I have a Samsung HL-R6868W LCD TV. When I first turn it on it works fine, then after a few minutes the picture is garbled. I do not see any vented or blown capacitors, and the fan in the center on the back of the set is spinning (looks like a computer CPU cooling fan). I was told that the unit has a self test feature, should I use that, and if so, how?
  • gary300 Feb 01, 2010
    it seems to me that it must have something to do with cooling. With the back off and the override switch taped on, the tv has run for a couple of hours.
    The response did not address my question on self diagnostics
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems that you might have a backlight issue with this TV set. It could also be due to the inverter circuits for the backlights. The inverter is the power supply source for the backlights. There could also be a screen driver problem; if it is then you have to change the entire board. All this is only recommended if you have some kind of expertise for checking the internal circuitry of the TV as these units have high voltages running even when the set is switched off.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 01, 2010
  • Rylee Smith
    Rylee Smith Feb 01, 2010
    If that is the case then you'll need to check for swollen capacitors once again maybe the issue could be with them. Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
  • 4,472 Answers
Are you sure that is the correct model number? I am not finding much under that number there is a 6767 though. I would consider getting the service manual for the television if you are attempting any type of repair or service yourself.
Thank you,
Lee
Samsung T.V. goes on for 30 seconds then no picture
If this is a flat panel LCD tv, this is a sure sign that the panel itself is bad. I have seen this before. Tv comes on works fine then within 5 minutes goes blank.
Aug 07, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung ldp 46 " replaced lamp humming sound fans cleaned and working set continues to turn off every 20 min or so
Humming problem with a Samsung DLP HL-P5063W
picture displays good
Humming randomly starts, but once it starts it hums
May 31, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP TV bad picture
Some Samsungs have a problem if the set is turned on bfore the input put device due to a firmware issue. Try turning on the device (game, DVD, etc) BEFORE turning on the TV.
Let me know if this helped.
visit my site:
www.mcveyelctronics.com
May 02, 2009 | Samsung HCM5525W 55" Rear Projection...
Buzzing and poor recption
I wish I had a solution--My DVD picture and sound is fine, but it takes about 30-40 minutes to get any kind of picture but it is broken--not clear at all - and the sound is all garbled, totally stops for seconds to minutes a a time. It is only a little over a yr old. I finally isconnectexd today and am going back to my cheap-o but dependable tv.
Aug 08, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Picture on my TV starts to flash after a few minutes of use
This problem is common in Samsung projection TVs. The DMD board is going bad.
Mar 21, 2008 | Samsung HL-R6167W 61" HDTV
T.V. TURNING OFF AFTER ABOUT 5 MINUTES.
Go to Samsung.com for solution. There is a switch that just needs to be repositioned behind access door on rear. Fixed my HL-S5086W ok.
Feb 13, 2008 | Samsung HL-S5086W 50" HDTV
Samsung HLR6167 - picture freezes
This is very common in Samsung DLPs. The DMD board is going bad. You will need to replace it.
Jan 07, 2008 | Samsung HL-R6167W 61" HDTV
Samsung DLP HL-S5086
Vertical problem and most likely a bad capacitor in the Vetical out circuit or IC.
Nov 24, 2007 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
