Question about McCulloch 10" Electric Pole / Chain Saw
MAC 7-38 chainsaw stalls when you open the throttle. Any ideas?
It stalls when you open the throttle. Any ideas?
  • dontbother10
    dontbother10 May 11, 2010
    I found a European Mac 738. Is this your saw? If not I need a better model number. Approximate age. Just something to help us help you.
  • 677 Answers
We are talking about an electric chain saw ?
I would say you are not getting oil to the bar chain sprocket. Do you have enough bar oil in it ?
Posted on Feb 05, 2010
  • john smith Mar 17, 2015
    This is a typical answer from a woman. Would it really have a throttle if it was electric?
Making chainsaw
This an example of a carburetor comming from a realy bad budged chainsaw orange colored Brand model below number 340 yes a ZAMA carburetor hihihihiii its not done to get it open in the smallest
fuel channels they are very fine even not with hydrochloric acid.
Really trust me you will spill your time and it also made me evil to the brand of this chainsaw to sell this to dissapointed customers. and if you have been done that the next part is your trigger that will have problems soon.
Dec 23, 2015 | Garden
How do u set the darb screws on a mac cat 839 chainsaw
Turn both jet screws CW to stops (lightly), then back out CCW 1-1/2 turns each. Start the engine and allow to warm up. Open the throttle and adjust the H jet needle CW until the engine starts to speed up. Correct adjustment is when the engine 4-strokes at speed unloaded, but 2-strokes immediately when cutting. Release the throttle and adjust the L jet screw CW for better idle, yet allows the engine to 'follow the throttle'. Adjust the idle speed screw so that the engine continues to run, but the chain doesn't try to turn. Hope this helps!
Nov 05, 2010 | Garden
Starts when cold but not when hot
Check the air cleaner for plugging. Don't use the choke when it's hot. Check the condition of the spark plug and the quality of the spark which should be blue and snappy. The internal insulator should be a tan color if running correctly (plug gap 0.020"). You may need to inspect the diaphragm in the lower part of the carburetor--it should be flexible with no holes or cracks. Turn the L jet needle CW somewhat until the engine will try to stall when the throttle is pulled, then back it up about 1/8 to 1/4 turn CCW until the engine will 'follow the throttle'. Hope this helps!
Oct 21, 2010 | McCulloch Points Pro Mac 6 Or 6a Chainsaw...
Need intructions on carberator adjustments for mac-3514 35cc/cm3 runs but hard to start after using it for few minutes.
There is a low speed jet and high speed. Low speed sets the idle or stays running without feathering the throttle./// When setting high speed, hold the throttle wide open until engine revs high, then turn back in(at least ¼ turn) to slow the engine which in turn gives the engine more gas and runs cooler. If you have it too lean on the high speed, it will be hot and hard to start. Sometimes using 40 to 1 mix helps with starting, especially on older chainsaw. good luck
Sep 22, 2010 | McCulloch Garden
Stalls during idle
Try setting the idle speed screw CW a little (not the two jet screws) until the engine will continue to idle, but not turn the chain. If this doesn't seem to help, then adjust L jet screw about 1/8 turn CCW. Hope this helps!
Jun 14, 2010 | Garden
I have a new hasky 460 rancher stalls when given
If it stumbles at full throttle, the fast (high) idle screw is set too rich. Using your owner's manual, locate the high idle adjustment and back it off in very very small increments. Do this until the saw will run wide open without stumbling.
Jun 06, 2010 | Husqvarna 20" 60cc Rancher Chain Saw 460
Saw starts, then stalls when you increase the throttle. Spark plug looks fairly clear. Ay ideas on where to look next?
Yes, you will need to disassemble carburetor and clean with carb. cleaner. If you need tips on how best to do this, just let me know. Or you may need a new carb. kit.
Jim
Jun 01, 2009 | McCulloch Garden
McCulloch 10" Electric Pole / Chain Saw Logo
465 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
