Question about Garmin GTM 12 FM TMC Traffic Receiver Receiver
I have a GTM 25; the usb connector was smashed; where can I buy a new connector to solder?
  • rpb6 May 11, 2010
    how old is the gtm 25
2 Suggested Answers
SOURCE: Where can I buy a
I have the same question.
Posted on Nov 26, 2011
How do i repair a obd connector
What's wrong with it?
1. Wires connecting to it? Splice or solder them.
2. Connector smashed or other physical (not electrical) problem? Get a used one off a junker (virtually any model) and splice/solder your car's wires to corresponding terminals on the new OBD connector.
May 25, 2014 | Saab 9 Cars & Trucks
Garmin nuvi 760 charging problem
The wire may be defective, especially where it plugs into the connectors.
Nov 25, 2013 | Garmin Nuvi 760 Car GPS Receiver
Akai mpk broken conector
Its a lot simplifier than that really.. all you need to do is unsolder the old one and re-solder the new one.. The pins and connectors are standard.
Dec 30, 2012 | Akai MPK mini MIDI Controller Keyboard,...
Garmin GTM 25 charger cord has broken wire inside.
Most likely that is the FM antenna lead that goes to the traffic receiver. It should only be connected on the end that goes to the receiver.
You say the GTM-25 is not charging. Is the fuse blown? The charger takes +12VDC from the lighter socket and supplies +5VDC to the GPS.
Dec 15, 2011 | Garmin GPS
Usb port broke and missing which doesn't turn on, this happen because when i would charge the mp3 it would hang and get loosen until it came off,i' vied took it aprt but nothing so i been looking for...
You can buy a new USB female connector and solder it on the PCB of your MP3 player.
You will need a female Mini-USB Type B connector, a soldering iron with a fine tip, flux and some solder wire.
1. Open the case of the MP3 player and look for the spot the lost USB connector was soldered on. 2. Clean the pads with a cotton swab and some clear alcohol. 3. Clean the female USB connector using the same method. 4. Heat up the soldering iron to a moderate temparature. 5. Put some flux on the solder pads. 6. Place the female USB connector on the pads and solder it on by touching the soldering iron and the solder wire on the pads until a tiny drop of solder makes the connection. The solder should flow on the pads because of the flux. 7. Re-assemble the MP3 player.
You can then test the connection using a multimeter.
Mar 15, 2011 | RCA M4204 MP3 Player
THE GARMIN GTM 25 NEEDS A NEW FUSE.THE FUSE IS F 1AH 250 V. I NEED TO KNOW WHERE THE FUSE IS ON THE UNIT, AND HOW TO TAKE OUT THE OLD ONE AND REPLACE IT WITH A NEW FUSE.
un screw the the tip of your charger that fits into the cigarette lighter, it is inside, be careful not to lose the spring, but if you do, a spring from a pen will work, i dont think you can buy one from garmin
Oct 30, 2009 | Garmin GTM 12 FM TMC Traffic Receiver...
Hook Up possible for EPSON Stylus 880 to new computer w/USB ?
There is no conversion cable that you can use with parallel connector since USB transfers data in Serial mode and the parallel cable handles data in Parallel mode.
Sorry.
Mar 01, 2009 | Epson Stylus Color 760 InkJet Printer
Garmin GTM 12 FM TMC Traffic Receiver Receiver Logo
118 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
