Question about HP DeskJet 5550 InkJet Printer
I have an HP deskjet 5550. I had a paper jam earlier but cleared it. After reseting, warning light still comes on. Printer makes clicking noise when I first turn it back on.
  • 2 more comments
  • Calvin W Boaz Feb 01, 2010
    Had printer about three years. I wouldn't think any paper would still be jammed. Cannot see anything jammed and paper that was removed when printer jammed has no rips or tears.
    It is the print cartridge status light that is blinking.
    The status light blinks after I turn printer on and the lights on the side move around and the cartridges move and the thing under the cartridges spin. After everything stops, the light just stays blinking.
    Confused-don't see yellow arrow on top of print cartridge. Cartridges was fine before jam, both color and black in cartridges are either brand new or just week old.
  • 4,472 Answers
First off how long have you owned the printer? There are several possibilities at this point. Possible paper still jammed or damage done to a part while clearing the jam. Once I have more information I can assist you further.
Thank you,
Lee
Posted on Feb 01, 2010
  • 3 more comments
  • Lee A.
    Lee A. Feb 01, 2010
    Ok can you tell me exactly what lights are blinking and when. usually it can be one or two lights and they may blink simultaneously or alternately. It may be very possible that the printer might need repair but I will need more information. If so you would definitely want to consider replacing the printer you can get a printer with much higher quality for as little as 40$.
    Thank you,
    Lee
  • Lee A.
    Lee A. Feb 01, 2010
    The print cartridge light is blinking, and the power light is on.
    The top access door on the printer might be open, or there might be something wrong with the print cartridge.
    Solution
    1. Check to make sure that the top access door is firmly closed.
    2. If
      the light continues to blink, open the top access door. When the top
      access door opens, the print carriage moves so the yellow arrow on top
      of the print carriage points to a drawing of a cartridge. Each drawing
      describes a symptom. Find the drawing in the following table, and then review the solution as necessary.
    1. Drawing inside the access door
      Problem identified by the drawing and the solution
      Problem
      The color cartridge is missing, improperly installed, or defective, or the wrong print cartridge is installed.
      Solution
      1. If there is no color cartridge in the print carriage, insert a color cartridge.
      2. If there is a color cartridge in the print carriage, remove the color cartridge and firmly reinsert it.
      3. Make sure the color cartridge is appropriate for the printer.
      4. If the problem persists, replace the color cartridge.
      Problem
      The black cartridge is missing, it is improperly installed, it is the wrong print cartridge, or it is defective.
      Solution
      1. If there is no black cartridge in the print carriage, insert a black cartridge.
      2. If there is a black cartridge in the print carriage, remove the black cartridge and firmly reinsert it.
      3. Check to make sure the black cartridge is appropriate for the printer.
      4. If the problem persists, replace the black cartridge.
      Problem
      The color print cartridge is running low on ink.
      Solution
      Replace the color print cartridge with a new color print cartridge.
      Problem
      The black print cartridge is running low on ink.
      Solution
      Replace the black print cartridge with a new black print cartridge.
      Problem
      None. The print cartridges are working correctly.
      Solution
  • Lee A.
    Lee A. Feb 01, 2010
  • Lee A.
    Lee A. Feb 01, 2010
    The print cartridge light is always on.
    Solution
    1. Open the top cover.
    2. Unplug the power cord from the back of the printer. Unplug the power cord from the wall outlet. Wait a minute or so.
    3. Plug the power cord into the back of the printer. Plug the power cord into the wall outlet.
  • Lee A.
    Lee A. Feb 01, 2010
    I would visit the link I gave you and try and decipher the exact error code you are receiving with the lights. Also I would try the last suggestion I have gave you as well.
    Thank you,
    Lee
Tip
I followed the steps outlined by nanicool to remove jammed paper from an...
Please perform the below steps.
1. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
on Jun 24, 2008 | HP OfficeJet 4255 All-In-One InkJet...
Doesn't print - carriage makes a clicking noise and power/paper lights flash
To confirm once again remove off the printer, reinstall the software, then connect the printer to be installed once again.
Now repeat the test print on the printer, if there is no response, check for the motor mechanism for jamming. Also see that the ink cartridge is moving well if not release any jamming possible from any objects.
If there is not response even after this the servo controller/ processor of the printer is faulty.
Possible error in the main board
Sep 14, 2010 | HP DeskJet 5550 InkJet Printer
Hp Deskjet 5550 making grinding noise then stops.
Here is a page explaining how to resolve this issue:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=71895&prodTypeId=18972&prodSeriesId=71895&objectID=c00681585
Apr 21, 2009 | HP DeskJet 5550 InkJet Printer
Constant yellow blinking light, no paper jam
I found this on the HP support site:
The power light is on, and the resume light is blinking.
c00109831.gifc01272271.gifc00109834.gif The printer might be waiting to complete a print job or to receive data from your computer.
Solution
Wait for the printer to finish the current task. The printer is waiting for the ink to dry on freshly printed paper.
Solution
  1. Remove the paper with fresh ink.
  2. Press the resume button.
The printer might be out of paper.
Solution
  1. Load paper in the paper tray.
The printer might have a paper jam.
Solution
Clear the paper jam. If the resume light continues to blink after the paper jam is cleared,
OR
if the print carriage is stuck or making a grinding noise, then follow these steps.
Solution
  1. Lift the top cover of the printer.
  2. Turn the printer off and then on again.
  3. Unplug the power cable from the back of the printer when the grinding noise starts. Unplug the power cable from the wall outlet.
  4. Movethe print carriage toward the middle of the printer (this proceduremight take a couple of tries to get the timing correct).
  5. Remove the print cartridges and close the top cover.
  6. Plug the power cord into the back of the printer. Plug the power cord into the wall outlet.
  7. Open the top cover, reinstall the print cartridges, and then close the top cover.
The printer may be ready to eject banner paper.
Solution
Press the resume button to eject the banner paper.
Mar 14, 2009 | HP DeskJet 5550 InkJet Printer
Printer cartridges not moving
Try turning the printer off and unplugging it both from the wall and from the computer. Take the paper out.
Open the paper jam door and gently push the paper roller forward or upward until it clicks. Close the paper jam door.
Leave the printer unplugged for several minutes (15). Then plug it back in. Do not turn it back on yet and restart your computer. then turn on your printer.
I hope this reset works for you. You may have to do it more than once. I've been through this one myself.
Thank you for using Fix Ya! Your ratings are always appreciated.
Aug 24, 2008 | HP DeskJet 5550 InkJet Printer
Will not print / cartridges will not move back and forth
I had this happen to me the other night and I had to restart the printer to get the print job out of the que. You could try that.
While it's restarting, unplug the power cord and the usb cable. That should reset it.
Jun 21, 2008 | HP DeskJet 5550 InkJet Printer
My printer always jams paper?
go to manufactures website and reset your printer
Mar 11, 2008 | HP DeskJet 5550 InkJet Printer
The cartridges are "stuck" in place - won't move left or right - yellow lights is flashing
With the power off. Push the carriage to the left about 4". Power up the printer. It should go through its normal reset. When it's done making noise look in & see if it went back to the center?
Open Printer & Faxes. Your default printer should have a check nex to it. make sure it is the 5550. Click the 5550 once so it's highlighted. Click file & open. Clear anything that is waiting to be printed. Close all the opened windows. Re-start the Pc.
I should list HP's suggestions too:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00034342&lc=en&cc=us&dlc=en&product=71896&rule=45014&lang=en
Try a test page even is so. Post back...
Feb 07, 2008 | HP DeskJet 5550 InkJet Printer
HP 5550 Print issue
When you removed the jammed paper , the jam paper sensor was not reset or positioned correctly. The reason the machine was sending two pieces of paper thru at once was probably due to the paper feed sensor. A lot of H'Ps do this. Try re-aligning the tray and if you pulled the paper out and heard a grinding noise, the whole feed unit is probably out of time.I would only re-install the software as a last resort, since your problem was caused by hardware, not software. Scrivitron
Jun 20, 2007 | HP DeskJet 5550 InkJet Printer
HP DeskJet 5550 InkJet Printer Logo
598 people viewed this question
Seeker5211
Seeker5211
