Question about Kenmore 73952 Gas Dryer
Kenmore front loader dryer will not start on it own-
    Scholar:
  • 91 Answers
Please give more info,
does it spin but won't stay running?
when u set the timmer to start does the motor turn on at all hear any noises?
what was the last thing the machine did, before it went out that helps to
diagosis the problem easier thanks
Posted on Feb 01, 2010
When i push the button to start my dryer, I can choose the cycle, temperature but when I push the button to start it- a dr appears on the screen and it doesn't start. It is a Kenmore front end loader...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Aug 26, 2010 | Kenmore Dryers
I have a kenmore front loader dryer. My basement recently had a flood and the bottom of the dryer was wet. When i tried to start it, it hums but will not run. What is the problem?
the motor is cooked,i live in the boston area and we had some bad floods a few months ago,all i did for two weeks was change out dryer motors,you can try to spin the drum and hold in the door switch and have someone else hold in the start button to see if it will start but you have to change out the dryer or get a new one if it's in rough shape
Aug 05, 2010 | Kenmore 73952 Gas Dryer
I have a Kenmore Elite HE5 front loader and seem
when i clean my screen i use a cheap vacuum to **** up particles as i pull it out and vacuum screen. works so nice.. but use a cheapy that you doesnt need a bag and it will filter better as it gets clogged with lint lol.
Apr 16, 2009 | Dryers
Kenmore front loader Model 48102 will not start
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 14, 2009 | Kenmore Washing Machines
Dryer works for few minutes then stops
clothes can open the door if door latch is weak, causing door opening and stopping the cycle, or a bad automatic sensor
Feb 17, 2009 | Kenmore 62602 Electric Dryer
Dryer wont start anymore
If the drum won't rotate, you may have a broken belt. I had a Kenmore and as I recall, you have to pull up the top section to see inside. Good luck.
Sep 14, 2008 | Dryers
Whirlpool Duet Ghw9150pw1 would not start
Aug 21, 2008 | Whirlpool GHW9150 Front Load Washer
Dryer won't start
hi thanks for the question theres a small thermal fuse located under the door behind the panel to get access remove front bottom panel 2 screws at bottom of panel and on the air duct to the left theres a small thermal fuse check it for continuity if bad replace thanks the appliance doc
Aug 20, 2008 | Kenmore 62872 Electric Dryer
"controls locked" red light indicator is lit up...
Hi! mingx2of06
So are any lights on, do you have power at the wall circuit.
InMrFixIt
Aug 08, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 73952 Gas Dryer Logo
78 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
