Question about Sony Playstation 3 (PS3) Console
I just bought a new hdmi cable for the ps3.When I play a DVD there is only audio, no video. What do I do now??
    Problem Solver:
  • 10 Answers
Try wiggilying the hdmi cable make sure it has a good connition
Posted on Feb 01, 2010
RX-V465 Yamaha Reciver we can get picture but no sound w/PS3
Check HDMI Sound settings:
Enter Setup menu via remote, then Func. Setup / HDMI / Audio. You can choose from Amp (sound will be played via Yamaha), TV (sound will go straight via HDMI out to your TV and not play on Yamaha) and Amp+TV (Yamaha will play the sound and also pass it to the TV).
Also what is your source? DVD or some network player? For example Yamaha cannot decode audio in AAC or other computer formats, so be sure to change the audio settings of your player to output PCM and not raw/bitstream.
Mar 26, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
All picture and no sound
Rick:
simply unplug--then replug--your HDMI cable. Or also go into the audio setup menu and reapply the "automatic" setting for HDMI to get the sound to work. I don't know if Sony can do anything about this or not in a firmware upgrade, but what it can do is try to simplify the labeling on some of the sound settings.
Let me know
Dec 26, 2007 | Sony Playstation 3 (PS3) Console
Setting audio to optical makes hdmi video not work
Here is the solution - in the audio settings you have to select optical out or it will still use HDMI. Regards, Joe
Feb 13, 2010 | Sony PlayStation 3 Slim Black Console
MX 3950D Philips - PS3 no sound
Aside from the xbox360 working via the coaxial digital cable. I got the PS3 to work this way.
I had to use the supplied SCART > (Y-video) (Red-Audio) (White-Audio) cable. Basically plugged this in from the PS3 directly to the MX 3950D Aux (Auxiliary) audio input.
On the PS3 audio settings menu, switched from HDMI to the 3rd option SCART.
Turn on the MX 3950D and set to Aux. Bang, got sound again.
I missed this cause I "assumed" the video/audio cable that came with the PS3 was a HDMI to Audio/Video cable, and didn't even see the SCART port in the back of the PS3. So I thought I didn't want to lose 1080p ..etc etc. Anyways. MX 3950D still good =)
May 18, 2009 | Philips MX3950 System
Ps3 plays audio but does not show image on tv
Well you can just use the hdmi cable if you're going both audio and video in to your tv. With your hdmi cable you get the best quality for both.
But in anycase, it seems that your PS3 is set up to output video via HDMI cable. To reset our video output settings, simply power down your PS3 (turned off) and hold down the power button until you hear the second beep. (around 5-10 secs) Power back up and hopefully you'll have video via your av cable. Hope this helps.
Apr 22, 2009 | Sony Playstation 3 (PS3) Console
Unable to get ps3 to play when hooked to receiver
The audio inputs on the receiver need to be set to receive the Optical signal on the switch you set the ps3 to. ie Game, DVD, AUX. Each switch needs to be set to receive the audio signal coming into it. Usually on the remotes setup feature.
Feb 10, 2009 | Denon AVR588 Receiver
No surround sound from my PS3 through the Onkyo 5100. Video OK
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
thanks.
Jan 24, 2009 | Onkyo Audio Players & Recorders
Have purched a hdmi cable for my playstation 3 but have no sound
ensure the regular composite cables are hooked up to determine whether audio is bad. (the yellow red white cable) ...unhook your HDMI cable for now....
Nov 11, 2008 | Sony Playstation 3 (PS3) Console
Hello can you help with this error!
When you switch from one cable connection to another (Hdmi to AV etc) you need to reset the PS3 to its default settings. Basically what is happening is, your PS3 is set to HDMI, so when you plug in AV cables it doesn't know it. So you have to reset it. Hook your PS3 up to whatever cables (make sure system is fully off) then hold the front power button down for a few seconds.
Doing this will reset the display settings. You can then go into the XMB (main menu) and choose your connection. Although the PS3 should do this during the start up on its own.
Hope this helps.
Sep 05, 2008 | Sony Playstation 3 (PS3) Console
HDMI sound?
I had the same problem with my PS3. I have a HD cable box with HDMI out, a Sony DVD player with HDMI out. The Sony receiver STR-DG800 only has the HDMI inputs (sat/tv and dvd) and the HDMI is only a pass through port and will not decode audio.
I purchase a HDMI 4 port switch from Newegg (HS-41A0 http://www.newegg.com/Product/Product.aspx?Item=N82E16812168003&Tpk=HS-41A0) to hook up the DVD and PS3 to the DVD HDMI and switch between the DVD player and the PS3. It took me several days to figure out how to make this work with the settings on the reciver.
1 the DVD player must use the coaxial in jack for sound on the receiver.
2. the PS3 must use the optical connection on video1
3. the sound settings in the PS3 must be set to PCM
4. set the sound setting on the receiver to the following
a. on the remote press AMP button then the MENU button, next press the down arrow to you see 5- AUDIO SET - then press enter.
b.set sound decode priorty to PCM
c. next scroll down to you see digital assign - press enter
assign VID1 OPTICAL to DVD ( this allows the pcm output from the PS3 to play through the receiver), next assign DVD to COAXIAL setting DVD to DVD (this allows the digital sound to play from your DVD player).
So when you use your remote and select DVD, you can use your PS3 or DVD through the 1 DVD HDMI port.
Feb 04, 2008 | Audio Players & Recorders
Sony Playstation 3 (PS3) Console Logo
22 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
