Question about Nintendo Wii Console
Disk will not eject> - Nintendo Wii Console
I am constantly receiving this message with a micro 2 GB cruzer, "The disk was not ejected properly. If possible, always eject a disk before unplugging it or turning it off. To eject a disk, select...
I have just experienced this problem with e 32Gb ScanDisk card. Every 40 seconds it dismounts with "The disk was not ejected properly. If possible, always eject a disk before unplugging it or turning it off." and the automatically remounts itself.
The card was formatted in my Canon camera and works fine, I also can read the files with iPhoto from the camera, however with a LogiLink card reader it has the above described problem on my MacBoook Pro with MountainLion OS.
Its about time Apple that you researched and found a solution!!!!
Hans Steller
Jul 04, 2012 | SanDisk Cruzer Sdcz36-002g-b35 2 Gb Flash...
Ejectiing a disc
f you're told you can't eject a disk, try the following suggestions.
f you're trying to eject an external disk:
  • Choose Apple menu > Log Out, and then log in again. Try to eject the disk again.
  • If you still can't eject the disk, choose Apple menu > Shut Down. Disconnect the disk from your computer, and then start up your computer again.
    If you're trying to eject a CD or DVD:
    • Choose Apple menu > Log Out, and then log in again. Try to eject the disc again.
    • If you still can't eject the CD or DVD, choose Apple menu > Restart. While your computer restarts, hold down the mouse button or trackpad button until the disc is ejected.
      If you're trying to eject a network disk:
      Choose Apple menu > Log Out, and then log in again. The network disk should be gone.
Jun 11, 2012 | Apple Air Computers & Internet
Need to eject
If you're told you can't eject a disk, try the following suggestions..
Jun 11, 2012 | Apple Computers & Internet
WD external hard drive mac
Sounds like your external drive might be bad. Try connecting it to another system and see what happens. If you can't get to read data on another system, the drive is bad.
May 29, 2012 | Western Digital My Book Essential Edition...
Port will not open to insert a disk
here is a small trick that can help you to eject a drive.
restart the computer. In front of the drive ther will be a small tiny hole.
insert a paper pin into the hole and press it gently. The drive would eject out.
You can also try
start->run->type"devmgmt.msc"
click on the + symbol of CD/DVD drive. .rt click on it->select uninstall.
restart the computer and check .it will work.
May 21, 2012 | Dell Dimension 4600 PC Desktop
My hp laptop keeps ejecting disc itself when i insert any disc. Wat do i do pls
> keep ejecting
The disk-drive is having a mechanical problem, i.e., it is not fully-loading the disk,
or it is not detecting that the disk is fully-loaded. Therefore, it assumes that the open/close
mechanism is "jammed", and so it ejects, to indicate that the disk-loading was not completed.
Replace the disk-drive.
Jun 26, 2011 | HP Computers & Internet
How do I eject a disk from my dell model 1737 studio lap top(window vista) . It made noise are clicking sound when it went in.
Hello Reg,
The CD/DVD rom is tray type then use a pin to eject the tray. There is small hole in front of tray plate.
Insert the pin in the small home and press smoothly and the tray will eject .
If the CD/DVD rom is different type then use long steel V shape clip to pull the disc.
Apr 14, 2011 | Dell Studio 15 Laptop
Cannot access DVD drive. Shows as BD-ROM and does not show disk. I'm only able to eject the disk by starting in setup mode.
1.control panel->system->hardware->DEVICE MANAGER 2.uninstall your driver 3.restart you computer 4.on tray icon a balloon come with a MSG of 'found new hardware' 5.click on it 6.select your driver from it .then select suitable option
if you still have problem buy a you op(win xp,vista,7..).using that disk repair you computer
Feb 27, 2011 | Dell (WT927) DVD+RW Burner
How do I remove a disk from my desktop hybrid computer?
press the eject button on the pc or go to the drive where the cd is and RIGHT click on it--> select EJECT option. the CD rom will open and the disk will be out.
Thanks for rating good luck
Feb 05, 2011 | Dell Studio Hybrid Desktop Computer
Citizen c479dvd player will not eject disk says ''Key Lock On'' We have tried everything but we can't turn off the player or eject the disk. We can FF or Rev and switch to other songs but we are stuck with...
Hey.. I was having exact same problem, and couldnt find answer anywhere online, so i actually called citizen.
SO>>> hopeuflly u have ur remote.
Push setup.. then push 00083 then enter.. and there ya go.. problem fixed. YAY>.
If u dont have remote.. not too sure. but heres there number.
18006635954
Mar 17, 2009 | Televison & Video
Nintendo Wii Console Logo
41 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
