panel of the All-In-One printer. Am I correct?
    james cowan: correct
    Earnest: Thank you for confirmation
    Earnest: May I have the model number of All-In-One you are using?
    james cowan: c6250
    Earnest: Thank you for information.
    Earnest: James, please let me know the room temperature in which printer is replaced
    james cowan: 67 degrees f
    Earnest: Okay
    Earnest: Please perform the below steps on the front panel of the printer to resolve the issue
    james cowan: ok
    Earnest: Press and hold the "left arrow" key.
    Press the "Setup" key and release both keys, Display should say "Enter Special Key Combo"
    Earnest: Please ignore the above steps, James
    james cowan: ok yes nothing seemed to do anything
    Earnest: Press and Hold the "Print Photos" &"Red Eye Removal" buttons. Release both buttons. Display should say"Enter Special Key Combo"
    Press and release in sequence"Red Eye Removal","Print Photos","Red Eye Removal"
    Earnest: Display should say “Support” and display the FW rev (something like R0616R)
    james cowan: COxxFN0723BR j
    Earnest: Okay
    Earnest: 2. Press and release the right arrow button until the display says “System Configuration Menu
    james cowan: ok
    Earnest: 3. Press and release the "OK" button.
    james cowan: ok and it says hardware failure status
    Earnest: Display should say "Hardware failure status: Clear. Press OK to clear".
    Earnest: Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
    Earnest: Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
    james cowan: ok
    Earnest: Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
    Earnest: Let me know once you are done with the above steps
    james cowan: ok its unplugged
    Earnest: Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
    Earnest: Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE".
    james cowan: ok
    Earnest: Let me know the message displaying on the front panel of the printer
    james cowan: printer preparation occuring - do not interrupt
    Earnest: Okay
    james cowan: ok its done
    Earnest: Let us print a self test page from the printer now
    james cowan: ok deal
    Earnest: 1) Load letter, A4, or legal unused plain, white paper into the input tray.
    2) Make sure that the printer is on and loaded with unused plain, white paper.
    3) Press Setup . The Setup menu appears.
    4) Press the down arrow button to select Tools , and then press OK .
    5) Press the down arrow button to select Self-test Report , and press OK .
    james cowan: ok printing
    Earnest: Okay, please check whether all the colors pritned perfectly on the test page
    james cowan: perfect
    Earnest: Great..Cheers!!!
    james cowan: thank you very much
    Earnest: James, now you can continue using the printer
    Earnest: I appreciate your efforts and patience in trying to resolve the issue."
May 26, 2008 | HP Photosmart 3210 Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
914 people viewed this question
Ben Johnson
