Question about Honda 8 HP Engine
Have a 11hp power washer pump not sucking water, how do i fix ?
    Problem Solver:
  • 5 Answers
Hey there...
Is the washer a direct drive or belt drive unit? If it is a direct drive ( the pump bolts directly to the engine) then the pump needs to be force fed the water, either by city pressure or a transfer pump. If it is belt driven, the lower rpm's should pull water, so more detail would be needed...
Posted on Feb 03, 2010
Have honda gx340 11hp pressure washer and gas keeps going into oil?
Excessive fuel entering the inlet manifold, carby needle and seat not shutting of fuel flow , remove and clean fit new gaskets and needle and seat if worn.
Jul 02, 2015 | Honda Gx340 Gas Engine 11hp Motor Pressure...
1+ year old GE wjre555ok2ww washer won't release the wash water during spinning. How can I fix that?
Small things get into the electric pump. I removed coins and shoestrings from the pump in the past. They are easy to take apart and clean up. Rarely do they fail.
I have a video and service manual for your Hydrowave Machine HERE
Mar 04, 2011 | GE WJRR4170BT
Where i have to store in the winter? . how many offen y have to change the oil pump and engine?
Heat you machine and take out the oil, then you can store it in a safe and dry place.Oil pumps and engine can stand as long as you care it.
So if your machine start with some problems try to fix it in a professional way.
Oct 13, 2010 | Mi T M Cw30044mgv 3000 Psi 11hp Pressure...
11hp washer new not sucking up water from barrell with or without lance
Try putting the machine on mains water pressure first to get rid of any air in the system then try it from a barrell.
May 31, 2010 | Garden
Pressure washer has no pressure
hi i am a pressure washer engineer, dont just jump in and get an unloader there is a few test you can do first! first of all is the machine sucking from a drum or off mains water pressure, if sucking force feed the pump with water to see if there is any leaks. and post reply on here or ring on 07973527954
Jan 14, 2010 | Karcher 2500 PSI Pressure Washer
Washer spins freely but clothes remain very wet
The two possibilities of which come to mind are, something in pump slowing the water outlet, belt loose or needing replacement. Sometimes an article gets over the barrell and sucked into the pump still allowing some water to pass by, but the belt needing to be replaced would prably be my first check. both need Power disconnect then cabinet panel pulled to view both the pump and belt
Feb 09, 2009 | Maytag PAV2300 Top Load Washer
Water left pooled inside maytag neptune front loading washer
Possible explanation: Some water is left in the hose going up to the drainpipe b/c the pump can only pump water with water, not air... so when the last bit of water is sucked up, it 'stays' just the other side of the pump exit nozzle and keeps the drain tubefilled. This water gradually leaks thru the drain exit valve and back into the machine, sometimes siphoning standing water in the drain trap with it.
The valve is either electric solenoid or plastic/rubber clapper in a cylinder. Your call whether to fix or not depending on ease and cost. Probably a $20.00 part.
Cheers!
Jan 27, 2009 | Neptune MLE2000A Front Load Stacked Washer...
Prevent items getting sucked through the pump
hi suggest you try this? use a spare small pillow case and put all smaller items in it then tie up open end witha a cord then put in washer they will wash and not get eaten by washer////// there are string bags with tie cord on the market at tesco etc that are designed for this purpose ?and are not expensive
Nov 03, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Fisher paykel not spinning out all the way
1st get as much water out as possible lean washer forward against something from back looking up left side rear of washer is pump.a finger clamp connects hose to pump remove hose a plastic clip on side of pump mount pull outward and twist pump counter clockwise (i think) remove wires and take pump out clean and reinstall also ck diverter valve beside pump sometimes objects will get into in and not allow internal valve to seat properly
May 03, 2008 | Fisher Paykel EcoSmart GWL15
Honda 8 HP Engine Logo
168 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
