Question about Brother MFC-8460N All-In-One Printer
Trying to send a fax error: Poor line condition/ Out of memory
    President:
  • 2,306 Answers
Make sure by making a copy that your scanner is OK, streaks or black bands won't send properly and you need a new scan assembly, Poor line condition is just that, you need a better line or cable, If you go to fax settings and turn off error correction mode it sometimes helps as well.
Posted on Feb 01, 2010
OUT OF MEMORY
Hello laray7813,
Please visit this link to know exactky what NG means and how to solve it.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000200/000009/faq000209_000.html?reg=us&c=us&lang=en&prod=mfc420cn_us&Cat=12
If this dosent work, let us know and we will find other solutions,
Dahaka
Jul 22, 2008 | Brother MultiFunction Center MFC-440CN...
Can't send fax. Getting transmission verification report stating NG: poor line condition/ out of memory. HELP!!
There are two possible reasons why your printer display the error message.
1. Poor Line Condition
- electrical interference on the line -Make sure electrical or electronic appliances do not interfere with the printer's phone line
- poor line connection - If you have a phone try connecting it directly to line outlet. Listen to the dial tone, if you hear noisy and static, then you will need to call your local telephone company cause there is a problem in your phone line. If dial tone is clear and stable then try checking the telephone line cord that you use to connect your printer from the line outlet, replace if broken.
- alarm system or another device on same line, these interferes with transmission / reception of the fax machine. Try connecting the printer all alone and then try sending a fax.
2. Memory Full
- There is no space to store incoming fax messages. Delete all stored fax messages.
Apr 09, 2011 | Brother MFC 6490CW InkJet Printer
Mfc-9840cdw scan poor line condition out of memory - how can this be solved. i feel so dense because it appears your site has already offered solutions but i can't even find them there!
Poor line condition / out of memory is almost always caused by poor line condition.
This is to say that there is a problem trying to send because the signal is not going through clearly enough.
This error can be due to either your fax machine or the receiving ends fax machine.
Try sending to other numbers as a test to see if it works for other numbers (you can use 1-866-685-8587 for the brother test line)
If you get the same error no matter who you send to, you may want to try another jack or telephone cable.
If you are using a splitter, try without the splitter.
Thanks,
Pat
Apr 01, 2010 | Brother MFC-9840CDW Laser Printer
Our MFC 7840 printer when faxing keeps saying
Depending on your location the line coulod well be poor quality for a sensitive fax. Any spurious sounds on a fax line will cause it to fault.
May I suggest you try the fax on the mainline first before assuming the unit is at fault.
Length of line from point a to b can also reduce the efficiency of signal. It may sound ok to the ear, but resistance may be the factor in reducing the level of the tone that the fax requires to hear and then activate send or receive.It reports poor line condition and even poor memory because it keeps loading to send.
If it does it on the mainline as well then I would be considering a technical call for help. There may be a fault in the unit.
please rwte my help++++Thanks for using FIXYA
Nov 24, 2009 | Brother MFC 7840W Printer
Consistently receiving poor line condition error
The other fax machines are not on the same line though, right? Try installing a line filter.
Jul 10, 2009 | Brother IntelliFax 1860C Plain Paper...
MFC-440CN PRINTER fax error
Plug a phone into the line and listen for static. Too many phones on the line, bad lines,etc, can cause a poor line condition. Try the unit directly into the phone line, no answer machine or anything else on the line. Maybe the memory thing is it has a lot of faxes that it hasn't been able to send.
Apr 29, 2009 | Brother MultiFunction Center MFC-440CN...
Help with outgoing faxes
Unplug the power cord for 30 seconds. Are you trying to fax on a DSL or any other kind of digital phone line?
Jul 03, 2008 | Brother IntelliFAX 5750e Laser Fax
NG: POOR LINE CONDITION / OUT OF MEMORY
You can adjust the Compatibility mode. This adjusts the sensitivity of the machine to interference on the phone line by lowering the transmission speed:
a. Press Menu, 2 (Fax), 0 (Miscellaneous), 1 (Compatibility)
b. Press Up or Down arrow to select "Basic"
c. Press OK.
d. Press Stop/Exit.
e. Try resending the fax.
If the problem continues we recommend you try the unit on another line at the current location or another location. Always restart your machines after you made changes, that way you will see the results.
Feb 26, 2008 | Brother IntelliFAX 5750e Laser Fax
Brother MFC-8460N All-In-One Printer Logo
1,124 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
