Question about Vertex FNB-27SM, YAESU,FT-26,FT-76,FT-415,FT-416,FT-815,FT-816,FT-530, 12v 1500mAh NiMH 2-Way Radio
Ft 26 reset
I have a Yaesu FT-26, after replacing the backup battery, the unit does not work, nor transmit or receive.
Reset as indicated in the user manual does not produce any effect.
There is another type of reset more from those two of the user manual?
Benimur
  • 6966 Answers
SOURCE: Yaesu Ft-60R with Kenwood TK-3107
Initially and the simplest probably would be to use the units without enabling the CTCSS or any form of encoding (turn this feature OFF). In the meantime, will check the specs and post if anything concrete comes up.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 31, 2008
SOURCE: my transceiver yaesu ft-one can't received/monitor and transmit
Thanks 4 your advice.
I left the radio w/o any batteries (the only battery is back up memory battery) in that time, and when I try the radio I used new batteries. The power supply for the radio is build in (uses 30 amperes switching power supply) and I have checked that the power supply is in a good condition. I suspect that PLL unit is not working so can't oscillation to generate frequencies.
The problem with sending the unit to the factory to be serviced is not worth (cost > benefit/ radio value).
Do you have another idea to help me? Please.. Thanks
Posted on Nov 06, 2008
SOURCE: Yaesu FT 11R
figured out how to solve this, with the radio off, push and hold both up and down scan buttons, while powering the radio on. This will fix the problem.
Posted on Jan 10, 2009
mohammed387
  • 1952 Answers
SOURCE: manual yaesu ft-10r
www.radioamateur.eu/schemi/FT10_40_user.pdf
Posted on Jun 29, 2009
  • 13 Answers
SOURCE: I need to replace the internal lithium battery on
I have a Yaesu FT-415 and the same problem. My original battery is a SONY 1220-VJ2H (solder tabs, blue insulation on the outer edge and two stick-on paper insulaters) and is soldered in to the Control PC board (mounted vertically). I'm going to get a new battery and hopefully am brave enough to get the soldering iron to the board. It looks like you have to unsolder the board from the speaker to lift it up enough to get at the solder tabs on the battery, luckily I have access to a Pace soldering station with a vacuum pump. I'll hopefully try this next week and get back to you all.
Posted on Jul 11, 2009
Radio power`s on but no transmit or receive on ssb however it will transmit with full power on fm
If your receiver was operating previously but now the SSB option is not working, very likely the sideband detector has failed. I'm not directly familiar with your Yaesu unit but, in most Yaesu transceivers, the SSB chip and control circuit (including diodes) is identified in print on the main board.
May 16, 2015 | Yaesu FT-990 DC Transceiver
Yaesu 270 not transmitting nor receiving
Hi this can be down to many reasons, radio keypad locked, receive on tone squelch, set on "Relay" or "Repeater", or even radio failure. Without the radio I cannot help, but that may give you some ideas.
Feb 14, 2015 | Yaesu Ft-270r Vhf Ft 270r Ft 270 R
Yaesu ft 416 ver a2 need reset to get extended receive
You may find detailed instructions for this on www.mods.dk
Jul 03, 2011 | Vertex FNB-27SM,...
Hello! I've a couple of battery packs yaesu FNB27. The old NiCad batteries do not work. I want to replaced it by new LiH type. What is the best way to open the battery case without damaging it? thanks...
It's difficult to open the Vertex packs without ruining them. FNB27 is widely available on eBay or you can get them from manufacturers such as W&W in Hicksville NY online. I don't know if anyone has made them in Lithium Ion yet.
Mar 13, 2011 | Vertex FNB-27,...
I need a new battery for a yaesu ft 26
Try "Batteries Plus" either online or possibly a local outlet. I found the batteries for my FT51 there and half the price of the factory ones.
May 19, 2010 | Vertex FNB-27SM,...
I need to replace the internal lithium battery on a yaesu FT-416 - how do I do this?
Jun 17, 2009 | Vertex FNB-26,...
PPT works in the lower bands (under 148 Mhz) but not 156 range
Your radio has not been modified to transmit outside of the amateur bands.
Jun 07, 2009 | Yaesu NABC NABC LMR NICD BATTERY FNB-29...
Yaesu FT-416 not Transmitting
Check the connection going to the BNC antenna connector from the circuit board. I have seen this wire break before. KB9EKH
Feb 24, 2009 | Vertex FNB-27SM,...
Yaesu FT-26 I got a Yaesu FT-26 that is used. The Problem by it is that its frequence between 140.000 and 148.000, i cant get lower or higher than, I cant even send or recieve anything!!! even when i press...
Same problem for me also blocking on the tape amateur 144/148 MHz not of emission nor of green reception led does not ignite malgres the modifs. Have a solution thank you
Feb 23, 2009 | Vertex FNB-27SM,...
Yaesu ft-815
Double check that "TSQ" is not enabled. In the menus you can fine "SQL" and select the type of squelch. If you have "TSQ" selected you'll only hear signals from radios that a re transmitting the CTCSS tone selected.
Jan 21, 2009 | Vertex FNB-27SM,...
Radio Communications Logo
341 people viewed this question
Top Vertex Radio Communications Experts
enb54
Level 1 Expert
Steve
eradiostore
eradiostore
Are you a Vertex Radio Communication Expert? Answer questions, earn points and help others
