Question about Lexmark X5470 All-In-One InkJet Printer
The paper starts to go thru the feeder but 3/4ths of the way through it will not continue to feed through. I looked thru all your instructions for jams, and there are no jams in the feeder or anywhere else in the printer.
  • Official Brand Answer
  • 3,344 Answers
Hi, this could be something related with the firewall of windows or from the software that you are using. Here is a link a solution document specific for this kind of problem and how to resolve it. http://bit.ly/csdYUJ
Posted on Feb 09, 2010
Lexmark 4650 paper wont feed when printing. It starts the feed process but does not catch the paper. when it does it will take several sheets.
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
6. If cartridge area is clear, close the cover.
7. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print a document again to verify that the problem is fixed.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 20, 2011 | Lexmark X4650 InkJet Printer
Hello. I have a Lexmark x4650 printer/scanner/copier and the paper starts to feed thru and then pulls to one side. I am then unable to print my document. Why does this keep happening and how can i solve...
Try to remove the sheets of paper from the feeder. Grab a flashlight and look into the feeder for any foreign objects that might have accidentally fell into it. If feeder is clear, open the printer cover and remove the cartridges. While the printer cover is open, check inside for any obstructions in the paper path. If none, then close the printer cover. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reinsert the cartridges. Close the cover. Load some paper (avoid overloading). Try to print again.
Jun 21, 2011 | Lexmark X4650 InkJet Printer
The belt inside my scanjet 4200c has come off. How do I reattach it? I have opened the scanner. It looks to be relatively easy but I don't know how to attach the belt to the motor etc
Instructions
1 Lift the hatch on the feed tray and pull up the large green tab to the left of the roller. Remove any jammed or torn paper from under the roller and around the feed tray.
2 Pull the input feed tray out of the automatic document feeder. Grasp the feed tray with both hands and pull it straight out.
3 Check the interior of the automatic document feeder for jammed paper. Remove any jammed paper, then reinsert the feed tray into the automatic document feeder. Push down the feeder cover until you hear a click.
Mar 08, 2011 | HP Scanjet 4200c Flatbed Scanner
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    Paper won't feed into printer
    I have taken a piece of cardboard, like the ones you get with a new shirt, size it to 8.5 x 11, and tell the printer to print a test page. hand feed the cardboard thru, and most times it will clean out the residual paper pieces stuck in the internal rollers. I have used this method several times and was successful 99% of the time. It isn't rocket science, but It may work. You will probably have to push the cardboard thru, but do not force it to much. It will not go thru easily on its own. Just a suggestion.
    Jun 17, 2009 | Epson Stylus CX3810 All-In-One InkJet...
    PAPERS WONT FEED THRU TOP FEEDER
    im having the same problem was working fine then quit feeding
    Mar 31, 2009 | Minolta EP4000/5000 CS/PRO Copier
    Copy of documents misaligned vertically on Canon Imagerunner 3045
    Hello sir; When you feed originals in portrait, the paper tray have to set by portrait direction too.
    Mar 30, 2009 | Canon Office Equipment & Supplies
    Paper feeder
    clean the rubber roller with alcohol this roller gets dirty all the time...this feeds the paper...im trying to upload my drawing..to guide you..
    Feb 09, 2008 | Canon S520 InkJet Photo Printer
    Lexmark X5470 All-In-One InkJet Printer Logo
    49 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
