Question about Bunn VPR Coffee Maker
Leaks water from the top resevoire - Bunn VPR Coffee Maker
    President:
  • 635 Answers
Either your fill tank is clogged, or your washer seal is cracked. You will need to remove the top of your Bunn to access this area. In the resevoir you will see a large nut with a drain hole. First try clearing the hole with a tooth pick and pour water in the basin. If it flows you have good drainage. Now, with the top still removed, pour water in the basin while checking for leaks. If a leak is present you should remove your drain nut and inspect the clear white looking washer on the underside. If it is cracked you can replace it with a gasket from Bunn. If you are tight on time and cash, a non rubber heat proof water hose gasket will suffice until yours arrives from Bunn. Replace and re-tighten the basin and drain nut (do not over tighten) .
Posted on Mar 11, 2010
2004 explorer, overheating, coolant bubbling in resevoir
Hi Mike,first thing to do is raise hood,check coolant level in overflow container,if low,there's a leak.look everywhere around top part of engine area for leaks,if none,then get under vehicle and look for leaks with a flashlight.If none are found,then thermostat may be bad not opening all the way causing it to get hot,here's a link on how to remove,get a pot of water and heat to 180 and see if thermostat opens completely.if not,then bad,if it does,then water pump is bad or radiator is partially clogged.Here's how to replace the water pump.Here's how to replace your radiator.Enjoy your free repair guide.
Feb 24, 2013 | Cars & Trucks
I have a 98 jetta glx vr6, every time i drive it the car will over heat. i know that the fan works and turns on and there is no leaks. so i know that there is air in the radiator system. How i bleed or...
Hi. It souds to me like you might have to replce the thermostat in the water pump. If you think there is air in the system, try opening the water resevoir bottle and let the car idle for about 5 minutes, topping up the water as the air voids escape through the return pipe. I doubt that there could be air in the system, as the pump would automaticaly push the air out into the resevoir bottle. Worth a try. Hope this helps
Jun 03, 2011 | 1997 Volkswagen Jetta
2001 kia sportage is over heating but has no leaks. the radiator has been flushed but is very rusty inside. The water is rusty inside the radiator. We have checked the resevoir, it is fine. the water...
Rusty is from running a bad or no mix of coolant. (PH level is off) You may have a water pump that has corroded impellers, and can't move the coolant as well any more. I would start by making sure to flush the engine block again, and make sure you flush water through every possible hose, and where you can get at it.
Jun 14, 2010 | 2001 Kia Sportage
Losing water from the resevoir no leaks or cracks visable on the resevoir water a funny colour.
water weill be a funny colour its the antifreeze in it ?? if the colour is not the same as the antifreeze then check it out because antifreeze will go a funny colour when the combustion gases from the engine mixes with it ,in other words you may have a head gasket problem
Jun 12, 2010 | 2002 Jaguar X-Type
My 10 cup Bunn coffee maker leaks from the top of the water resevoir, from the right top side and from the back top. It looses aprox. 2 cups of water onto my counter while brewing. What has happened to...
I have the same problem and I took the coffee maker apart to find out why. It has to do with a leak on a fitting. On mine I found that the fitting where the hole in the black plastic that the water flows through to get into the stainless steel tank needed to be repaired with some silicone sealant to fix the leak. Still making some coffee!
Oct 09, 2009 | Bunn 10 Cup Home Coffee Brewer
Water leaks out of holes up under resevoir.
Use a Torx T-9 tamper resistant screwdriver to remove the screws on the bottom of the coffee maker.
Your plastic tube has probably come loose or is leaking. Carefully re seat the plastic tube over the metal tube using the metal spring compression clamp.
Jan 09, 2009 | Bunn NHB Coffee Maker
Resevoir leaking on Saeco Trevi(like Vienna)
you have to replace the gasket in your water inlet, if you look where the inlet is you will see there are a little gap between the chassis and the inlet.
Take a screwdriver and bend up the plastic, you will now see the gasket.
The gasket have spare part number: 145842900
Hope this will help you.
/Mirran
Aug 16, 2008 | Saeco Vienna De Luxe Espresso Machine
Bloomfield Koffee King coffee maker
TRY REPLACING THE SEALS IT WORKED FOR ME
May 22, 2007 | Bloomfield 8571 Coffee Maker
Bunn VPR Coffee Maker Logo
210 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
