Front load washer 2006 model Smartwash Elite - stops during cycle - shows flashing red F - control buttons do not respond to any commands -problem occurs randomly
    Brigadier General:
  • 3,917 Answers
Guess the code is F H, if you check it once more.
However F H means that no water was detected entering machine
is the water coming fast ?
If indeed the water is fine than there is a sensor called a flow meter that tell the CCU if and how much water has entered.
It also uses a water level pressure switch to monitor water level.
Take the top off the washer and locate the sensor. There is a wheel in the plastic casing and it tells the CCU how much water is coming through. However it might have some calcium built up in the casing, tap it a couple of times and reconnect everything back. The sensor is easy to find. It is the one that is connected to the hot and cold fill valve and then it goes to the white sensor.
Thanks for contacting fixya.com
Posted on Feb 01, 2010
My kenmore elite smartwash/he4t
The "F11" fault code will display if the Motor Control Unit (MCU) has an internal failure; repeating under or over voltage, or over current conditions. If failure occurs during high speed spin the door unlocks after 3 minutes. The MCU (Motor Control Unit) is located beside the motor. Here is the part to order.
Dec 02, 2012 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite smartwash and the machine says contols locked, is there any way to reset that?
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 25, 2010 | Kenmore Elite 45986 Front Load Washer
It says "Control Locked".
Sep 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
WHAT IS A CL CODE ON MODEL 796.41022900 FRONT LOAD KENMORE ELITE WASHER,IT SHOWS INTERMITTENLY DURING WASH CYCLE
Means someone put it in controlled lock position. Just hold the Control lock button down for 5 sec or so until the light comes off. Machine isn't malfunctioning.
Jul 31, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite is now LOUD during spin cycle
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Jun 11, 2010 | Kenmore Elite 45986 Front Load Washer
My kenmore elite smartwash flashes f and dl when i try and run the wash cycle
Hi
Thanks for using FixYa. Error fdl means a Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
It has occurred due to
1. Door lock mechanism is broken or removed from door.
2. Door switch/lock unit failure. To unlock it follow the steps—
a. Unplug washer or disconnect power.
b. Check door switch/lock unit.
c. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Please revert for further assistance.
Thanks
Rylee
Jul 21, 2009 | Kenmore Elite 45986 Front Load Washer
F11 CODE FLASHES DURING THE SPIN CYCLE
this is a central command error and its something to do with either motor or control
module
Jun 11, 2009 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
