Question about Kenwood KDC-MP335 CD Player
My Auxiliry input is turned off and the manual doesn't tell you how to turn it back on... Anybody know how to turn it back on? I press the source button and it doesn't go to aux anymore. It just goes through the cd, turner, and standby.
You need to have in standby. Press and hold the bost button left of preset station one. Use you am fm on the right side of the radio. Go up or down to find aux to turn in on or off. I had the same prob.
Posted on May 04, 2010
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Kenwood Master
  • 2,226 Answers
Try going into the menu and see if it can be turned back on from there. press menu for a few seconds and use am and fm butttons to scroll through the menu and the seek up and down to adjust it .
Posted on Feb 01, 2010
After plugging the hdmi cable, we have the sound but no video
Some ideas:
  • Make sure the correct input is selected for your display device.
  • You may need to change the video out setting on your video source device (Blu Ray player, cable box, etc) to turn on the HDMI output port. See the video source's manual.
  • Devices connected to HDMI are sometimes picky about the order they turn on. Try turning off the video source and video device, then turn on the video source, wait a few seconds, then turn on the display. If that doesn't work, try reversing the order that they are turned on. If this is the problem, you can buy a universal remote, like the Harmony, that will start devices in a specified order.
Feb 12, 2012 | Panasonic DMPBD655 Player
Can hear sound but no picture
You didn't mention what the source was or how it was connected or if you were using analog or digital connections.
It appears that the device (cable box, maybe??) is assigned to different inputs for audio and video.
The solution should be really simple.
Kind of odd for this to just "happen", but it might have something to do with static electricity or a small power surge. Your first remedy should be to unplug the H/K receiver for 30 seconds and plug it back in. This should reset any logic hiccup.
The AVR's manual will show you how to assign video inputs and audio inputs to specific devices. You'll do this differently, depending on what cables you are using and how you have set up the source device, but the instructions do tell you how to make this work.
Basically, you'll need to know what button on the AVR you want to use to select this source. Then in the AVR's menu, you'll need to tell the receiver which of its inputs should be selected when that source button is pressed. Look closely at the back of the receiver and see where you have connected the cables. Your solution might be to simply move the audio and or video cables on the back of the receiver to jacks with the same labels!
For instance, if the video cables are connected to the receiver's video-1 jacks and the audio cables are connected to its video-2 jacks, just make them both the same.
Jul 24, 2010 | Harman Kardon AVR 240 Receiver
We turn it on and the screen stays blue...it is connected to the cable but won't get a picture nor does the original set up come on
I don't have the manual in front of me but what you need to do is change the source. The tv accepts input from various sources and connections. So you need to tell it where to find the signal you want. On your remote there will either be a button marked source or you will have to find it from the setup or menu button.
Usually there are 3 or 4 valid inputs. So all you do is press the source button and it switches to the next source. If there is nothing there you press it again and it goes to the next and so on. It will just keep cycling through the inputs as you press the button. You should see something marked as AV1 AV2 CABLE as you cycle through. When it finds the cable source it will then scan through and mark the avilable channels. This may take a few minutes. After that you can just use the remote to normally switch channels up/dwn etc.
May 09, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sound output problems
Are you saying a stereo source sometime switches to multichannel? In my experience, that's the opposite of what I think could be happening.
Many AVR's have automation that can be set to select the better of the two audio paths from a source if you have analog and digital assigned to the same input. If digital is present, it prefers it. If the signal degrades or goes away, it switches to analog. I think it's trying to tell you the hdmi cable connection or the source is flaky.
Perhaps you could flesh out the details of what input is being used and also look at the source device. Isolate the cause by swapping it to another compatible input and/or trying another cable.
Feb 11, 2010 | Audio Players & Recorders
Code 22, will not power up.
i found you a manual :)
http://www.mitsubishi-tv.com/support.html
from here select
CRT televisions, year:2003, then your model, and click pdf :)
Nov 19, 2008 | Mitsubishi WS-55411 55" Rear Projection...
CASIO TK 7000 cash register how to change the time
pgm 1
enter 24Hr Clock
0900 or 2100
press the date/ time button
next to the C Key on standard keyboard
Nov 11, 2008 | Computers & Internet
The who input button
usually a tv that doesn't "see" video on the S-video will not even "switch" to it.  It just goes to the next Svideo, RCA etc..
Make sure your cable is not damaged. (on both ends) Does the svideo source and svideo cable work with another tv or video device?
31GT740 Manual From the Manual:   " WHO•INPUT In TV mode, press WHO•INPUT to toggle through the available Video Input channels (VID/SVID and the current channel). In SAT mode, press to select available channel lists.
Using the WHO•INPUT Button Use the WHO•INPUT button to toggle through the available input sources (VID and the current channel) and view the content from the component you have connected to the TV. 1. Press TV to place the remote in TV mode. Make sure that the content from the component is turned ON. 2. Press WHO•INPUT to tune to the available input source and view the component. 3. Press WHO•INPUT again to tune back to the channel you were previously watching.  "
James Mac
Sep 10, 2008 | GE 31GT740 31" TV
RGB
Press input until tv apears again. Or go into menu , setup Video input and select av or tv what ever you use.
Dec 23, 2007 | Vizio L37 Television
AUX inputs
Turn the ignition key to on or accessory position, turn the stereo off, then hold the function key for a couple seconds, the stereo will turn on and you scroll through the menu with the left and right arrow buttons and change settings with the up and down buttons
Feb 25, 2007 | Pioneer DEH-P6800MP CD Player
Kenwood KDC-MP335 CD Player Logo
148 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
