Question about Garmin Nuvi 360 Bilingual GPS Navigator and Personal Travel Assistant GPS Receiver
When I turned on my Nuvi255 gps it indicated that there where no maps to show. Idont know how this happened. I remember It ask me to press on a dot, than press on another dot and when I take a look at the gps there are no maps anymore. Please help.
  • Anonymous Mar 29, 2014
    car battery went dead had to jump off. when my gps came on it showed a dot on the screen that said press here.
Solved
Posted on Feb 02, 2010
My nevi 2595 shows only touch dot and will not do anything else. If you touch it the dot moves to another area on the screen
It looks like you are in the calibration mode ... just touch every dot and after a few times it will go back to the menu ... as usual.
Dec 24, 2014 | Garmin nuvi 2595LMT 5" GPS w/Lifetime Maps...
I updated my garmin nuvi255 and it only shows usa maps, now I lost all of Canada
When you update the unit you are given selections based upon how much memory is available on your unit. With each map release, the map sizes become larger. On the 2xx series, you may not have had enough memory to have both the US and Canada map, so it probably only installed the lower 48 states. You will need to install the map on an SD card in order to have both maps on the unit.
Sep 06, 2013 | Garmin nuvi 255W GPS Receiver
Hi, I have a Nuvi 255 (205 series) gps, three years old. Last week the screen went blank, came back grey with 'crosshairs' and a black dot in the middle indicating 'press here'. I did so and the dot moved...
Graham - what your describing sounds like you somehow managed to erase the street level maps and POIs in your Nuvi.
If you connect the GPS to the computer with your USB cable, you should at the contents of the Nuvi directories and find a file called GMAPPROM.IMG or GMAPSUPP.IMG. These are the street level map files. Generally, these are found in the root directory of the Nuvi - or if yours has / and you use a memory card slot for maps - find it in the /GARMIN directory. GMAPPROM.IMG is the name of the first map set and GMAPSUPP.IMG is the name of the supplementary or second map set (if you purchased & installed one). You will likely have only one of these files - and may be named either. The size of this file depends on the area and age of the map. Current maps of the entire US run over 1 GB in size. If you do not have any maps named GMAPPROM or GMAPSUPP, you will not see any street level maps.
Something happened to delete the maps. Garmin will probably NOT provide free replacement maps for you, unless under warranty. If the devices is trashing maps and other files, you probably want to replace the unit under warranty or not. Garmin will, upon return of your old Nuvi - replace it with a factory refurbished unit with the latest maps installed, for $79. You can take advantage of this service by following this link to Garmin Service.
I hope this helps and good luck! Please rate my reply. Thank you.
Mar 23, 2011 | Garmin nuvi 205 GPS Receiver
How do I get map updates on my nuvi255 without a usb cable
Unfortunately you have to use the USB cable to connect the Nuvi to a computer.
Mar 25, 2010 | Garmin Nuvi 255 Car GPS Receiver
Trying to download maps but have not been asked for my product key--- I do not see any indication of any errors. ( I know there was an indication downloading could take up to 2 hours ) should I let the...
I have downloaded maps and no product key was asked for, why do u think it should have a product key? it did ask for the model number and that is all, the maps are for all the GPS's made my the manufacturer of your unit, if certain info is required it will ask, otherwise just follow the on screen instructions as they appear.
Dec 12, 2009 | GPS
Maps disapeared from my garmin for no reason!
go into settings, then map, then map info see if box is ticked if not tick it, then return to where to and see if countrys name appears the select country
Dec 04, 2009 | Garmin nuvi 205 GPS Receiver
I've download couple of things but it seem that is not what i've
Most of the GPS companies only offer support on maps if you pay for a subscription service. The company that made mine wants $79.95 quarterly. For me, the roads don't change that much. If you need daily updates for traffic detours and such, you'll probably have to pay extra.
Sep 17, 2009 | Garmin nuvi 200W GPS Receiver
Garmin nuvi
Different parts of the screen do different things depending on the mode you're in. When you touch "speed" the trip screen appears as you've already noted. The 'Driving" icon does nothing until you've asked the GPS to take you someplace.
After you enter a route the "speed" icon changes to "arrival" (which will still bring up the trip screen) and the 'driving' icon will change to "Turn In." Touching "Turn In" will bring up a list of turns along with a small portion of the map (showing that particular turn) anytime you've entered a route.
Note you can also press the green banner on top of the map when you have a route set. You'll see a list of just the turns and the distance to each. Touching each of those turn boxes will show you the split screen offered after you touched the "turn in" button.
Cheers
Nov 15, 2008 | Garmin Nuvi 660 GPS Receiver
HOW CAN I UNLOCK MY GPS ,IDONT REMEMBER MY PIN
Go to the home location where you originally set the pin. Make sure the antenna is up and turn the unit on.
When your at the home location where you set the pin, you won't be asked for the pin and you'll be able to change the pin to whatever you want.
Please be advised that if you can't remember the home location, you'll need to contact Garmin for a solution.
There are too many of these units being stolen from vehicles and the thieves are trying to obtain the passwords on this site.
Please let me know if I can be of further assistance to you.
- Jim
Feb 25, 2008 | Garmin nuvi 350 GPS Receiver
GPS Logo
85 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
