Question about Pioneer AVH-P6500DVD Car DVD Player
Disc removal received an error 02 message and not ive shut off the car is that the same as removing power from the unit......
  • 2 more comments
  • Anonymous Apr 09, 2008
    Me having the same problem with my Indash pioneer DVD, Error-02. Even after multiple reset, same problem...
  • Anonymous May 02, 2008
    error 02
  • ceelamb Jun 14, 2008
    the cd in the unit saying error02 and when i press eject the whole unit shuts off , and comes back on minutes later still displaying the error02
  • steven_phan Dec 15, 2008
    i have the same problem. error 02 and disc is stuck inside indash
    Problem Solver:
  • 5 Answers
If that doesn't work, it might be that the cd lens is dirty or going bad.
Posted on Apr 27, 2008
  • 78 Answers
Try pressing the reset button on the front of the unit, you will need a pen to get at the button.
Posted on Feb 26, 2008
My pioneer AVH-p6500 shows error 02. I found out in the manual that it is from a scratched disc(so it would not play it). Problem is, I could not eject the disc it keeps turning the system off. Please...
Unfortunately the internal safety circuits are going to fight you here. The unit has detected a mechanical problem during the attempt to eject and shuts down to prevent further damage. You will need to dis-assemble the unit to remove the disc. It is possible that the lens has a dirt film on it that would prevent it from reading the disc, thus the 02 error code. This is not the easiest mechanism to work on. I would suggest that you seek a service shop for this repair.
Dan
Mar 20, 2008 | Audio Players & Recorders
C:13:02
After having formatted the memory stick with the cardreader on my laptop which runs on winxp I tried to use the stick in my sony dsc-p5 but all I got was the C:13:01 error message. So I tried to format it again but eith FAT instead of FAT32 which is the regular format on winxp. Now the disc adapter which I use on my desctop to read the memory sticks worked again with the stickt, my camara still gave me the message of not being able to read the stick so I removed the stick, got into the setup mode, reinserted the stick and formatted it with the camara. This worked, I hope this can help you.
May 09, 2010 | Sony Handycam DCR-DVD92 DVD Camcorder
" USB ERROR "
Hello kenwood12312,
With the receiver OFF, remove the USB device then turn the power ON. If the same display is repeated, use another USB device. Remove the USB device without entering the remove mode. If this does not work, try resetting the receiver. Press the "reset" button just above the AUX INPUT. This will return the unit to factory default settings. If these steps fail and you still get the USB error, the receiver is faulty and needs service.
Hope this helps.
May 20, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
02 COLOR CARTRIDGE ISSUE
  1. While the unit is on, remove the power cord from the rear of the unit AND the wall outlet.
  2. After one minute, reconnect the power cord to the wall outlet and the unit.
  3. If the unit does not turn on, press the On button.
Check if the error goes away ...
Jan 21, 2009 | HP Photosmart C5180 All-In-One InkJet...
Error message e099
Hi try resetting the unit, or down powering the changer. this could reset the unit. if not then it wil need to be repaired
May 22, 2008 | Kenwood KDC-CPS89MP 10-Disc CD Changer
Avh-p5900dvd... I keep getting error -02-9e and it wont play cd,s or dvd,s can you help.
Owner's manual doesn't really say what the -02-9e error code means other than a disc error. They do recommend resetting the unit as a possible solution:
  1. Turn the ignition off.
  2. Remove the faceplate.
  3. On the right side of the front of the head unit (with the faceplate removed), press the reset button with a ball point pen.
You may have to call Pioneer directly to find out what the -02-9e code means specifically. 1-800-421-1404
Apr 03, 2008 | Car Audio & Video
DISC STUCK AND ERROR 02 MESSAGE
hi, i have a kenwood kvt_725(or did have before some scallywag robbed it) i had a simular problem when ejecting discs i found that if you turn power off and removed face plate and turned ignition off it eventually ejected the disc and worked, or a simular routine with the face plate then ignition etc etc. i know it seems a lame solution sorry but hope it helps.....
Mar 20, 2008 | Pioneer AVH-P6500DVD Car DVD Player
Rpd 552 cd reader problem
Message Possible cause Recommended action
E-01 Dirty disc. Clean the disc.
Scratched disc. Replace the disc.
Up-side-down. Check the disc.
E-02 Focus error. Try ejecting and re-inserting
under normal temperature
conditions.
E-03 Data and focus error. Under normal temperature
conditions, eject and
insert clean, undamaged
disc properly.
E-04 Mechanical problem. Eject and re-insert.
Oct 17, 2007 | Blaupunkt RPD 552 CD Player
Pioneer AVH-P6500DVD Car DVD Player Logo
1,002 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
