Question about GE 24 in. Profile PDW7880G Built-in Dishwasher
PDW7880G-No power to control panel. Just stopped at the end of drain cycle
The dishwasher is only 3 years old. worked fine until yesterday. Cycle did not finish draining, and just stopped. No power to display so can no even get machine to start. I checked fuses, and for drain clogs. I also tried pushing to door closed tighter, nothing is working. Any advice???
  • 3 more comments
  • yossit90 Apr 30, 2008
    Have the same DW, same model, the control panel is not working correctly pushing buttons yields random results, reseting the power breaker helps for one cycle then the control panel goes nuts again. Any idea?
  • conejosmike Aug 22, 2008
    I have the same problem, I checked to see if there was power to the unit , and there is. I tried turning the breaker off to reset it and that didn't work. Any suggestions what to try next?
  • Joe Bousquin Feb 03, 2009
    I'm having the same problem. Unplugged dishwasher under the sink for 15 minutes, didn't help with anything. Is this a common problem with this dishwasher?
  • Gary Davd
    Gary Davd May 11, 2010
    you have a pwr issue remove the bottom panel chekat the junction box for proper power.. you then need to chek the door switch to see if it is ok let m know
  • Anonymous Mar 14, 2014
    6 years old, finished last load fine, LEDs inside come on but nothing on display-no power
Solution Found!!
Checked for power to dishwasher. According to the manual, shutting off the breaker for more that 30 seconds resets the dishwasher. It did!!! The dishwasher works fine now. THANKS!!!
Posted on Feb 20, 2008
WATER NOT FILLNG IN GE PROFILE DIHWASHER
It ended up being a simple fix. Soap had dried on the floater (water sensor device) and it could not move, therefore no water was going in. I poured hot water and vinegar into the washer and ran a complete cycle and it is working fine now
Jun 10, 2009 | GE 24 in. Profile PDW7880G Built-in...
Whirlpool Dishwasher won't drain during normal cycle
As you say a clogged line or valve does not make sense.
Try running it without the heated drying and see if it empties or if the cancel button will work then.
The dishes should air dry quickly if you empty it and open the door.
It could be a defective thermostat allowing it to get too hot during the heat cycle
May 18, 2009 | Dishwashers
Error code 2H
The control panel needs to be replaced (indicated by the "2H" error code displayed at the start of the cycle).
BTW - The number 1 displayed at the end of the cycle indicates the cycle has timed out (i.e., it doesn't mean 1 minute remaining). Hence the continued running of the unit. Until you replace the control panel, you'll have to manually cancel the cycle at this point.
Oct 08, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
ASKO 1605
Hi Guys
My dishwasher this morning has desided to not work correctly.
Its a ASKO 1302 about 20 years old. It has been a very good machine.
Over the last couple of weeks during the washing cycle, the dishwasher has been making a loader noise than usual.
1. Today, the dishwasher timer, travels all the way through its cycle, but very little washing take place.
2. Soap power is still there, plates not clean!!!!
3. Water is hot
4. At the end of the cycle, there is no water in the dishwasher.
5. I'm thinking the problem could be the pump needs replacing.
What do you think?
Greg
Sep 05, 2008 | Asko 1375 Dishwasher
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Bosch SHU5316
Sounds like the control module is out -- cost about $100 (I am on my third). I got a "lifetime" warranty when buying my second one. If you are handy, you can replace it yourself. You can call Bosch to confirm this (I did). It mounts inside the door.
Apr 15, 2007 | Bosch 23 in. SHU5302UC Built-in Dishwasher
GE 24 in. Profile PDW7880G Built-in Dishwasher Logo
868 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
