Question about HP PSC 950 All-In-One InkJet Printer
Copies print with a magenta hue. The color yellow doesn't print out. Tried 3 cartriages all the same. Clean printer also.
    President:
  • 2,306 Answers
Try dabbing the cartridges on a paper towel, if you don't see a yellow line, the yellow is just empty, many have had the same complaint, new cartridges with no yellow inside.
Posted on Feb 01, 2010
When i try to print in color, the red prints as yellow..i am not out of ink
Most printers have 4 inks: Magenta, Cyan, Yellow, and Black. Red requires the printer to print both Yellow and Magenta. If your Magenta isn't printing, red will show up yellow. When you say, "I am not out of ink", you may actually BE out of Magenta, or your magenta ink nozzles may be clogged. I don't know what brand of printer or model you have, so I can't give you exact directions to clean the nozzles. The printer driver may have that ability.
Dec 17, 2016 | Office Equipment & Supplies
I am using a HP CP3505n printer. I have changed all the four catridges. But while printing color copies, I am not getting all the colors as seen on the picture. While running a band test, no shades of...
Something is wrong with the yellow cartridge.
pull the yellow cartridge, and make sure transportation strip got fully removed, give the cartridge a good shake, and reinsert the cartridge and try the band test again.
If you still only get magenta and cyan and combinations of them, return the yellow cartridge for a replacement.
Apr 12, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
Are the ink cartridges just a few copies, I have new copier and print is very faint
You need to clean the print head and insert the cartridge and check, whether it is working at fine because a dirty printer header will not allow the right formulation of the basic cyan, magenta, and yellow to print and comes up with the yellow color and not red.
If you still face the problem after cleaning print head then you need to check for a clogged nozzle. Clean the nozzle and then try printing it will work fine now.
To clean the print head from the Utility section found in the printer driver, clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. Furthermore, you can clean the print head by Using a cotton Q-Tip & Isopropyl Alcohol and gently rub the print head with alcohol.
Hope this helps.
If you still have any queries, please feel free to ask us.
Shane
Mar 03, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Making Only megenta color copies no other color
When the blue color ink is finished it may print magenta instead of blue. And it is clear that black,yellow,red colors are there.
Jun 18, 2010 | Ricoh Aficio CL3500N Laser Printer
Okidata C5200N printer: streaky copies on magenta
If the streaks are only from the magenta then your magenta drum is bad. If you recently replaced it, it may still be under warranty.
Jan 19, 2010 | OKI C5200n Laser Printer
The lt magenta and magenta just quit printing between pages
1. Check if the cartriges are correctly installed:
Installing the Ink Cartridges
2. Print a diagnostic page and clean print heads, using the printer cleaning utility:
Color Mix or Missing Colors on the Diagnostic Page
Repeat if needed.
3. If this still doesn´t solve you problem, try resetting the printer and manually cleaning the cartrigdes as advised in this FAQ:
Ink Cartridge is Missing, Incorrectly Installed, or Not Intended for Your Device' Error Message is Displayed on the Printer
Sep 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
D7260 not printing some colors
1.Try placing sheet of Magenta print on copy board, and run many copies .  Run head clean after about each 50 sheets.
Apr 24, 2009 | HP Photosmart D7260 Printer
Color LaserJet Printer Problem
Have you tried changing the magenta and black toner cartriages?
Jan 26, 2009 | HP Color LaserJet 3500 Printer
Prints only green predominently
Without knowing what printer you have or what things you have tried I can only guess here. It sounds like you need a new cartridge. A color ink cartridge will have 3 colors of ink for most printers...cyan (blue), magenta (purplish-maroon), and yellow. Depending on what you print it is very possible that you could run out of one of the inks before the others. Printing green can be an indication that you are out of magenta ink. The cyan and yellow inks will combine and look green.
You can remove the cartridge and run a tissue over the printhead and see if you see all 3 colors as a quick test. If you only see cyan and yellow, then the magenta is probably empty or dried up. If you see all 3 colors I would reinsert the cartridge and try printing again. It is possible that the magenta was just clogged and you cleaned it with the tissue. If it still doesn't print all colors your best bet is probably to just get a new ink cartridge.
Sep 10, 2008 | Office Equipment & Supplies
Yellow Hue when color copying
I understand your situation, however let me explain you that whenever you try to make a copy or print, yellow cartridge takes part and provides its color in all the aspects. Please do check that you use the HP ink cartridges and try to clean the cartridges for every 15 days as this may reduce the issues of colors.
Feb 07, 2008 | HP Photosmart 2710 All-In-One InkJet...
HP PSC 950 All-In-One InkJet Printer Logo
65 people viewed this question
Seeker5211
Seeker5211
