Question about Hotpoint WMA50 Front Load Washer
Hotpoint WMA50p won't spin
My Hotpoint wma50p won't spin ? When you load it and select a programme it fills with water then nothing ! If you put it on spin only it emptys the water but no spin ! I've checked the belt, cleaned the filter and motor brushes which are fine plenty there. If you leave the machine on and the water in it cools down the heating element starts up and reheats it to the required temperature but still it won't spin or go through any cycle apart from the start ie fillling.
Many thanks
Steve
  • 2 more comments
  • Bantman Feb 19, 2008
    Thanks for reply
    what do you mean by PWR (pre-wash and rinse ) . I'm coming round to the idea that it is something to do with the controller board but how can i check this
  • Bantman Apr 14, 2008
    Found the solution to mine. One of the dampers came loose this through the drum around which loosened the contacts on the motor . Did the same removed and refitted the brushes and It all works fine now
  • jatenderkoul Oct 23, 2008
    I moved my washing machine, Connected water pipe, and extended the hose to the sink point,
    As i started the machine, water start filling, and then nothing happens and continues like same......
    not sure what happen wrong? can some help?
  • Gary Davd
    Gary Davd May 11, 2010
    you will need to check to see if you have pwr at the motor controller board first
Had same problem today with our machine. Brushes looked OK (although one appeared a little shorter than the other).
After removing and re-fitting the brushes, motor worked fine - suggesting that it was the brushes afterall.
Now looking for replacement brushes
Posted on Mar 27, 2008
Hotpoint WMF760 fills with water but doesn't move through programme
Bad motor/ DC power inverter control assembly. My suggestion is don't buy electronically controlled washing machines. They're designed to stop working and for corporate to sell you parts and service again and again and again, until you go buy a rebuilt second hand fully electro-mechanical good ole reliable mechanical top load washing machine.
Feb 07, 2014 | Washing Machines
Machine does not seem to be filling properly, then does nothing else.
Sounds like you're fill valves are junk which sadly happens allot. This video is very generic but should give you an idea
Jul 06, 2017 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint ultima washing machine wma74 drum not turning
If the machine wasn't excessively noisy before and when you select spin only you can't hear the motor running its likely to be the carbon brushes in the motor worn down till they no longer contact stick a new set in if the carbon length sticking out the brass holder is less than around half an inch long
Dec 08, 2013 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint aquarius 1000 (wma50p) not taking in water, and i cannot move the drum by hand.
Hello, it sounds like the main motor has blown. This causes the pump to stop as it is connected to the pulleys and gearbox. The only solution is replacing the main motor. Even though it sounds expensive, it should only cost around $100 plus fitting.
Mar 23, 2011 | Hotpoint WMA50 Front Load Washer
Select program, water fills then nothing happens. Have to cancel program to empty water to retrieve washing.
hello sorry to say sounds like the programmer may be the trouble i was luck when i repaired mine there were dry joints on ther circuit board on the back of the programmer it's worth a try if you know someone that can use a soldering iron good luck
regards
shaun
May 30, 2010 | Hotpoint WMA50 Front Load Washer
Hotpoint wma76 stops and displays ON
Could be rinse water valve ..Faulty Solonoid coil
Nov 10, 2009 | Hotpoint WMA76 Front Load Washer
Hotpoint WMA30 Front Loader Not Pumping Out but still fills if put on rinses, on spin tries but gives up
no easy way to get water out but try putting drain hose down at floor level into a bucket and that may work
fault is probably filter blocked.
to access filter, take rear back panel off. you will see a large diameter hose going from bottom of tub to pump. disconnect this hose at tub end - carefull, water will come out. filter is inside this hose. take it out, clean and reassemble
Oct 02, 2008 | Hotpoint WMA30 Front Load Washer
"Test" displays no washing done!
Your test mode is on, maybe accidently. Press "start", "cancel", "on" & "off" together for 10 secs, you will see d/off come on the display. Do the same & the test mode comes on again.
Rate pl.
Dec 02, 2007 | Hotpoint Ultima WF860 Front Load Washer
Washer will not spin
normally i would suggest changing motor carbons for hotpoint washers, but my experience is that the WMA motor armature is weaker than the carbons, normally if there is no connection fault a replacement motor is the answer 9 times out of 10, not a job for the amature
Aug 28, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint WMA50 Front Load Washer Logo
393 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
