Question about HP PSC 950 All-In-One InkJet Printer
The pictures have a meajenta hue. The color
The pictures have a meajenta hue. The color yellow doesn't print tried 3 cartriages all the same.
  • 3 more comments
  • jfender2 Feb 01, 2010
    I have checked 3 cartriages the colors are now delouted and no yellow prints.
    Already clean cartrige and printer same problem
    have had printer for about 5+ years never had problem before only had problem for about 2 days
    Thanks for your help
    leethdeuce was helpful
  • 4,472 Answers
How long have you owned the printer? How long have you had this problem? Keep in mind if the camera does require repair. That the latest model of it is only about a 100$. Then you are getting all new parts with a new warranty. Most times this ends up being a much better investment of your money. Once I have more information I can assist you further.
Thank you,
Lee
Posted on Feb 01, 2010
  • Lee A.
    Lee A. Feb 01, 2010
    Being the age of the printer I would consider replacement. It definitely sounds like it is need of repair. For how cheap you can get a new replacement with all new parts and better quality. You can sell your printer for parts on ebay or craigslist. As there are still parts that someone could use to repair another printer. If you need further assistance please let me know.
    Thank you,
    Lee
  • Lee A.
    Lee A. Feb 01, 2010
    Your very welcome. Please consider accepting/rating my solution accordingly.
    Have a great day,
    Lee
    President:
  • 2,306 Answers
Try dabbing the bottom of the cartridge on a damp paper towel, a slightly wetter area will help clean the nozzles and then press in a dry area and look for each color to make a color streak. If yellow is missing you just have bad cartridges. There have been several people with the same complaint, could be the yellow evaporates faster, check the expiration date on the cartridge, hopefully you can return the defective cartridges for new or money back. No yellow on the towel means there's no yellow in the cartridge.
  • Craig Gillette
    Craig Gillette Feb 01, 2010
    Try cleaning the contacts on both the cartridge and inside where they connect. A pencil eraser can clean the little copper squares on the cartridge and a towel wit alcohol can clean the pins inside where the cartridge connects, wipe off any rubber pieces from the eraser before re-installing. The colors are diluted after the wet towel but if you select clean cartridges in the maintenance menu from the front panel the diluted inks are restored. From the print reports in the menu selections you can print the printer status page that uses less ink.
Both the picture and sound work when the TV is turned on, yet the picture is distorted like a double picture and has a yellow hue to it.
Sounds like you have a convergence problem. If you go into the setup menu of your TV, there should be some settings to adjust the red, green and blue hues and re-position them so each color matches up. If this does not work or if you don't have a menu, your TV *might* have a circuit board with several plastic screws on it. These adjust the picture and it's a very tedious task to re-align each hue correctly.
My projection TV is an older model from 1995, which is probably why it has this circuit board in place of a convergence menu built into the TV.
If adjusting the convergence still doesn't work, you might need to purchase a new convergence chip.
May 20, 2011 | Sony KP-51WS520 51" Rear Projection...
Colour prints coming out with a lilac hue
check whether the printer is in proper mode or not
Feb 29, 2008 | Epson Stylus Photo 950 InkJet Printer
Color section in tv receiver
can I know what is the answer for that question.
Feb 23, 2010 | SAMTRON 96B 19" CRT .22MM 1600X1200...
Copies print with a magenta hue. The color yellow doesn't print out. Tried 3 cartriages all the same. Clean printer also.
Try dabbing the cartridges on a paper towel, if you don't see a yellow line, the yellow is just empty, many have had the same complaint, new cartridges with no yellow inside.
Feb 01, 2010 | HP PSC 950 All-In-One InkJet Printer
HP D7260 can't print color in black & white only - greenish hue
I am having the same problem, printing photos I took of the moon thru my telescope. Any solutions?
Jul 01, 2009 | HP Photosmart D7260 Printer
No ink on page
Clean the contact in the housing area and on the ink cartriage. If that does not work buy a new cartriage. The ink probably dried up in the nozzles. You can place the ink cartriage on a wet paper towel water or alcohal and press the cartriage into the towel. If you see no ing replace.
Jun 11, 2008 | Office Equipment & Supplies
Yellow Hue when color copying
I understand your situation, however let me explain you that whenever you try to make a copy or print, yellow cartridge takes part and provides its color in all the aspects. Please do check that you use the HP ink cartridges and try to clean the cartridges for every 15 days as this may reduce the issues of colors.
Feb 07, 2008 | HP Photosmart 2710 All-In-One InkJet...
Yellow hue
1)Please verify your model # from back of set......
2)Reduce the color to minimum or tune in a black & white chan.
you should see gray, not yellow hue
3)Remove lower front grill cover & access panel.....locate the
focus / screen control block...turn blue screen control slightly
CW......red,green and blue must mix to equal gray
4) reset color to normal level.......reassemble
Dec 22, 2007 | Toshiba 57H82 57" Rear Projection...
HP PSC 950 All-In-One InkJet Printer Logo
35 people viewed this question
Seeker5211
Seeker5211
