Question about Lisle Oil Pressure Sending Unit Socket for GM # 13150
My 1988 suburban is leaking oil but only when it's running, and its a pretty steady drip I was wondering if it could be a oil pressure switch, and if it is where is it located on the motor
  • 111 Answers
Yes ,it can be the oil pressure sending unit, it's located on rear of the motor, just to the left of the distributor where it goes into the block, sometimes getting at them can be interesting, good luck
Posted on Feb 01, 2010
    President:
  • 1,515 Answers
If it is leaking as steady as you say when the engine is running, it could be coming from several places you can check. Raise and block the vehicle good and steady enough to where you can slide under it with a good strong light. Check the oil drain plug, pan gasket, oil filter may have a hole in it from a rock flying up, the sending unit should be on the side of the block. It could be the rear main seal, but Its doubtful as you say its a steady stream when its running. You shouldn't have a problem finding it if its a steady leak, you will just have to look where its running down with the engine on. Keep me posted, and good luck.
Shastalaker7
Oil leak, dripping onto starter
check if bolts by oil pan may be loose
Jan 15, 2014 | 2006 Chevrolet Cobalt
I did a oil change on my 1994 gmc suburban w/5.7L and it started leaking oil on the back of the motor by the intake and the brass fitting for the oil pressure sensor. It is a steady leak and will lose all...
OK, does it appear that the oil pressure sensor is leaking through the plastic to metal seam (on the sensor itself)?
Have had an oil pressure sending unit go bad and leak on a 1990 Oldsmobile Cutlass Calais that needed to be replaced.
REMOVAL & INSTALLATION C1500 Suburban 1994
  1. Disconnect the negative battery cable and drain the engine oil.
  2. Disconnect the sensor electrical lead and unscrew the sensor. The sensor can be found on the top side of the engine, near the distributor. To install:
  3. Coat the first two or three threads with sealer. Install the sensor and tighten until snug. Engage the electrical lead.
  4. Connect the battery cable and fill the engine with oil.
Jul 14, 2010 | 1994 GMC Sierra
Oil in my honda civic 1991 is dripping all over but only when the car is running any ideas?
your the only one that can answer where, check the oil filter and the oil light switch first.
Oct 02, 2009 | Honda Civic Cars & Trucks
Gauges say no pressure in engine 1995 vw golf
Get someone to check oil pressure with a mechanical gauge, to verify whether you have oil pressure or not. These engine/vehicles, have 2 warning sensors & a control module in the instrument panel. Once you know you have pressure for sure, then you can proceed from there.
May 09, 2009 | 1992 Volkswagen Golf
Hi i have just bought a nissen paulser 1988 gx ventura and i have noticed it is leaking oil i am not sure where from and was wondering if it would still be safe to drive as long as oil is topped until i...
Yes,it will be safe to run as long as you keep the oil level up,but note how many miles it takes to leak a quart,it can get pretty costly to keep adding a quart everyday and may be more cost effective to just fix the leak.Hope this helps.
Apr 12, 2009 | 1988 Nissan Pulsar
Oil leak problem with 1996 toyota camry
I am going to see a mechanic - my trusted mechanic who does not nickel and dime me - to see what this is. I have the same problem and he told me he has never done this job on a Camry and is unsure. Given the miles, he has suggested that maybe it is time to part ways with the car. I am going to ask him if he will put some florescent dye in it and let me drive it for 50-100 mi and then check to see where the leak is and fix it. Let you know what happens. I have to try, the car is solid.
Mar 30, 2009 | 1996 Toyota Camry
Lisle  Oil Pressure Sending Unit Socket for GM # 13150 Logo
120 people viewed this question
Top Lisle Measuring Tools & Sensors Experts
Jerry Kramer
Jerry Kramer
Prariehog
Prariehog
Mai Lor
Are you a Lisle Measuring Tool and Sensor Expert? Answer questions, earn points and help others
