Question about Whirlpool Refrigerators
Whrilpool refrigerator is not cooling. the
Whrilpool refrigerator is not cooling. the compressor will come on and cool only when I jump across the contacts. Does it have a service mode or a system reset. the lower coil was dirty when this unit stoped working.
  • 1 more comment
  • dougenfield Feb 03, 2010
    The contacts that I jumped across was L1 to L2 on the compressor. The control board is not sending power to the compressor. Do I have a bad control board?
    Whrilpool side by side
    Mod# GC1SHAXMS00
    Ser# EAR0801626
  • dougenfield Feb 04, 2010
    I called a whrilpool repair man out. He confirmed that the board is bad and wants $460 to replace it. Where is a good place to pick up a control board?
    thanks for the help
    President:
  • 1,218 Answers
Good day,
I'm not sure which contacts your dealing with. If it's the contacts on the compressor, then replace the components as a package. Relay, overload, and run capacitor if it came with one.
If it's the contacts on the thermostat, then replace it.
If something, somewhere else, please post back with the description and location, and the complete model number..
Posted on Feb 02, 2010
  • 2 more comments
  • John Hall Feb 03, 2010
    Good day,
    I guess what you mean is you supplied an outside source of power. If that is the case, then yes, the board is very suspect.
    However, you didn't supply the age, make, and model number. That was important information. There are boards that only perform defrost cycles. On those, they not only shut down the compressor, but the fans as well.
    Others are all encompassing, performing defrost functions, fan functions, and temperature control.
    My error. The data only showed up when I exited your post. Some kind of glitch here.
    If the machine is not running at all(no fans either), then it would have failed in defrost mode.
    The adaptive defrost control would be at fault. In either case the board is responsible for telling the compressor when and when not to run.
    There are as well as the diagram shows, 2 thermistors that control the electronics. They are temperature sensitive.
    A good appliance parts house should be able to test them for you.
    Sorry for the delay.
    I checked on the price on that board. It's close to $300.00
    Before I'd make a decision, it would pay, if you live in an area that has Whirlpool authorized service techs to make a diagnosis for you, even if you want to do the actual repairs yourself.
    Like GE they are becoming totally absurd.
    It's pathetic what they've done with refrigerators in the last 10 years.
  • John Hall Feb 04, 2010
    Good day,
    The first stop would be your local appliance parts house. Check with them, then compare here..
    http://www.appliancepartspros.com
    Have your model number ready.
My Whrilpool 3 Door Protton refrigerator was found cooling only freezer compartment, not refrigerated compartment. Local mechanic told that it is a defrost problem and replaced two bi-metal thermostat
this seems to be a major issue with whirlpool and kitchenaid multiple door refrigerators. The defrost timer device on the compressor does not function properly or fails and the cooling coils freeze up. Check the little fan that pulls air through the freezer coils to make sure it is running (that cools the refridg) if not running then it is bad and causing problem. Otherwise you have another bad defrost relay on the compressor. It's easy to change and cost about $25 at the parts store. I just defrost mine every six months or so since none of the ones I tried work very well. Its just a bad design that is still propagating in whirlpool devices.
Jan 06, 2015 | Refrigerators
My lg gm-313sc keep on work and stop in lest than 3 minits
The refrigeration is short cycling. The cause may be due to airflow problem. There is an outside fan thalt blows across a radiator and another in the inside the fridge enclosed behind panels.
These two fans must run and blow across the refrigeration radiators. The outside one can clog with lint and dirt, the inside one can clog with ice buid up, or the fans simply quit working. Check that the fans run and that the radiator coils are clean and clear to airflow. For the outside one, paneling will need to be removed, as well for the inside one if the outside one does not do the trick.
The refrigerator compressor short cycles because it overheats. The cool refrigeration gas entering the compressor cools it and when the gas is not kept cool, the compressor may short cycle.
There may be a different problem but checking for airflow is a start.
Jan 06, 2015 | LG Refrigerators
I purchased whirl pool refrigerator sept2004 for guarnty 7 year scheme but now refrigerator have not done cooling
check to make sure compressor is running may be something simple like the relay on compressor... also make sure there is no frost build up on back wall of freezer as this would be a defrost issue and will frost up enough that it cannot move air across coil to cool....
repost with any questions....good luck to you...
Jan 08, 2011 | Refrigerators
Fan blowing air across coils, compressor seems to be working. refrigerator portion not getting cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 01, 2011 | Samsung RS265LBBP Side by Side...
Motor not running Refrigerator not cooling
There are three possibilities why the compressor motor is not running. #1. The thermostat switch is not closing to turn the motor on. #2. The compressor motor is bad. #3 The defrost timer is engaged, preventing the compressor motor from starting.
Solution for #1: Locate the thermostat switch behind the console in the refrigerator. It is attached to the freezer temperature adjusting knob. If you jump the switch out, the compressor motor should start. If it does, replace this switch.
Solution for #2: get another refrigerator. It is not worth repairing.
Solution for #3: Turn the freezer temperature switch to the coldest setting. Locate the defrost timer in the console on the ceiling of the refrigerator compartment. Look for position labels like "cool control" and "compressor". Jump between these two wires. The compressor should start. If it does, replace this module.
Mar 06, 2010 | Kenmore Refrigerators
Whrilpool refrigerator model ed25te will not cool or freeze. lights are on, fan works
Your compressor may be trying to start and have a bad start capacitor, start relay or overload. If you hear the fans that tells me the thermostat has also told the compressor to start. Unplug and pull away from the wall. remove lower cover over the compressor area and feel the compressor on the top. If too hot to keep you hand there leave the refrigerator unplugged until we locate why the compressor is trying to start but will not. tell me the age of your refrigerator. I will keep checking for a response from you and will be here to help, Thanks, Sea Breeze
Jan 16, 2010 | Whirlpool ED2SHGSM Side by Side...
Refrigerators is not blowing cool enough air to freeze or cool each side respectively.
I assume the compressor is running since you indicate you have some cool air.
Check to make sure the compressor fan is running. This fan should be near the compressor. Its purpose is to pull room air across the coils and remove the heat from them. If this fan does not operate properly, the refrigerant will not be cycled properly. If the fan is not turning, you will need to replace the fan motor.
Oct 17, 2009 | Refrigerators
Whrilpool refrig, smells hot, so i cleaned the coils and turned it off for a few hours, seems cooling fine
sir, your refrigerator need a servicing. so please call the nearby service engineed to checkup the compressor condition, refrigerant pressure, etc.
thanks for contacting fixya
Sep 12, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My whrilpool freezer and refrigerator stop working after defrosting
1Plugged coils (lint and dirt) cutting off air flow will cause the problem you describe; Also
2 Fan that will not run underneath the box
3 Defective compressor
4 Compressor starting components, are the 1st items that come to mind with a description like yours.
But first check your controls inside and make sure they are set to mid range.
2 types of controls in refrigerators 1 for on off and 1 for air flow. If this control you mentioned has "off" on it this is the thermostat. Look for the other one and set it to mid range
If this has helped you please rate me as high as you can and thank you for using fixya..
Sep 03, 2008 | Whirlpool ED0GTQXMQ Side by Side...
-check your thermostat setting at refrigerator it should be at cold. Same digital control they have separate settings.
- Check also the vents of your unit for obstruction.
Jan 13, 2008 | Refrigerators
Refrigerators Logo
62 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
