Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
Message on screen "check fan 1" - Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
  • Angel  Petterson
    Angel Petterson May 11, 2010
    try to clean your TV.
    1.- a can of compressed air.
    2.- a small vacuum cleaner
    (preferably a hand held).
    3.- a mouth cover.
    4.- a pair of latex gloves. and check if you can see if one of the fans is not working
  • 69 Answers
Look inside the tv one of the two fans is not rotating there is one that can be seen easily thru the rear cabinet the other you have to look thru the lamp housing its hard to see while the tv is on because of the brightness of the lamp.
Posted on Feb 07, 2010
    Guru:
  • 114 Answers
Try to clean your TV.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1.- a can of compressed air.
2.- a small vacuum cleaner (preferably a hand held).
3.- a mouth cover.
Posted on Feb 10, 2010
A message can on the tv "check fan No 1"
the message means the set has detected an issue there, the fan may or may not be bad. See a lot of this and half the time the fan is good.
Dec 12, 2012 | Televison & Video
Where is fan 1
If you have a fan error i would replace them all.
You can get get parts for this tv at www.interliquidparts.com
Nov 26, 2011 | Samsung LN40A650A LCD TV
I have a 61 inch samsung TV. A message flashed across the screen saying "check fan # 1 " then a few minutes later it shut down.
Hello
Not much to do by web, this message mean you most likely need a new fan, tv shuts down due to overheating. Contact service.
Aug 21, 2011 | Samsung Televison & Video
Sony KDS-55A2000. bought 1/07. replaced bulb 2/08. gave tv to parents 11/10. worked fine until last week. 1 on screen message, temperature warning (they checked all vents-everything clear and 1' away from...
you will need to check the fans are all switching on when you turn the tv on, it might be one of the fan sensors that has gone bad, the tv wont turn on if it detects that the fans or a single fan is not working. I have not worked on this particular set , but that would be the first place i would look, if you find a fan is not firing up and if you have a multimeter, then check to see if you have a 12v voltage going to the fan, an easy way of rectifying it is to run a wire from one of the other working fans to the positive of the fan that isnt working. This would at least eliminate the fan as the culprit, if the tv starts up normally then the problem lies in why the fan is not receiving power. I ran a tv using this method for over 8 months before it died, from other problems i might add , not the fact i bypassed the fan power circuit.
If you found this info useful please take a moment to vote for me
Mar 30, 2011 | Sony KDS55A2000 55" HDTV
Check fan 2 message is on the bottom of the screen, what does that mean?
Check the fans for dust and dirt if duirty clean them. If you do not see any that are dirty then it means Fan is defective if it stops running while set is trying to come on.
Samsung Parts.com 1-800-627-4368
Oct 28, 2010 | Samsung HL-S7178W 71 in. HDTV Television
Error Message: Condition 1
Error condition 1 is a faulty Fan. On these units if one fan is faulty then the sensor will shut the screen down as a protection.
a repair of this unit is possible.
Regards
May 12, 2010 | Fujitsu Plasmavision PDS-4214 42 in....
Message on my tv reads check fan 1..
check fan 1 means the fan is not cooling, check to variety the fan is indeed working, the unit is shutting down due to over temp. if there is a filter, clean it
Jan 30, 2010 | Samsung Televison & Video
Tv ask me to check fan number 1 -hlt5676s
Get the manual and determine where the fan is. Make certain it is clean and working freely, and make certain the air passageway and screen are not clogged with lint. If the fan is not working, you might be able to lubricate it, or perhaps it will need replacement.
Oct 14, 2009 | Samsung HL-T5676S Television
Samsung sp50l6hd it is showing up on the sceen fan 2 error can any one help?
If a “Fan error message appears on the screen:
1. Look at the fans to see if they are running while the unit is on. If not running check the connector. If the connector is good replace the fan.
2. If all fans are operating, problem is in the fan detection circuit, Actuator, Protection Board or Digital Board.
May 15, 2009 | Samsung HLN467W 46" Rear Projection HDTV
Optoma RD50 TV which shuts down on #1 fan failure
This could be a variant of, or a newer (or older) version of the "DMD fan failure" message.
Symptoms I had are, I stop hearing a fan when the message is displayed.
Then the temp LED keeps flashing RED until I either try to turn the TV on again,
Or turn MAIN power off/on again. BUT it repeats when I try to turn the TV on.
The picture appears normal until this happens ( about 15 sec.)
The solution is to FORCE a normal shutdown by hitting the TV off button
before the message appears.
You should see the power LED flashing RED/GREEN (cool down) and then RED (standby).
Apr 20, 2009 | Optoma RD50 50" Rear Projection HDTV-Ready...
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
103 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
